<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[gpio leds for rx/tx/err on Rpi2b not being set in /sys/class/gpio]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Configured my Rpi2B with the following:-<br />
./configure --my-transport=rf24 --my-gateway=ethernet --my-port=5003 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18</p>
<p dir="auto">which results in:-[SECTION] Detecting target machine.<br />
[OK] machine detected: SoC=BCM2836, Type=rpi2, CPU=armv7l.<br />
[SECTION] Detecting SPI driver.<br />
[OK] SPI driver detected:BCM.<br />
[SECTION] Gateway configuration.<br />
[OK] Type: ethernet.<br />
[OK] Transport: rf24.<br />
[OK] Signing: Disabled.<br />
[OK] Encryption: Disabled.<br />
[OK] CPPFLAGS: -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_DEFAULT_TX_LED_PIN=18 -DMY_DEFAULT_RX_LED_PIN=16 -DMY_DEFAULT_ERR_LED_PIN=12 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003<br />
[SECTION] Detecting init system.<br />
[OK] Init system detected: systemd.<br />
[SECTION] Saving configuration.<br />
[OK] Saved.<br />
[SECTION] Cleaning previous builds.<br />
[OK] Finished.</p>
<p dir="auto">This I assume, because not quite clear on the gateway page,  will blink rx and tx on rf24 receive and xmit.   However, it does not appear to work.   When I look in /sys/class/gpio only 22 is enabled but as input.   Been looking through the code and can't quite following the trail to the gpio enablement.</p>
<p dir="auto">Have I assumed correctly?</p>
<p dir="auto">Cheers,</p>
<p dir="auto">Michael</p>
]]></description><link>https://forum.mysensors.org/topic/10272/gpio-leds-for-rx-tx-err-on-rpi2b-not-being-set-in-sys-class-gpio</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 18:29:59 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10272.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Mar 2019 18:47:05 GMT</pubDate><ttl>60</ttl></channel></rss>
