<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RS485 Gatway with relay and DS18B20 sensors]]></title><description><![CDATA[<p dir="auto">Hello.<br />
I built a MySensor. It has 4 relays and 4 temperature sensors.</p>
<pre><code>/**
   The MySensors Arduino library handles the wireless radio link and protocol
   between your home built sensors/actuators and HA controller of choice.
   The sensors forms a self healing radio network with optional repeaters. Each
   repeater and gateway builds a routing tables in EEPROM which keeps track of the
   network topology allowing messages to be routed to nodes.
   Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
   Copyright (C) 2013-2015 Sensnology AB
   Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
   Documentation: http://www.mysensors.org
   Support Forum: http://forum.mysensors.org
   This program is free software; you can redistribute it and/or
   modify it under the terms of the GNU General Public License
   version 2 as published by the Free Software Foundation.
   DESCRIPTION
   Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
   http://www.mysensors.org/build/temp
   Enhanced Version to keep ChildIDs fix based on petewill's http://forum.mysensors.org/topic/2607/video-how-to-monitor-your-refrigerator.
  - Present Dallas-Hardware-ID as comment
//#define MY_DEBUG
// Enable to print out an array of the attached DallasSensors to Serial
// comment this after initial setup and adopt MAX_ATTACHED_DS18B20 accordingly
//#define PRINT_ARRAY
#define MY_RS485
// Define this to enables DE-pin management on defined pin
#define MY_RS485_DE_PIN 2
// Set RS485 baud rate to use
#define MY_RS485_BAUD_RATE 9600 //19200
// Enable this if RS485 is connected to a hardware serial port
//#define MY_RS485_HWSERIAL Serial1
// Enable serial gateway
//#define MY_GATEWAY_SERIAL
#define MY_NODE_ID 10
#define SN "Heizung_OG"
#define SV "1.0"
//#include &lt;SPI.h&gt;
#include &lt;MySensors.h&gt;
#include &lt;DallasTemperature.h&gt;
#include &lt;OneWire.h&gt;
//Parameter für 1-wire DS18B20
//#define COMPARE_TEMP 1 // Send temperature only if changed?
#define ERASE_HASH // Clear EEPROM, if no 1w-device is present?
#define MAX_ATTACHED_DS18B20 4
uint8_t DS_First_Child_ID = 1; //First Child-ID to be used by Dallas Bus; set this to be higher than other Child-ID's who need EEPROM storage to avoid conflicts
DallasTemperature sensors(&amp;oneWire); // Pass the oneWire reference to Dallas Temperature.
//unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
unsigned long TempSendFreqency = 60000; // Sleep time between reads (in milliseconds)
unsigned long lastTemp = 0;
boolean metric = true;
MyMessage DallasMsg(0, V_TEMP);
MyMessage msgId(0, V_ID);
#ifdef PRINT_ARRAY
DeviceAddress dallasAddresses[8];
#else
/* Tabelle von Testsensoren
DeviceAddress dallasAddresses[] = {
  {0x28, 0x8D, 0x4F, 0xC0, 0x06, 0x00, 0x00, 0xD0}, // Position Oben
  {0x28, 0xDD, 0x0D, 0xC0, 0x06, 0x00, 0x00, 0x94}  // Position
  {0x28, 0xFF, 0x04, 0x22, 0xA1, 0x16, 0x03, 0xD9},  // Position Oben
  {0x28, 0xFF, 0xE2, 0xA4, 0xA1, 0x16, 0x03, 0x13},  // Position 3/4
  {0x28, 0xFF, 0x16, 0x20, 0xA1, 0x16, 0x03, 0x21},  // Position 2/4
  {0x28, 0xFF, 0xA2, 0xE3, 0xA0, 0x16, 0x04, 0xE8}   // Position Unten
int  resolution = 10;
int  conversionTime = 750;
//Parameter fuer Schaltkreise
#define noRelays 4                     // Anzahl der Schaltkreise
const int relayPin[] = {A0, A1, A2, A3};       //  switch around pins to your desire
//#define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
//#define NUMBER_OF_RELAYS 1 // Total number of attached relays
class Relay             // relay class, store all relevant data (equivalent to struct)
  public:
    int relayPin;             // physical pin number of relay
    boolean relayState;       // relay status (also stored in EEPROM)
Relay Relays[noRelays];
MyMessage msg[noRelays];
void before()
  conversionTime = 750 / (1 &lt;&lt; (12 - resolution));
  sensors.begin();
  //numSensors = sensors.getDeviceCount();
  #ifdef PRINT_ARRAY
  printAddressArray();
  wait(100);
  // Initialize Relays with corresponding buttons
  for (int i = 0; i &lt; noRelays; i++) {
    Relays[i].relayPin = relayPin[i];
    msg[i].sensor = i;                                   // initialize messages
    msg[i].type = V_LIGHT;
    Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
    digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
    send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
    wait(50);
  // Senden der MAC Adressen der gefundenen Sensoren
  for (int i = 0; i &lt; MAX_ATTACHED_DS18B20; i++) {
      send(msgId.setSensor(DS_First_Child_ID + i).set(dallasAddresses[i], 8));
    sendSketchInfo(SN, SV);
    wait(100);
    // present sensor to gateway
      present(i, S_LIGHT);
    wait(100);
      present(DS_First_Child_ID + i, S_TEMP);
    unsigned long vergangeneZeit = millis();
    if (vergangeneZeit - lastTemp &gt; TempSendFreqency) {
    sleep(conversionTime);
