<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[switch does not work]]></title><description><![CDATA[<p dir="auto">I do not know how to explain my problem, since home assistant does not work the swich, I detect the states, since google assistant through home assistant works very well, but if I click on home assistant there is no way to turn on a light.</p>
<pre><code>mysensors:
  gateways:
    - device: !secret ip_local
      persistence_file: '/home/pi/.homeassistant/mysensors3.json'
      tcp_port: 5003
  optimistic: false
  persistence: true
  #retain: true
  version: '2.0'
</code></pre>
<p dir="auto">I'm desperate, in domoticz it works perfect</p>
]]></description><link>https://forum.mysensors.org/topic/10106/switch-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 23:48:55 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10106.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Jan 2019 07:19:34 GMT</pubDate><ttl>60</ttl></channel></rss>
