  3. Test your home made controller with MockMySensors (w/ tutorial)
39 Posts 12 Posters 30.9k Views 14 Watching
  • barduinoB
    barduinoB
    barduino
    wrote on last edited by barduino
    Hi Folks,
    While building my custom controller i've run into a problem of not having enough arduinos/material to produce each type of supported sensors.
    So in order to create visualizations for each sensor I've decided to create an arduino sketch to fake sensors and send dummy data.
    Of course I'm running out of Global/Local variable space half way through (about 12 sensors, even with debug off) but plan to comment/uncomment the sersors to fake.
    Also I havent had a proper chance to test this.
    Is anyone interested in this?
    Want to give it a go?
    Check it on MySensors Github
    Usual stuff, open source, as is, terrible code, blá blá blá, have fun!
    Cheers
    A 1 Reply Last reply
    • blaceyB
      blaceyB
      blacey
      Very cool. I think the appropriate term would be "mock" sensors as is common in software where one mock objects for testing.
      • barduinoB
        barduinoB
        barduino
        Guys
        No pun intended.
        I admire and appreciate your work with my sensors library
        Cheers
        • barduinoB
          barduinoB
          barduino
          Hi Folks
          Did a major refactor on this thing and was able to do some preliminery testing.
          Due to memory limitations on the Arduino, you now can comment/uncomment the sensors you would like to test. I was able to test about 12 sensors at a time (if i turn off the MySensor library debug).
          It is able to fake/mock the 24 sensors on the 1.4.1 MySensors Library.
          Nest steps will be:
          • remove the read/write from the eprom
          • include the extra sensors supported by library version 1.5.
          • Implement a way to request sensor information (where it makes sense)
          Not necessarily in this order...
          With this I now have plenty of information to use in my controller HAALL
          It has also made a very good exercise in creating MySensors code.
          By the way I would like some advice from the arduino experts here....
          As I mentioned you can comment/uncomment the sensors declarations on the beginning, I use a lot of #ifdef in the code.
          My question is: Is there a more elegant solution for this?
          e.g. for the dimmer sensor:
          //declaration
          #define ID_S_DIMMER                   5
          //Message
          #ifdef ID_S_DIMMER
            MyMessage msg_S_DIMMER(ID_S_DIMMER,V_DIMMER);
          //set up - presentation
          #ifdef ID_S_DIMMER
              Serial.println("  S_DIMMER");
              gw.present(ID_S_DIMMER,S_DIMMER);
              gw.wait(SHORT_WAIT);
          // loop
          #ifdef ID_S_DIMMER
              dimmer();
          // read function
          #ifdef ID_S_DIMMER
          void dimmer(){
            int dimmerVal = gw.loadState(ID_S_DIMMER);
            Serial.print("Dimmer is set to: " );
            Serial.println(dimmerVal);
            gw.send(msg_S_DIMMER.set(dimmerVal));
          // incoming message switch
          #ifdef ID_S_DIMMER
              case V_DIMMER:
                    if ((message.getInt()<0)||(message.getInt()>100)) {
                      Serial.println( "V_DIMMER data invalid (should be 0..100)" );
                      break;
                    gw.saveState(ID_S_DIMMER, message.getInt());
                    Serial.print("Incoming change for ID_S_DIMMER:");
                    Serial.print(message.sensor);
                    Serial.println(message.getInt());
              break;
          Also, suggestions to remove the read/write from the eprom are welcome.
          For those who are building custom controllers, the comments on the v1.5 library help to clarify a few things.
          For example, there is no formal relation between the sensor type and the message type (and to me it wasn't always obvious), however that relation is somewhat establshed in the comments of lib 1.5.
          Thanks guys.
          As always, feedback is very welcome!!!!
          Cheers
          AWIA 1 Reply Last reply
          • barduinoB
            barduinoB
            barduino
            Hi Folks,
            Though i give out an update on the MockMySensors thing...
            Here is a pic
            Cheers
            • greglG
              greglG
              gregl
              Nice work and great idea.
              When I was getting started I too didn't have enough arduinos/radios to test different bits with it was a pain...or wanting to try out Hek's latest and greatest sensor/sketch to see what it looks like in Vera/Imperihome... but I never thought to create a sketch to just pretend it had the hardware...great thinking!