      // Fetch and round temperature to one decimal; original method uses "sensors.getTempCByIndex(i)"
      float temperature = static_cast&lt;float&gt;(static_cast&lt;int&gt;((metric ? sensors.getTempC(dallasAddresses[i]) : sensors.getTempF(dallasAddresses[i])) * 10.)) / 10.;
      //#if COMPARE_TEMP == 1
        if (lastTemperature[i] != temperature &amp;&amp; temperature != -127.00 &amp;&amp; temperature != 85.00) {
          //#else
          //if (temperature != -127.00 &amp;&amp; temperature != 85.00) {
      //#endif
            send(DallasMsg.setSensor(i + DS_First_Child_ID).set(temperature, 1));
            lastTemperature[i] = temperature;
      lastTemp = millis();
void receive(const MyMessage &amp;message)
      if (message.sensor &lt; noRelays) {          // check if message is valid for relays..... previous line  &lsqb;&lsqb;[ if (message.sensor &lt;=noRelays){ &rsqb;&rsqb;]
        digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
        send(msg[message.sensor].set(Relays[message.sensor].relayState ? true : false));
        saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
    wait(20);
</code></pre>
<p dir="auto">The Gatway is controlled by the FHEM.</p>
<p dir="auto">My problem is, if the temperature is transmitted by the Gatway and at the same time one of the relays is switched, it says in the fhem that the relay is ON, but the relay on the Getway is OFF.</p>
<p dir="auto">How can I get the relay safely on or off?<br />
Thank you!</p>
]]></description><link>https://forum.mysensors.org/topic/10164/rs485-gatway-with-relay-and-ds18b20-sensors</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 02:37:54 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10164.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 Feb 2019 13:00:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RS485 Gatway with relay and DS18B20 sensors on Tue, 12 Feb 2019 19:26:07 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your support!<br />
It now works without losing some switching commands.</p>
<p dir="auto">I have adapted the Gateway software according to your suggestions.<br />
And in the fhem, I defined the devices as follows:</p>
<pre><code>define MYSENSOR_10 MYSENSORS_DEVICE 10
setuuid MYSENSOR_10 5c61b043-f33f-3ee4-4a0b-da4876cebf4faa94
attr MYSENSOR_10 IODev meinMSG
attr MYSENSOR_10 mapReading_id4 4 id
attr MYSENSOR_10 mapReading_id5 5 id
attr MYSENSOR_10 mapReading_id6 6 id
attr MYSENSOR_10 mapReading_id7 7 id
attr MYSENSOR_10 mapReading_power 0 power
attr MYSENSOR_10 mapReading_power1 1 power
attr MYSENSOR_10 mapReading_power2 2 power
attr MYSENSOR_10 mapReading_power3 3 power
attr MYSENSOR_10 mapReading_status 0 status
attr MYSENSOR_10 mapReading_status1 1 status
attr MYSENSOR_10 mapReading_status2 2 status
attr MYSENSOR_10 mapReading_status3 3 status
attr MYSENSOR_10 mapReading_temperature4 4 temperature
attr MYSENSOR_10 mapReading_temperature5 5 temperature
attr MYSENSOR_10 mapReading_temperature6 6 temperature
attr MYSENSOR_10 mapReading_temperature7 7 temperature
attr MYSENSOR_10 mode node
attr MYSENSOR_10 requestAck 1
attr MYSENSOR_10 room Heizung_OG
attr MYSENSOR_10 setReading_power 1
attr MYSENSOR_10 setReading_power1 1
attr MYSENSOR_10 setReading_power2 1
attr MYSENSOR_10 setReading_power3 1
attr MYSENSOR_10 setReading_status off,on
attr MYSENSOR_10 setReading_status1 off,on
attr MYSENSOR_10 setReading_status2 off,on
attr MYSENSOR_10 setReading_status3 off,on
</code></pre>
<p dir="auto">To control the relays individually, I defined a  "readingsProxy" for each relay:</p>
<pre><code>define Relais1 readingsProxy MYSENSOR_10:status
attr Relais1 devStateIcon on:sani_heating_level_100@red:off off:sani_heating_level_0@#18B8ED:on
attr Relais1 group Heizungskreise,
attr Relais1 room Heizung_OG
attr Relais1 setFn {($CMD eq "on")?"status on":"status off"}
attr Relais1 setList on off
</code></pre>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.mysensors.org/post/97315</link><guid isPermaLink="true">https://forum.mysensors.org/post/97315</guid><dc:creator><![CDATA[butaluk]]></dc:creator><pubDate>Tue, 12 Feb 2019 19:26:07 GMT</pubDate></item><item><title><![CDATA[Reply to RS485 Gatway with relay and DS18B20 sensors on Mon, 11 Feb 2019 08:21:22 GMT]]></title><description><![CDATA[<p dir="auto">Three remarks on that:</p>
<ul>
<li>Avoid doubleing ChildID's for temperature and relays (1-3 are "dual-functional", DS_First_Child_ID = 4 would help)</li>
<li>Use wait(conversionTime) instead of sleep(conversionTime); millis will otherwise be reset.</li>
<li>Better use FHEM's options to request an ACK from the Node; so state will not be update on controller side until ACK is sent from Node. (send(msg[message.sensor].set(Relays[message.sensor].relayState ? true : false)); is not needed; in FHEM: attr &lt;MYSENSOR_0?&gt; requestAck)</li>
</ul>
]]></description><link>https://forum.mysensors.org/post/97276</link><guid isPermaLink="true">https://forum.mysensors.org/post/97276</guid><dc:creator><![CDATA[rejoe2]]></dc:creator><pubDate>Mon, 11 Feb 2019 08:21:22 GMT</pubDate></item></channel></rss>
