<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Combine several scetches to 1 node]]></title><description><![CDATA[<p dir="auto">Hi<br />
I am having trouble combining multiple scetches into one node since the last mysensors library update.<br />
I have combined the DHT and RELAY scetches and they work great. I just want to add an interrupt sensor (door, motion, whatever) to pin 3.<br />
I think the problem is the sleep function. it is different in all 3 scetches, i am an absolute NOOB with programming, but simply cut/paste is not working anymore.</p>
<p dir="auto">Can somebody please be of any assistance? You would save the day! thanks!</p>
<pre><code>#define MY_DEBUG
#define MY_REPEATER_FEATURE
#include &lt;SPI.h&gt;
#include &lt;MySensors.h&gt;
#include &lt;DHT.h&gt;
#define CHILD_ID_HUM 3
#define CHILD_ID_TEMP 4
#define DHT_DATA_PIN 8
#define SENSOR_TEMP_OFFSET 0
#define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
float lastTemp;
float lastHum;
uint8_t nNoUpdatesTemp;
uint8_t nNoUpdatesHum;
bool metric = true;
DHT dht;
void before()
  for (int sensor = 1, pin = RELAY_PIN; sensor &lt;= NUMBER_OF_RELAYS; sensor++, pin++) {
    pinMode(pin, OUTPUT);
    digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
  sendSketchInfo("DHT &amp; Relays", "2.0");
  present(CHILD_ID_HUM, S_HUM);
    present(sensor, S_BINARY);
  dht.readSensor(true);
  if (isnan(temperature)) {
    lastTemp = temperature;
    // apply the offset before converting to something different than Celsius degrees
    if (!metric) {
    // Reset no updates counter
    nNoUpdatesTemp = 0;
#ifdef MY_DEBUG
    Serial.print("T: ");
    Serial.println(temperature);
  } else {
    nNoUpdatesTemp++;
  if (isnan(humidity)) {
    lastHum = humidity;
    nNoUpdatesHum = 0;
#ifdef MY_DEBUG
    Serial.print("H: ");
    Serial.println(humidity);
  } else {
    nNoUpdatesHum++;
  sleep(UPDATE_INTERVAL);
void receive(const MyMessage &amp;message)
    // Change relay state
    digitalWrite(message.sensor - 1 + RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
    // Store state in eeprom
    // Write some debug info
    Serial.print(message.sensor);
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/10125/combine-several-scetches-to-1-node</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 07:53:40 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10125.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 26 Jan 2019 10:58:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Combine several scetches to 1 node on Mon, 28 Jan 2019 19:34:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xypzo" aria-label="Profile: xypzo">@<bdi>xypzo</bdi></a> &gt; One thing, the interrupt (motion) status is only sent when the other data (temp hum) is being send. So once a minute it jumps from "on" to "off" in stead of every time the Sensor goes HI/LO.</p>
<blockquote>
<p dir="auto">Is there a way to fix that?</p>
</blockquote>
<p dir="auto">Don't sleep the node. It won't be able to receive messages during it's sleep anyway so incomming messages will be lost as well.</p>
]]></description><link>https://forum.mysensors.org/post/97014</link><guid isPermaLink="true">https://forum.mysensors.org/post/97014</guid><dc:creator><![CDATA[skywatch]]></dc:creator><pubDate>Mon, 28 Jan 2019 19:34:12 GMT</pubDate></item><item><title><![CDATA[Reply to Combine several scetches to 1 node on Sun, 27 Jan 2019 12:28:56 GMT]]></title><description><![CDATA[<p dir="auto">IT WORKS, thank you very much!<br />
One thing, the interrupt (motion) status is only sent when the other data (temp hum) is being send. So once a minute it jumps from "on" to "off" in stead of every time the Sensor goes HI/LO.<br />
Is there a way to fix that?<br />
Thanks again, you are a HERO</p>
]]></description><link>https://forum.mysensors.org/post/96976</link><guid isPermaLink="true">https://forum.mysensors.org/post/96976</guid><dc:creator><![CDATA[xypzo]]></dc:creator><pubDate>Sun, 27 Jan 2019 12:28:56 GMT</pubDate></item><item><title><![CDATA[Reply to Combine several scetches to 1 node on Sat, 26 Jan 2019 13:05:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xypzo" aria-label="Profile: xypzo">@<bdi>xypzo</bdi></a> said in <a href="/post/96955">Combine several scetches to 1 node</a>:</p>
<p dir="auto">This should do it - It compiles but I cannot test it, so that is down to you!</p>
#define DIGITAL_INPUT_SENSOR 3
#define CHILD_ID 1
float lastTemp;
float lastHum;
bool metric = true;
DHT dht;
void before()
    pinMode(DIGITAL_INPUT_SENSOR, INPUT);
   digitalWrite(DIGITAL_INPUT_SENSOR, HIGH);
  present(CHILD_ID, S_DOOR);
    if (!metric) {
    nNoUpdatesTemp = 0;
#ifdef MY_DEBUG
  } else {
    nNoUpdatesTemp++;
    lastHum = humidity;
    nNoUpdatesHum = 0;
#ifdef MY_DEBUG
  } else {
    nNoUpdatesHum++;
bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
    send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
    sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, UPDATE_INTERVAL);
  //sleep(UPDATE_INTERVAL);
</code></pre>
<p dir="auto">I am not sure it is possible for the node to receive a message when it is asleep?</p>
]]></description><link>https://forum.mysensors.org/post/96956</link><guid isPermaLink="true">https://forum.mysensors.org/post/96956</guid><dc:creator><![CDATA[skywatch]]></dc:creator><pubDate>Sat, 26 Jan 2019 13:05:11 GMT</pubDate></item></channel></rss>
