  3. In wall - PCB, (AC to DC 5v)
pcbinwall
89 Posts 14 Posters 78.5k Views 24 Watching
  • sundberg84S
    This post is archived!
    Please use this thread to post questions:
    https://forum.mysensors.org/topic/2783/in-wall-ac-dc-pcb-for-mysensors
    Project can be found here:
    https://www.openhardware.io/view/13/In-Wall-ACDC-Pcb-for-MySensors
    Hi!
    As i mentioned in another post i had this idea to stack two PCB on top of each other to fit inside a wall appliance box. This idea has evolved (see below).
    Im aware of the big security risk here, and have tried to read:
    • http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
    • http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board
    EDIT 03/1/2016
    After discussion on this here are the findings of this thread (as of now):
    I will update this post with BOM and eagles files as soon as i get a node running.
    BOM/README: http://1drv.ms/1kCzue5
    GERBER: InWallMySensor3.0.rar
    EAGLES: InWallMySensor3.0Eagles.rar
    Build images: http://1drv.ms/1lsleox
    If you are using this design, please know about the risks when you work with high power. This design has no guarantee s so use it on your own risk!
    m26872M B 2 Replies Last reply
    • S
      Samuel235
      This looks a fantastic step in the right direction for where this development should/could go, well i think so anyway. I can't make any comments on the actual circuitry of this project, however like i said, i think its an awesome leap in the development for MySensors and the possibilities it brings to the avid home user that was out of the box solutions. Keep up the appreciated work.
      MySensors 2.1.1
      • ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        Good step. Is there any 3d pictures ?
        The nrf is pointed upward. Won't it be outside the 2.5x5 space ?
        • sundberg84S
          No 3D pictures, I dont know how to make that - but ill see if i can learn.
          Yea, the nrf is outside to dont block the radio waves... it might be a litte to much, I will make some more measurments:
          • S
            Samuel235
            Do we know if the radio signals will get distorded or blocked in any way if installed into a metal/galvenised socket box? I'm really interested in something like this for the 'standard' style lightswitches i'm making at the moment.
            MySensors 2.1.1
            ahmedadelhosniA 1 Reply Last reply
            • S Samuel235
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              @samuel235 You can test and monitor the performance. Watch also this antenna modification by @petewill https://www.youtube.com/watch?v=NpMnauHeR7Y
              S 1 Reply Last reply
              • ahmedadelhosniA ahmedadelhosni
                Samuel235
                @ahmedadelhosni I have seen how you can increase the signal reading capabilities, i was just wondering if the steel backbox would affect the rate at which the signal came into the radio with it being inside of the metal box.
                MySensors 2.1.1
                • sundberg84S
                  @samuel235 Probably! I had this problem when i had the radion in between two pcb a while ago. Relocating the radio changed the effect on it so I think there might be problem if ju isolate the radio with metal.
                  • sundberg84S sundberg84
                    Hi!
                    EDIT 03/1/2016
                    m26872M
                    m26872M
                    m26872
                    @sundberg84 I don't like the creepage distance to those display-pins in the middle of the relay footprint. It looks like there's plenty of space to move it, eg beneath "sensors". Also due to the EMI-risk from relay switch.
                    Maybe you also want increase the width and solder-mask the middle of the relay high power traces.
                    The panelizing holes will probably be hard to break without damage to the pads. At least try to move them closer together.
                    • S
                      Samuel235
                      So, i need to test my module inside of a metal backbox then, and if it receives interference we could do with coming up for a solution because most of the 'older' UK Style houses that i work within use metal back boxes. So if we could come up with a work around, it would broaden the possible audience.
                      MySensors 2.1.1
                      • sundberg84S
                        @samuel235 I would have tried to attach the radio with jumper wires and put the radio outside the metal box somehow.
                        • S
                          Samuel235
                          That would be incredibly difficult to do if you're using a metal box purely for the reason of having no room between the brick and the plasterboard (Or whatever finished product you use over where you live).
                          MySensors 2.1.1
                          petewillP 1 Reply Last reply
                          • S Samuel235
                            petewillP
                            petewillP
                            petewill
                            @samuel235 You will probably have to face the radio so it's pointing through the plastic cover (not the metal box) and use repeaters in the rooms where necessary.
                            • petewillP petewill
                              Samuel235
                              @petewill I shall give this a test! I'll report back soon, hopefully.
                              MySensors 2.1.1
                              • bjacobseB
                                bjacobseB
                                bjacobse
                                Looks great, will you consider to create a version with 2 relays so it will be similar like the Fibaro 2 relay or Qubino 2 relay
                                I also live in Sweden (Using same wall mechanical dimensions) and are searching exactly for a Mysensor relay 2 device to hide in the wall
                                link to Fibaro 2 Relay zwave device
                                • sundberg84S
                                  @bjacobse My thought was to first create one working pcb to start with and leave the upper side for sensors.
                                  This way you can recreate that upper pcb for the needs you have and just add it as a shield to the lower pcb.
                                  • scalzS
                                    scalzS
                                    @sundberg84: hi nice idea :smiley:
                                    just for curiosity, what does "sweden" box look like??? I live in France, and here the most common style/size is like this: http://www.leroymerlin.fr/v3/p/produits/boite-d-encastrement-legrand-pour-mur-creux-d-67-mm-e29984
                                    is it like yours??
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      This is what I have in my walls and these in the roof in a house in Finland. I bet they are similar in Sweden.
                                      • Tomas
                                      • scalzS
                                        scalzS
                                        wrote on last edited by scalz
                                        thx :smile:
                                        it seems you have good quality/strong box :wink: not cheap, a little bit bigger than ours. interesting to see difference. so in future, if I will make something inwall for me, it will fit to "nordic" box. cool. unfortunately maybe not the holes...I will check this. but it's not a big problem I think. good to know.
                                        • sundberg84S
                                          Yea. Mine is about d =6,5 mm as well. Reminds of yours.
