<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble setting up repeater node]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I'm having a lot of trouble getting a repeater node to work. I've tried to do some background on this, and have checked a few other posts that also seem to have trouble, but I'm not really any closer.</p>
<p dir="auto">Here is my scenario:<br />
I have a gateway connected to a raspberry pi.<br />
I have a battery powered node (set node ID to 47). I'd like to be able to place this a fair distance away from the gateway, and so I need a repeater. I made a repeater node (node id set to 46).</p>
<p dir="auto">The repeater node appears to connect to the gateway ok. The mobile temp node also connects ok if I'm close to the gateway. But doesn't seem to be able to use the repeater.</p>
<p dir="auto">For testing, to try to force the temp node to use the repeater, I have set:</p>
<pre><code>#define MY_NODE_ID 47                    //To set a fixed ID for your node
#define MY_PARENT_NODE_ID 46             //To set a fixed parent for this node
</code></pre>
<p dir="auto">I noticed that if I didn't have MY_PARENT_NODE_IS_STATIC the node would still connect to the<br />
gateway. If I defined it, then it seemed to only try to connect to the repeater node, which is what I want at least for testing.</p>
<p dir="auto">So, I'm pretty sure the repeater node connects. Code for repeater is:</p>
<pre><code>#include &lt;Arduino.h&gt;
#define MY_RADIO_RF24
#include &lt;SPI.h&gt;
#define MY_NODE_ID 46                        //To set a fixed ID for your node
#define CHILD_ID 0
//#define MY_REPEATER_FEATURE
#include &lt;MySensors.h&gt;
void presentation() {
  sendSketchInfo("Repeater Node", "1.1");
  present(CHILD_ID, S_DOOR);
</code></pre>
<p dir="auto">And output from gateway when connecting the repeater:</p>
<pre><code>mysgw: Starting gateway...
mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
mysgw: TSF:LRT:OK
mysgw: TSM:INIT
mysgw: TSF:WUR:MS=0
mysgw: TSM:INIT:TSP OK
mysgw: TSM:INIT:GW MODE
mysgw: MCO:REG:NOT NEEDED
mysgw: Listening for connections on 0.0.0.0:5003
mysgw: MCO:BGN:STP
mysgw: MCO:BGN:INIT OK,TSP=1
mysgw: TSF:MSG:READ,46-46-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
mysgw: TSF:MSG:BC
mysgw: TSF:MSG:FPAR REQ,ID=46
mysgw: TSF:CKU:OK,FCTRL
mysgw: TSF:MSG:GWL OK
mysgw: TSF:MSG:SEND,0-0-46-46,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
mysgw: TSF:MSG:PINGED,ID=46,HP=1
mysgw: TSF:MSG:SEND,0-0-46-46,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
mysgw: TSF:MSG:SEND,0-0-46-46,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
mysgw: TSF:MSG:READ,46-46-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.1
mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Repeater Node
mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
mysgw: TSF:MSG:READ,46-46-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
mysgw: TSF:MSG:SEND,0-0-46-46,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
</code></pre>
<p dir="auto">So seems ok. Connecting the temperature node, with debug on, serial output looks like:</p>
<pre><code>␀␀
 __  __       ____
        |___/                      2.3.1
16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
28 TSM:INIT
28 TSF:WUR:MS=0
34 TSM:INIT:TSP OK
36 TSM:INIT:STATID=47
40 TSF:SID:OK,ID=47
43 TSM:FPAR
43 TSM:FPAR:STATP=46
45 TSM:ID
47 TSM:ID:OK
49 TSM:UPL
51 TSF:MSG:SEND,47-47-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
2060 TSM:UPL
2062 TSF:MSG:SEND,47-47-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
4071 TSM:UPL
4073 TSF:MSG:SEND,47-47-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
6082 TSM:UPL
6084 TSF:MSG:SEND,47-47-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
8093 !TSM:UPL:FAIL
8095 TSM:FPAR
8095 TSM:FPAR:STATP=46
8099 TSM:ID
8099 TSM:ID:OK
8101 TSM:UPL
</code></pre>
<p dir="auto">I'm guessing that the repeater isn't forwarding the messages. I'm also having trouble parsing the log output. There are links to the message parser, but this doesn't seem to function anymore (<a href="https://www.mysensors.org/build/parser" rel="nofollow ugc">https://www.mysensors.org/build/parser</a> doesn't point to a project anymore).</p>
<p dir="auto">If anyone could help interpret the messages that would be great.</p>
<p dir="auto">Robert</p>
