  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 372.3k Views 73 Watching
  • tekkaT Offline
    tekkaT Offline
    tekka
    wrote on last edited by tekka
    Hi all,
    I've been working on this project since some time, basically it's a GUI for controlling/updating/debugging a network of MySensors nodes. OTA functionality is supported via MYSBootloader - read posts for further instructions/troubleshooting or PM.
    link updated: MYSController Version 1.0.0.3316 released
    New features:
    • support OTA FW update Sensebender board
    • metric/imperial system I_CONFIG
    • save nodes
    Update via update button in MYSController or download here.
    JohnJ N DomoJimboD jmkhaelJ M 6 Replies Last reply
    • tekkaT tekka
      Hi all,
      New features:
      • save nodes
      JohnJ Offline
      JohnJ Offline
      John
      wrote on last edited by John
      @tekka
      This is very, very cool! It connects to Ethernet or does it also do serial?
      • tekkaT Offline
        tekkaT Offline
        tekka
        both. in my setup i'm using a serial over tcp approach (NAS: serial gateway & ser2net)- fw loading is substantially faster and more stable compared to the ethernet gateway.
        JohnJ 1 Reply Last reply
        • tekkaT tekka
          JohnJ Offline
          JohnJ Offline
          John
          @tekka
          Very nice approach, this could also work on other boxes where serial interfaces are not exclusively opened.
          • E Offline
            E Offline
            ericvdb
            @tekka
            You plan to share this, or provide the sources?
            It looks indeed verry nice ;)
            • ch3b7C Offline
              ch3b7C Offline
              ch3b7
              Good work man! im make a controller in .net!
              http://clip2net.com/s/3aGJdvY
              • tekkaT Offline
                tekkaT Offline
                tekka
                @ericvdb yes, I will provide a link soon
                @ch3b7 cool :+1: , are you also implementing tcp connections?
                • ch3b7C Offline
                  ch3b7C Offline
                  ch3b7
                  yes but at now im not have a ethernet shield right now =( and i need to work with the optiboot/OTA bootloader part and dont know where find that part "request" "send" all that info. sorry my bad english im from argentina.!
                  • daulagariD Offline
                    daulagariD Offline
                    daulagari
                    Yes, looks really nice!
                    Seems to be written in TK so cross-platform, even better!
                    • greglG Offline
                      greglG Offline
                      gregl
                      Wow...really nice. Cant wait to give it a go!
                      • D Offline
                        diamantmatch
                        wow, this is something!
                        would really love to set this up at home!
                        i also can't wait for your link to appear, really exited !
                        • T Offline
                          T Offline
                          Tibus
                          Yeah, really looks nice!
                          Can't wait too for the link and more info about de OTA bootloader.
                          I'm making some industrial opensources sensor based on MySensor and my current bootloader don't have an OTA Bootloader. So it would be greate with your Bootloader and your application!
                          • P Offline
                            P Offline
                            p0lar
                            Nice.... Following
                            • J Offline
                              J Offline
                              jribera
                              This looks very interesting. Seems like it will make remote debugging easy, ie can run this on a PC at home and RDP into it.
                              • C Offline
                                C Offline
                                chris021
                                Also Following. Very keen to try this!
                                • RJ_MakeR Offline
                                  RJ_MakeR Offline
                                  RJ_Make
                                  Will this program act like a controller (take the place of Vera?) and handle automation logic?
                                  RJ_Make
                                  • tekkaT Offline
                                    tekkaT Offline
                                    tekka
                                    hi all,
                                    here is the first alpha version of the MYSController (I changed the name).
                                    http://goo.gl/9DCWNo
                                    There are still lots of things that need to be done and some bugs :), but feel free to give it a try. I included the modified bootloader (flash according to the settings in the fuses.txt file) and two example .hexs for testing/uploading. From my experience, the OTA works better/faster using the serial gateway.
                                    Cheers,
                                    tekka
                                    • C Offline
                                      C Offline
                                      chris021
                                      Got it working first try! Can see data coming back from my Temp and Hum sensors!
                                      Looks like a great tool.
                                      Thank you!
                                        daulagariD Offline
                                        daulagari
                                        @tekka
                                        :+1:
                                        Saw it was a Windows executable but did give it a try on Linux:
                                        wine MYSController.exe
                                        And the GUI comes up nicely!
                                        I can not select the serial port yet, so could not test it further, likely have to do some mapping in wine.
                                        • hekH Offline
                                          hekH Offline
                                          wrote on last edited by hek
                                          Yepp.. GUI comes up on mac using wine as well. Will try tomorrow when I have an Arduino nearby.
                                          11.8k
                                          113.2k