              Q: What GUI is that?
              barduinoB 1 Reply Last reply
              • greglG gregl
                barduinoB
                barduinoB
                barduino
                @gregl
                I'm one of the crazy ones who decided to build it own controller (see here: Meet HAALL)
                Still very much work in progress, but I needed this MockMySensors to get it going.
                Cheers
                • greglG
                  greglG
                  gregl
                  Wow - nice work again! Im in bed with Vera and looking at OpenHAB, but what you have created looks very nice and a good start!
                  • T
                    TimO
                    Very good idea! Thanks a lot!
                    I've tested it against my OH2 binding and it works like a charm.
                    One thing didn't work though, for S_DIMMER there is a value of 255 submitted, which was read from the eeprom. At this point OH2 grumbles because the value is >100%. ;-)
                    • barduinoB barduino
                      Hi Folks
                      Nest steps will be:
                      //declaration
                      //Message
                      #ifdef ID_S_DIMMER
                      #ifdef ID_S_DIMMER
                      // loop
                      #ifdef ID_S_DIMMER
                          dimmer();
                      // read function
                      #ifdef ID_S_DIMMER
                      void dimmer(){
                      #ifdef ID_S_DIMMER
                          case V_DIMMER:
                                  break;
                          break;
                      Thanks guys.
                      Cheers
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      Not very elegant, but just a different idea. Ability to extend it to more then 24 sensors and 1.5. I built it to test my own controller script. Not complete yet...I doubt it will ever be ;)
                       PROJECT: MySensors
                       PROGRAMMER: AWI
                       DATE: 10 august 2015
                       FILE: AWI_Universal_Test_50.ino
                       LICENSE: Public domain
                         -in conjunction with MySensors
                       SUMMARY:
                      	multisensor for controller (sensor)testing
                       Setup: sends values for al sensor specified in setup array
                      const int NODE_ID = 50;  		  		// fixed MySensors node ID
                      const int NoSensors = 36;
                      const int NoTests = 40;
                      // Sensor array: defines the sensors { Sensor_type (S_LIGHT) }, index number = sensor_id minus 1
                      byte MySensorList[NoSensors]={
                      	S_DOOR, // Door sensor, V_TRIPPED, V_ARMED
                      	S_MOTION,  // Motion sensor, V_TRIPPED, V_ARMED
                      	S_SMOKE,  // Smoke sensor, V_TRIPPED, V_ARMED
                      	S_BINARY, // Binary light or relay, V_STATUS (or V_LIGHT), V_WATT (same as S_LIGHT)
                      	S_DIMMER, // Dimmable light or fan device, V_STATUS (on/off), V_DIMMER (dimmer level 0-100), V_WATT
                      	S_COVER, // Blinds or window cover, V_UP, V_DOWN, V_STOP, V_DIMMER (open/close to a percentage)
                      	S_TEMP, // Temperature sensor, V_TEMP
                      	S_HUM, // Humidity sensor, V_HUM
                      	S_BARO, // Barometer sensor, V_PRESSURE, V_FORECAST
                      	S_WIND, // Wind sensor, V_WIND, V_GUST
                      	S_RAIN, // Rain sensor, V_RAIN, V_RAINRATE
                      	S_UV, // Uv sensor, V_UV
                      	S_WEIGHT, // Personal scale sensor, V_WEIGHT, V_IMPEDANCE
                      	S_POWER, // Power meter, V_WATT, V_KWH
                      	S_HEATER, // Header device, V_HVAC_SETPOINT_HEAT, V_HVAC_FLOW_STATE
                      	S_DISTANCE, // Distance sensor, V_DISTANCE
                      	S_LIGHT_LEVEL, // Light level sensor, V_LIGHT_LEVEL (uncalibrated in percentage),  V_LEVEL (light level in lux)
                      	S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node
                      	S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node
                      	S_LOCK, // Lock device, V_LOCK_STATUS
                      	S_IR, // Ir device, V_IR_SEND, V_IR_RECEIVE
                      	S_WATER, // Water meter, V_FLOW, V_VOLUME
                      	S_AIR_QUALITY, // Air quality sensor, V_LEVEL
                      	S_CUSTOM, // Custom sensor
                      	S_DUST, // Dust sensor, V_LEVEL
                      	S_SCENE_CONTROLLER, // Scene controller device, V_SCENE_ON, V_SCENE_OFF.