]]></description><link>https://forum.mysensors.org/topic/10289/trouble-setting-up-repeater-node</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 17:32:41 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10289.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 Mar 2019 02:25:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble setting up repeater node on Sun, 31 Mar 2019 21:16:09 GMT]]></title><description><![CDATA[<p dir="auto">Great work <a class="plugin-mentions-user plugin-mentions-a" href="/user/rjad" aria-label="Profile: rjad">@<bdi>rjad</bdi></a>, thanks for reporting back.</p>
]]></description><link>https://forum.mysensors.org/post/98284</link><guid isPermaLink="true">https://forum.mysensors.org/post/98284</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Sun, 31 Mar 2019 21:16:09 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble setting up repeater node on Sun, 31 Mar 2019 20:18:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a></p>
<p dir="auto">The log parser now works for me too. Thanks.</p>
]]></description><link>https://forum.mysensors.org/post/98283</link><guid isPermaLink="true">https://forum.mysensors.org/post/98283</guid><dc:creator><![CDATA[rjad]]></dc:creator><pubDate>Sun, 31 Mar 2019 20:18:57 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble setting up repeater node on Sun, 31 Mar 2019 20:15:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a></p>
<p dir="auto">Well that's embarrassing....</p>
<p dir="auto">That was part of my testing to make sure it worked as a normal node. Looks like I forgot to put it back.</p>
<p dir="auto">Thanks for pointing it out.</p>
]]></description><link>https://forum.mysensors.org/post/98282</link><guid isPermaLink="true">https://forum.mysensors.org/post/98282</guid><dc:creator><![CDATA[rjad]]></dc:creator><pubDate>Sun, 31 Mar 2019 20:15:58 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble setting up repeater node on Sun, 31 Mar 2019 13:32:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rjad" aria-label="Profile: rjad">@<bdi>rjad</bdi></a> the log mentions NREP which means<br />
"message relaying request, but not a repeater"</p>
<p dir="auto">I noticed in your sketch that you have commented out the line that enables the repeater. Maybe it works better if you remove the // before #define MY_REPEATER_FEATURE</p>
]]></description><link>https://forum.mysensors.org/post/98271</link><guid isPermaLink="true">https://forum.mysensors.org/post/98271</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Sun, 31 Mar 2019 13:32:13 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble setting up repeater node on Sun, 31 Mar 2019 13:34:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rjad" aria-label="Profile: rjad">@<bdi>rjad</bdi></a> interesting. I wonder what is so special about your environment, since it works for almost everyone else.<br />
Do you have blocker plugins or a filtering proxy? Could you try from a different web browser?<br />
Edit: it seems you are not entirely alone <a href="https://forum.mysensors.org/topic/10292/log-parser-error">https://forum.mysensors.org/topic/10292/log-parser-error</a><br />
Iam unable to reproduce the problem though - as I showed in the screen shot it works for me.</p>
]]></description><link>https://forum.mysensors.org/post/98270</link><guid isPermaLink="true">https://forum.mysensors.org/post/98270</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Sun, 31 Mar 2019 13:34:15 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble setting up repeater node on Sun, 31 Mar 2019 11:09:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a></p>
<p dir="auto">This is the output from the repeater node when I turn on the temperature node:</p>
<pre><code>
28 TSM:INIT
28 TSF:WUR:MS=0
34 TSM:INIT:TSP OK
36 TSM:INIT:STATID=46
40 TSF:SID:OK,ID=46
43 TSM:FPAR
77 TSF:MSG:SEND,46-46-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
649 TSF:MSG:READ,0-0-46,s=255,c=3,t=8,pt=1,l=1,sg=0:0
655 TSF:MSG:FPAR OK,ID=0,D=1
2088 TSM:FPAR:OK
2088 TSM:ID
2091 TSM:ID:OK
2093 TSM:UPL
2097 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
2109 TSF:MSG:READ,0-0-46,s=255,c=3,t=25,pt=1,l=1,sg=0:1
2115 TSF:MSG:PONG RECV,HP=1
2117 TSM:UPL:OK
2119 TSM:READY:ID=46,PAR=0,DIS=1
2123 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
