Motion/Relay sensor sketch help
  • Hi
    This is my attempt do merge the motion and relay actuator sketch.
    It's working, but I had tp put in some delays, so I didn't get flooded with log updates.
    The goal with this is to have the arduino mini pro control a PiR and a 2 channel relay. The PiR should trigger relay_1 and my controller should be in control over relay_2.
    It, to my BIG supprise, actually work! But I don't think that the code is no way near optimal! So what I would like, is some optimization hits/examples.
    Here's the sketch:
     // Example sketch showing how to control physical relays.
     // This example will remember relay state even after power failure.
     #define RELAY_1 6  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
     // Motion sensor defs
     unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds)
     #define CHILD_ID 3   // Id of the sensor child
       gw.sendSketchInfo("Relay/Motion Sensor", "1.0");
       // Fetch relay status
         gw.present(sensor, S_LIGHT);
         pinMode(pin, OUTPUT);
         digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
       gw.present(CHILD_ID, S_MOTION);
       gw.process();
       // Read digital motion value
       if (digitalRead(DIGITAL_INPUT_SENSOR) == HIGH) {
         Serial.println(tripped);
         gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
         //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
         digitalWrite(RELAY_1, 1);
         delay(5000);
       } else {
         digitalWrite(RELAY_1, 0);
         boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == LOW;
         delay(5000);
       if (message.type==V_LIGHT) {
          // Change relay state
          // Store state in eeprom
          // Write some debug info
          Serial.print(message.sensor);
  • Hero Member
    Hi @Hausner
    I've a multisensor sketch. I havent tied my relay to any action of the PIR - as i may not want it to do any action unless Vera has instructed it to do so... ie: if the relay was to turn on a light on detected movement, i'd only want that to occur at night, or if the security system was armed etc...
    Anyway sketch is here:
    https://codebender.cc/sketch:61919
  • Contest Winner
    @Hausner
    something like this:
    (compiled but not tested)
    #define RELAY_2 7
    //#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    boolean lastTrippedState;
    MyMessage msgRelay2(2, V_LIGHT);
    MyMessage msgMotion(3, V_TRIPPED);
      gw.present(1, S_LIGHT);
      pinMode(RELAY_1, OUTPUT);
      gw.present(2, S_LIGHT);
      pinMode(RELAY_2, OUTPUT);
      digitalWrite(RELAY_2, gw.loadState(1)? RELAY_ON : RELAY_OFF);
      gw.process();
      if (tripped != lastTrippedState)
        Serial.println(tripped? "tripped" : "not tripped");
        gw.send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw//
        digitalWrite(RELAY_1, tripped? 1 : 0);
      lastTrippedState = tripped;
      if (message.type==V_LIGHT && message.sensor == 2)
        digitalWrite(RELAY_2, message.getBool()?RELAY_ON:RELAY_OFF);
  • Hello everyone, I am using this code for my bathroom but I added a sensor, This latter allows me to know if there is a flood in my absence and through ver4-domoticz allows me to set an alarm, this code goes in my opinion correct
    https://codebender.cc/sketch:209969
  • recapping sensor h2o 2 relays 2 buttons I used this code to optimize the water heater in the bathroom and detect water on the floor
    the dish is ready
    https://codebender.cc/sketch:210051
  • @Michel---It Hi, im quite a beginner but found your sketch interesting. Anyway i cannot compile it from the compile function in your post nor in my arduino ide. it seems somethinf releated the old library used but i cannot find the right one to use. Can you help me ?
    thanks
  • Mod
    @Marco-MicrOchip-Acquadro the sketch above is for MySensors 1.x, so it won't work with MySensors 2.x.
    Converting a sketch is possible, but requires some work. Instructions are available at https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x/
  • @mfalkvidd thank you for your Quick reply . I need to improve my knowledge of coding ... hope to success in this porting anyway.
  • Mod
    @Marco-MicrOchip-Acquadro Great. Maybe the relay example with button can help you get started. It works with MySensors 2.x.
  • 1
  • 198
  • 1
  • 10
  • 5