                      	S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT
                      	S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT
                      	S_COLOR_SENSOR,  // Color sensor, send color information using V_RGB
                      	S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT, V_HVAC_SETPOINT_COLD, V_HVAC_FLOW_STATE, V_HVAC_FLOW_MODE
                      	S_MULTIMETER, // Multimeter device, V_VOLTAGE, V_CURRENT, V_IMPEDANCE
                      	S_SPRINKLER,  // Sprinkler, V_STATUS (turn on/off), V_TRIPPED (if fire detecting device)
                      	S_WATER_LEAK, // Water leak sensor, V_TRIPPED, V_ARMED
                      	S_SOUND, // Sound sensor, V_TRIPPED, V_ARMED, V_LEVEL (sound level in dB)
                      	S_VIBRATION, // Vibration sensor, V_TRIPPED, V_ARMED, V_LEVEL (vibration in Hz)
                      	S_MOISTURE, // Moisture sensor, V_TRIPPED, V_ARMED, V_LEVEL (water content or moisture in percentage?)
                      // sensor data types
                      // typedef enum {P_STRING, P_BYTE, P_INT16, P_UINT16, P_LONG32, P_ULONG32, P_CUSTOM, P_FLOAT32 } MyTypes ;
                      // Test array: defines the sensor test patterns
                      // { sensorId ; sensorMessage ; type (MyTypes) ; lowValue(byte) ; highValue(byte) ; step }
                      // integer values take normal step, float values take reciproke step
                      int myTestData[NoTests][6]={
                       {0, V_TRIPPED, P_BYTE, 30, 50, 2}, // DOOR
                       {1, V_TRIPPED, P_BYTE, 30, 40, 2},  // MOTION
                       {2, V_TRIPPED, P_BYTE, 30, 30, 2},  // SMOKE
                       {3, V_STATUS, P_BYTE, 30, 40, 2},  // BINARY
                       {4, V_PERCENTAGE, P_BYTE, 30, 30, 2},  // DIMMER
                       {5, V_PERCENTAGE, P_BYTE, 30, 40, 2},  // COVER
                       {6, V_TEMP, P_FLOAT32, 30, 30, 2},  // TEMP
                       {7, V_HUM, P_FLOAT32, 30, 40, 2},  // HUM
                       {8, V_PRESSURE, P_FLOAT32, 30, 30, 2},  // BARO
                       {9, V_WIND, P_BYTE, 30, 40, 2},  // WIND
                       {10, V_RAIN, P_BYTE, 30, 30, 2}, // RAIN
                       {11, V_UV, P_BYTE, 30, 40, 2}, // UV
                       {12, V_WEIGHT, P_BYTE, 30, 30, 2}, // WEIGHT
                       {13, V_KWH, P_FLOAT32, 30, 40, 2}, // POWER
                       {13, V_WATT, P_FLOAT32, 30, 40, 2}, // POWER
                       {14, V_HEATER, P_BYTE, 30, 30, 2}, // HEATER
                       {15, V_DISTANCE, P_BYTE, 30, 40, 2}, // DISTANCE
                       {16, V_LIGHT_LEVEL, P_BYTE, 30, 50, 2}, // LIGHT_LEVEL
                       {19, V_LOCK_STATUS, P_BYTE, 30, 40, 2}, // LOCK
                       {20, V_IR_SEND, P_BYTE, 30, 30, 2}, // IR
                       {20, V_IR_RECEIVE, P_BYTE, 30, 30, 2}, // IR
                       {21, V_VOLUME, P_BYTE, 30, 40, 2}, // WATER
                       {22, V_LEVEL, P_FLOAT32, 30, 30, 2}, // AIR QUALITY
                       {23, V_STATUS, P_BYTE, 30, 40, 2}, // CUSTOM
                       {24, V_LEVEL, P_BYTE, 30, 30, 2}, // DUST
                       {25, V_SCENE_ON, P_BYTE, 30, 40, 2},  // SCENE
                       {25, V_SCENE_OFF, P_BYTE, 30, 40, 2},  // SCENE
                       {26, V_RGB, P_ULONG32, 30, 30, 2},  // RGB
                       {27, V_RGBW, P_BYTE, 30, 40, 2},  // RGBW
                       {28, V_RGB, P_BYTE, 30, 30, 2},  // COLOR
                       {29, V_HVAC_SETPOINT_HEAT, P_BYTE, 30, 40, 2},  // HVAC
                       {30, V_VOLTAGE, P_BYTE, 30, 30, 2},  // MULTIMETER
                       {30, V_CURRENT, P_BYTE, 30, 30, 2},  // MULTIMETER
                       {30, V_IMPEDANCE, P_BYTE, 30, 30, 2},  // MULTIMETER
                       {31, V_STATUS, P_BYTE, 30, 40, 2},  // SRINKLER
                       {32, V_TRIPPED, P_BYTE, 30, 50, 2},  // WATER_LEAK
                       {33, V_TRIPPED, P_BYTE, 30, 40, 2},  // SOUND
                       {34, V_TRIPPED, P_BYTE, 30, 30, 2},  // VIBRATION
                       {35, V_TRIPPED, P_BYTE, 30, 40, 2},  // MOISTURE
                      // initialize MySensors
                      MyTransportNRF24 transport(7, 8); // Ceech board, 3.3v (7,8)  (pin default 9,10)
                      MySensor gw(transport);