2136 TSF:MSG:READ,0-0-46,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
2144 TSF:MSG:SEND,46-46-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
2154 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
2854 TSF:MSG:READ,0-0-46,s=255,c=3,t=6,pt=0,l=1,sg=0:M
2865 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Repeater Node
2875 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
2885 TSF:MSG:SEND,46-46-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
2891 MCO:REG:REQ
2895 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
2904 TSF:MSG:READ,0-0-46,s=255,c=3,t=27,pt=1,l=1,sg=0:1
2910 MCO:PIM:NODE REG=1
2912 MCO:BGN:STP
2914 MCO:BGN:INIT OK,TSP=1
55711 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
55717 !TSF:MSG:REL MSG,NREP
57733 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
57741 !TSF:MSG:REL MSG,NREP
59746 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
59752 !TSF:MSG:REL MSG,NREP
61761 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
61767 !TSF:MSG:REL MSG,NREP
63791 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
63797 !TSF:MSG:REL MSG,NREP
65804 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
65810 !TSF:MSG:REL MSG,NREP
67831 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
67837 !TSF:MSG:REL MSG,NREP
69844 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
69851 !TSF:MSG:REL MSG,NREP
71874 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
71880 !TSF:MSG:REL MSG,NREP
73891 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
73897 !TSF:MSG:REL MSG,NREP
75929 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
75935 !TSF:MSG:REL MSG,NREP
77940 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
</code></pre>
]]></description><link>https://forum.mysensors.org/post/98268</link><guid isPermaLink="true">https://forum.mysensors.org/post/98268</guid><dc:creator><![CDATA[rjad]]></dc:creator><pubDate>Sun, 31 Mar 2019 11:09:19 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble setting up repeater node on Sun, 31 Mar 2019 10:03:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rjad" aria-label="Profile: rjad">@<bdi>rjad</bdi></a> ,</p>
<p dir="auto">Also, I have 4.7uF caps on all the radios. And even if I put the repeater a metre away from the temp node I get the same result. Its awkward getting the log from the repeater, but I'll get on it.</p>
]]></description><link>https://forum.mysensors.org/post/98267</link><guid isPermaLink="true">https://forum.mysensors.org/post/98267</guid><dc:creator><![CDATA[rjad]]></dc:creator><pubDate>Sun, 31 Mar 2019 10:03:30 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble setting up repeater node on Sun, 31 Mar 2019 10:01:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a></p>
<p dir="auto">When I go to the link <a href="https://www.mysensors.org/build/parser" rel="nofollow ugc">https://www.mysensors.org/build/parser</a> I get a page with the message:<br />
!Doh.. This project isn't published!</p>
]]></description><link>https://forum.mysensors.org/post/98266</link><guid isPermaLink="true">https://forum.mysensors.org/post/98266</guid><dc:creator><![CDATA[rjad]]></dc:creator><pubDate>Sun, 31 Mar 2019 10:01:19 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble setting up repeater node on Sun, 31 Mar 2019 08:45:40 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/rjad" aria-label="Profile: rjad">@<bdi>rjad</bdi></a>, welcome to the MySensors forum.</p>
<p dir="auto">The log parser works good for me. See screen shot below. Could you clarify what you mean by "doesn't point to a project anymore"? Could you check the browser console if there are any messages when you try to use the parser?<br />
<img src="/assets/uploads/files/1554020431343-d42639b1-43f1-44e3-852d-fcefd8d9ff0b-resized.png" alt="0_1554020431146_D42639B1-43F1-44E3-852D-FCEFD8D9FF0B.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Could you grab the debug log from the repeater node, while the temp node is starting up?<br />
You do have capacitors on the nrf24 radios, right?<br />
How far from the repeater node is the temp node?</p>
]]></description><link>https://forum.mysensors.org/post/98264</link><guid isPermaLink="true">https://forum.mysensors.org/post/98264</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Sun, 31 Mar 2019 08:45:40 GMT</pubDate></item></channel></rss>
