  3. Indigo Domotics
  4. Plugin for Indigo for Mac
Scheduled Pinned Locked Moved Indigo Domotics
28 Posts 3 Posters 12.6k Views 2 Watching
  • marceltrapmanM Offline
    marceltrapman
    Only a few weeks ago I installed camera's in and around our house.
    One thing lead to another and a couple of z-wave sensors/switches magically arrived in the same box ;)
    After installing all these goodies and making all this work using SecuritySpy and Indigo (www.perceptiveautomation.com) I found this website.
    My project will involve creating an Indigo plugin as soon as my Arduino Pro Mini's, radio's etc arrive.
    I should have seen them arriving already, instead my battery holders have arrived last week...
    Anyway, wish me luck since all this is quite new to me...
    Cheers,
    Marcel
    Fulltime Servoy Developer
    • hekH Offline
      hekH Offline
      Great Marcel,
      Let us know if you need help to interpret the API.
        marceltrapman
        So, I have my Gateway up and one Temperature sensor.
        The plugin only reads at this point so I fixed the sensor id to 10.
        This is what I receive but I can't make much of it yet.
        Is this ok (I am not sure, looking at the API I would say not really) ?
        0;0;4;11;Message available on pipe 1
        0;0;4;11;Sent ack msg to 10
        0;0;4;11;Rx: fr=10,to=0,la=10,ci=255,mt=4,t=13,cr=13(ok):
        10;255;4;13;
        • W Offline
          W Offline
          wannabee
          10;255;4;13; is the interesting part. The messages above is network debug message.
          10 - is the Raido ID
          255 - is the Node, see it as the arduino without the sensors.
          4 - means internal message type. It’s used to send messages between an intelligent controller and the network. i.e vera or what you are about to write.
          13 - is the subtype of the internal message in this case I_UNIT.
          So what your arduino is doing is requesting the unit type for your sensor network. It’s ethier M as in Metric or I as in imperial.
          The arduino except to get a answer back telling it either
          10;255;4;13;M or 10;255;4;13;I
          This is the call in the arduino requesting what metric system to use.
          metric = gw.isMetricSystem();
          All types are explained at http://www.mysensors.org/build/sensor_api
          What you want to do is port most of the functions in https://github.com/mysensors/Vera/blob/master/L_Arduino.lua
          and build some yourself since the Vera is doing some part that you don’t know about. Keeping track of some information.
          You can see my python project (still without a name) at https://github.com/wbcode/ham where you can steel, borow, push or fork ideas/code to/from.
          WB
            marceltrapman
            @wannabee Thanks, will play with this tomorrow. Looks good :)
            W 1 Reply Last reply
              marceltrapman
              @wannabee good stuff! I learn(ed) a lot from it because I am a novice in Python.
              And it also made me even better understand what, how and when to communicate between controller, gateway and sensor.
              I managed to set the id and collect the temperature of a sensor using the beginning of my plugin.
              Now I can start building :)
                marceltrapman
                Oh, question: After sending the ID to a sensor will the sensor store it 'permanently'?
                hekH W 2 Replies Last reply
                • marceltrapmanM marceltrapman
                  hekH Offline
                  hekH Offline
                  @marceltrapman
                  Yes (it saves it to the EEPROM).
                    W Offline
                    W Offline
                    wannabee
                    @marceltrapman Glad it was helpful, Tricky part is to develop something that sends information into the network from outside. ie when you want to turn a switch on or off.
                      W Offline
                      W Offline
                      wannabee
                      @marceltrapman and you clear the eeprom by uploading https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/ClearEepromConfig/ClearEepromConfig.ino.
                        marceltrapman
                        Nice @wannabee
                        Three other questions:
                        1. Am I correct that an Arduino board/node always presents itself and its children upon inclusion (after startup) ?
                        2. I do not see a way to set the child id so assume this is set by the Arduino board/node itself?
                        3. Is there a way to 'manually' ask for all available Arduino boards/nodes and/or sensors available through the gateway?
                        In other words: "I like this" :)
                          Nice @wannabee
                          W Offline
                          W Offline
                          wannabee
                          wrote on last edited by wannabee
                          1 For every sensor on a board you send:
                          gw.sendSensorPresentation(<sensor_child_id>,<sensor_type_id>);
                          2 the sensor_child_id is set by the board.
                          Ie.
                          #define CHILD_ID_HUM 0
                          #define CHILD_ID_TEMP 1
                          And then later:
                          gw.sendSensorPresentation(CHILD_ID_HUM, S_HUM);
                          gw.sendSensorPresentation(CHILD_ID_TEMP, S_TEMP);
                          In the HumiditySensor.ino
                          3 Here @hek have to correct me. The answer is maybe, if you dig deep in the routing table in the gateway. But the gateway will lose that info when rebooted. It would also be possible to send a broadcast to all nodes asking them for info, but in that case you have to implement a function in the nodes that answers on broadcast. It will also make them not sleep. I keep track of available sensors in the python code. It’s the same way the vera is doing it. You basicly stores all sensors that have sent a presentation.
                          • hekH Offline
                            hekH Offline
                            Currently, no, The routing table exists in gateway (and is not lost when rebooting). But it only contains information about were to send messages for a certain radioId (realy or direct route). Not what type of sensor(s) that each node has attached. Unfortunately the Arduino is a bit limited on how much data we can store in the EEPROM.
                              marceltrapman
                              wrote on last edited by marceltrapman
                              @wannabee @hek
                              Both your answers have helped me a lot! Thanks a million!!!
                              My 'issue' was that I was trying to do all the fancy stuff from the Controller (Indigo, or better my plugin, in this case) but obviously the sensor can be set to be active as well :)
                              I have made great progress today thanks to you guys...
                                marceltrapman
                                For the fun of it!
                                Screen Shot 2014-04-29 at 21.42.13.png Screen Shot 2014-04-29 at 21.42.40.png Screen Shot 2014-04-29 at 21.42.58.png
                                • hekH Offline
                                  hekH Offline
                                  Cool! Great work!
                                    marceltrapman
                                    Thanks, while looking at my screenshots again I also found a little mistake :)
                                      marceltrapman
                                      Here you see the full power of Indigo.
                                      I added 2 relays to the existing temperature sensor.
                                      In fact a created a custom multi sensor.
                                      This is what it looks like in Indigo.
                                      I will make it so that when a device will be updated or added all sensors are included :)
                                        marceltrapman
                                        I am happy, the plugin is not ready but I moved it to my Indigo Server and it is now in production :)
                                        What am I using it for right now?
                                        The temperature sensor shows the temperature in a computer cabinet.
                                        Based on the temperature a fan is enabled/disabled to lower the temperature.
                                        For that I added the board with attached sensors and I created triggers.
                                        Here it is:...
                                        Screen Shot 2014-05-06 at 22.11.48.png Screen Shot 2014-05-06 at 22.12.13.png Screen Shot 2014-05-06 at 22.12.17.png
                                          marceltrapman
                                          Added the source to github: https://github.com/IT2BE/indigo-mysensors
                                          Please beware: the plugin is not ready. I have a few sensors working but I am awaiting my mini pro's to be delivered before I can move ahead.
                                          In the meantime I will polish things as I am also getting ready to go on vacation in about 10 days :)
                                          11.8k
                                          113.2k