                      // Initialize messages, not used here
                      MyMessage Msg;                    // instantiate message to fill "on the fly
                      // storage of last values - if you onlys want to send changes (I don't)
                      float lastHum, lastTemp, lastPressure, lastLux ;
                      unsigned long SLEEP_PERIOD = 1000 ;   // Sleep period in ms)
                      unsigned long loopDelay = 1000 ;      // Sleep period in ms)
                        Serial.println("\n  Stress test for Mysensors network (201508).\n");
                        gw.begin(incomingMessage, NODE_ID); 											// start MySensors, manual set node ID
                        gw.sendSketchInfo("AWI Universal test 50", "1.0");
                        for (int i = 0; i < NoSensors ; i++) {
                          gw.present(i+1,MySensorList[i] ); // present all sensors in list
                          gw.wait(loopDelay);
                        gw.process();           // check if message from controller
                        for (int i = 0; i < NoTests ; i++) {
                          Msg.setSensor(myTestData[i][0]);    // set the sensor number, byte 0
                          Msg.setType(myTestData[i][1]);      // set the sensor type, byte 1
                          switch (myTestData[i][2]) {         // determine type of data for test and use in send
                            case P_BYTE:
                              for (byte j = myTestData[i][3]; i < myTestData[i][4] ; j += myTestData[i][5])
                                gw.send(Msg.set(i, true ));
                                gw.sleep(SLEEP_PERIOD);
                            break;
                            case P_INT16:
                              for (int j = myTestData[i][3]; i < myTestData[i][4] ; j += myTestData[i][5])
                              break;
                            case P_UINT16:
                              for (unsigned int j = myTestData[i][3]; i < myTestData[i][4] ; j += myTestData[i][5])
                            break;
                            case P_ULONG32:
                              for (unsigned long j = myTestData[i][3]; i < myTestData[i][4] ; j += myTestData[i][5])
                            break;
                            case P_FLOAT32:
                              for (float j = myTestData[i][3]; i < myTestData[i][4] ; j += 1/myTestData[i][5])  // reciproke step for float
                            break;
                            default:
                              // do nothing
                       Serial.print("Incoming Message");
                       // We wait for V_... value
                      // if (message.type == V_DISTANCE) {
                           Serial.print(" (type : ");
                           Serial.print(message.type);
                           Serial.print(")");
                           Serial.print(", status: ");
                      • T TimO
                        barduinoB
                        barduinoB
                        barduino
                        @TimO
                        Yes, it still has the init value of the eprom...
                        Good feed back, i'll initialize it to 0 or something.
                        • AWIA AWI
                           PROJECT: MySensors
                           PROGRAMMER: AWI
                           SUMMARY:
                              gw.wait(loopDelay);
                                case P_BYTE:
                                break;
                                case P_INT16:
                                  break;
                                case P_UINT16:
                                break;
                                case P_ULONG32:
                                break;
                                case P_FLOAT32:
                                break;
                                default:
                                  // do nothing
                               Serial.print(")");
                          barduinoB
                          barduinoB
                          barduino
                          @AWI
                          Very interesting and compacts, probably avoids the memory limitations on UNO.
                          Great feedback, thanks!
                            Hi Folks,
                            Cheers
                            A
                            A
                            akbooer
                            @barduino
                            Please excuse newness and ignorance (which go hand-in-hand.) Do I understand correctly that this sketch replaces a serial gateway? If so, what changes might be required to make this work for an ethernet gateway? Or, perhaps, do I have this all completely wrong?
                            I'm wanting to check out an ethernet connection between a Vera controller (or equivalent) and a Uno, on which I plan to run an internet gateway when I have built some sensors. Not yet having connected a radio, can I use this to mock up some sensors sending data to the Vera gateway plugin, just from an ethernet connected Uno?
                            Any help appreciated.
                            • A akbooer
                              @barduino
                              barduinoB
                              barduinoB
                              barduino
                              @akbooer
                              Hi, this sketch does not replace a gateway. It simulates a node with many sensors.
                              So its like having an arduino with 24 sensors connected to it (all fake, done by software) it still needs the gateway and radios, etc.
                              Some folks here in the forum have made experiences in creating sensors directly on a gateway, not sure if it is supported.
                              If so, it might be possible to Mock sensors in the gatway using such a technique...
                              Food for thought/investigation,
                              Cheers
                              • A
                                A
                                akbooer
                                OK and thanks for the quick response!
                                I knew I knew nothing.
                                So, just to be sure, I run this on an Arduino with a radio, but not sensors. This is going to talk to my Arduino gateway, with radio, and either serial or ethernet connection to the controller, whichever I choose.
                                • A akbooer
                                  barduinoB
                                  barduinoB
                                  barduino
                                  @akbooer
                                  That is correct.
                                  Also, because i'm having some issues updating the source code in git hub here is the latest version (lib 1.5) MockMySensors.ino and l(lib 1.4) FakeMySensorsOrig.ino
                                  Cheers
                                  • A
                                    A
                                    akbooer
                                    Thanks so much.
                                    • ch3b7C
                                      ch3b7C
                                      ch3b7
                                      wrote on last edited by ch3b7
                                      all sensors present good but when finish i get a loop sended:
                                      send: 50-50-0-0 s=0,c=1,t=16,pt=7,l=5,sg=0,st=ok:0.0
                                      im use (lib 1.5) MockMySensors.ino
                                      • ch3b7C ch3b7
                                        barduinoB
                                        barduinoB
                                        barduino
                                        @ch3b7
                                        Very interesting.
                                        I was not able to repruduce what you are describing above.
                                        According to your message we have:
                                        • Node 50 sending to node 0
                                        • Child sensor id 0
                                        • Message type 1 : SET
                                        • MessageSub Type 16: V_TRIPPED
                                        • Payload type 7: P_CUSTOM
                                        • Payload length 5
                                        Which is very strange.
                                        In MockMySensors there is no childid=0, the first sensor is #define ID_S_DOOR 1 and the node ID is set to 254 (but perhpas you have changed this)
                                        Also V_TRIPPED should be sending a bolean value...
                                        Could you upload your scetch?
                                        here is my log: SetUP
                                        send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                                        send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                        read: 0-0-254 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                        sensor started, id=254, parent=0, distance=1
                                        GW Started
                                        Send Sketch Info: send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,st=ok:MockMySensors
                                        send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=4,sg=0,st=ok:v0.3
                                        MockMySensors v0.3
                                        Get Config: Metric
                                        Presenting Nodes
                                        ________________
                                          S_DOOR
                                        send: 254-254-0-0 s=1,c=0,t=0,pt=0,l=0,sg=0,st=ok:
                                          S_MOTION
                                        send: 254-254-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,st=ok:
                                          S_SMOKE
                                        send: 254-254-0-0 s=3,c=0,t=2,pt=0,l=0,sg=0,st=ok:
                                          S_LIGHT
                                        send: 254-254-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                          S_DIMMER
                                        send: 254-254-0-0 s=5,c=0,t=4,pt=0,l=0,sg=0,st=ok:
                                          S_COVER
                                        send: 254-254-0-0 s=6,c=0,t=5,pt=0,l=0,sg=0,st=ok:
                                          S_TMEP
                                        send: 254-254-0-0 s=7,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                          S_HUM
                                        send: 254-254-0-0 s=8,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                                          S_BARO
                                        send: 254-254-0-0 s=9,c=0,t=8,pt=0,l=0,sg=0,st=ok:
                                          S_WIND
                                        send: 254-254-0-0 s=10,c=0,t=9,pt=0,l=0,sg=0,st=ok:
                                          S_RAIN
                                        send: 254-254-0-0 s=11,c=0,t=10,pt=0,l=0,sg=0,st=ok:
                                          S_UV
                                        send: 254-254-0-0 s=12,c=0,t=11,pt=0,l=0,sg=0,st=ok:
                                          S_WEIGHT
                                        send: 254-254-0-0 s=13,c=0,t=12,pt=0,l=0,sg=0,st=ok:
                                          S_POWER
                                        send: 254-254-0-0 s=14,c=0,t=13,pt=0,l=0,sg=0,st=ok:
                                          S_DISTANCE
                                        send: 254-254-0-0 s=16,c=0,t=15,pt=0,l=0,sg=0,st=ok:
                                          S_LIGHT_LEVEL
                                        send: 254-254-0-0 s=17,c=0,t=16,pt=0,l=0,sg=0,st=ok:
                                          S_LOCK
                                        send: 254-254-0-0 s=18,c=0,t=19,pt=0,l=0,sg=0,st=ok:
                                          S_IR
                                        send: 254-254-0-0 s=19,c=0,t=20,pt=0,l=0,sg=0,st=ok:
                                          S_WATER
                                        send: 254-254-0-0 s=20,c=0,t=21,pt=0,l=0,sg=0,st=ok:
                                          S_AIR_QUALITY
                                        send: 254-254-0-0 s=21,c=0,t=22,pt=0,l=0,sg=0,st=ok:
                                          S_SCENE_CONTROLLER
                                        send: 254-254-0-0 s=23,c=0,t=25,pt=0,l=0,sg=0,st=ok:
                                          S_CUSTOM
                                        send: 254-254-0-0 s=24,c=0,t=23,pt=0,l=0,sg=0,st=ok:
                                        ________________
                                        And the loop section
                                        RandomNumber:76
                                        Send Battery Level
                                        send: 254-254-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:76
                                        Request Time
                                        send: 254-254-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-254 s=255,c=3,t=1,pt=0,l=10,sg=0:1439720967
                                        Time value received: 1439720967
                                        Motion is: Quiet
                                        send: 254-254-0-0 s=2,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
                                        Smoke is: Quiet
                                        send: 254-254-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
                                        Light is: On
                                        send: 254-254-0-0 s=4,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
                                        Dimmer is set to: 255
                                        send: 254-254-0-0 s=5,c=1,t=3,pt=2,l=2,sg=0,st=ok:255
                                        Cover is : Idle
                                        send: 254-254-0-0 s=6,c=1,t=31,pt=2,l=2,sg=0,st=ok:31
                                        Temperature is: 34
                                        send: 254-254-0-0 s=7,c=1,t=0,pt=4,l=4,sg=0,st=ok:34
                                        Humitidty is: 76
                                        send: 254-254-0-0 s=8,c=1,t=1,pt=4,l=4,sg=0,st=ok:76
                                        Atmosferic Pressure is: 103363
                                        send: 254-254-0-0 s=9,c=1,t=4,pt=4,l=4,sg=0,st=ok:103363
                                        Weather forecast: unstable
                                        send: 254-254-0-0 s=9,c=1,t=5,pt=0,l=8,sg=0,st=ok:unstable
                                        Wind Speed is: 76
                                        send: 254-254-0-0 s=10,c=1,t=8,pt=4,l=4,sg=0,st=ok:76
                                        Wind Gust is: 86
                                        send: 254-254-0-0 s=10,c=1,t=9,pt=4,l=4,sg=0,st=ok:86
                                        Wind Direction is: 272
                                        send: 254-254-0-0 s=10,c=1,t=10,pt=4,l=4,sg=0,st=ok:272
                                        Rain ammount  is: 76
                                        send: 254-254-0-0 s=11,c=1,t=6,pt=4,l=4,sg=0,st=ok:76
                                        Rain rate  is: 1
                                        send: 254-254-0-0 s=11,c=1,t=7,pt=7,l=5,sg=0,st=ok:1.0
                                        Ultra Violet level is: 11
                                        send: 254-254-0-0 s=12,c=1,t=11,pt=4,l=4,sg=0,st=ok:11
                                        Weight is: 113
                                        send: 254-254-0-0 s=13,c=1,t=12,pt=4,l=4,sg=0,st=ok:113
                                        Impedance is: 113
                                        send: 254-254-0-0 s=14,c=1,t=14,pt=4,l=4,sg=0,st=ok:113
                                        Watt is: 113
                                        send: 254-254-0-0 s=14,c=1,t=17,pt=4,l=4,sg=0,st=ok:113
                                        KWH is: 113
                                        send: 254-254-0-0 s=14,c=1,t=18,pt=4,l=4,sg=0,st=ok:113
                                        Voltage is: 113
                                        send: 254-254-0-0 s=14,c=1,t=38,pt=4,l=4,sg=0,st=ok:113
                                        Current is: 113
                                        send: 254-254-0-0 s=14,c=1,t=39,pt=4,l=4,sg=0,st=ok:113
                                        Distance is: 113
                                        send: 254-254-0-0 s=16,c=1,t=13,pt=4,l=4,sg=0,st=ok:113
                                        Light is: 113
                                        send: 254-254-0-0 s=17,c=1,t=23,pt=4,l=4,sg=0,st=ok:113
                                        Lock is: On
                                        send: 254-254-0-0 s=18,c=1,t=36,pt=2,l=2,sg=0,st=ok:1
                                        Infrared is: 255
                                        send: 254-254-0-0 s=19,c=1,t=32,pt=2,l=2,sg=0,st=ok:255
                                        Water flow is: 113
                                        send: 254-254-0-0 s=20,c=1,t=34,pt=4,l=4,sg=0,st=ok:113
                                        Water volume is: 113
                                        send: 254-254-0-0 s=20,c=1,t=35,pt=4,l=4,sg=0,st=ok:113
                                        Air Quality is: 76
                                        send: 254-254-0-0 s=21,c=1,t=24,pt=4,l=4,sg=0,st=ok:76
                                        Scene is: On
                                        send: 254-254-0-0 s=23,c=1,t=19,pt=2,l=2,sg=0,st=ok:1
                                        Custom value is: 76
                                        send: 254-254-0-0 s=24,c=1,t=25,pt=4,l=4,sg=0,st=ok:76
                                        send: 254-254-0-0 s=24,c=1,t=26,pt=4,l=4,sg=0,st=ok:76
                                        send: 254-254-0-0 s=24,c=1,t=27,pt=4,l=4,sg=0,st=ok:76
                                        send: 254-254-0-0 s=24,c=1,t=28,pt=4,l=4,sg=0,st=ok:76
                                        ch3b7C 1 Reply Last reply
                                          @ch3b7
                                          Very interesting.
                                          • Child sensor id 0
                                          • Payload length 5
                                          GW Started
                                          MockMySensors v0.3
                                          Get Config: Metric
                                          Presenting Nodes
                                          ________________
                                            S_DOOR
                                            S_MOTION
                                            S_SMOKE
                                            S_LIGHT
                                            S_DIMMER
                                            S_COVER
                                            S_TMEP
                                            S_HUM
                                            S_BARO
                                            S_WIND
                                            S_RAIN
                                            S_UV
                                            S_WEIGHT
                                            S_POWER
                                            S_DISTANCE
                                            S_LIGHT_LEVEL
                                            S_LOCK
                                            S_IR
                                            S_WATER
                                            S_AIR_QUALITY
                                            S_SCENE_CONTROLLER
                                            S_CUSTOM
                                          ________________
                                          RandomNumber:76
                                          Send Battery Level
                                          Request Time
                                          Motion is: Quiet
                                          Smoke is: Quiet
                                          Light is: On
                                          Cover is : Idle
                                          Temperature is: 34
                                          Humitidty is: 76
                                          Wind Speed is: 76
                                          Wind Gust is: 86
                                          Rain ammount  is: 76
                                          Rain rate  is: 1
                                          Weight is: 113
                                          Impedance is: 113
                                          Watt is: 113
                                          KWH is: 113
                                          Voltage is: 113
                                          Current is: 113
                                          Distance is: 113
                                          Light is: 113
                                          Lock is: On
                                          Infrared is: 255
                                          Water flow is: 113
                                          Air Quality is: 76
                                          Scene is: On
                                          Custom value is: 76
                                          ch3b7C
                                          ch3b7C
                                          ch3b7
                                          @barduino
                                          sorry your sketch work good! the problem im have is with the @AWI example!
                                          @AWI
