<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Humidity&#x2F;Temp Sensor Issues]]></title><description><![CDATA[<p dir="auto">This is my second humidity sensor.</p>
<p dir="auto">I keep getting the same error.<br />
Failed reading temperature from DHT<br />
Failed reading humidity from DHT</p>
<ol>
<li>I have tried 4 different DHT22 and even the one off my working Humidity sensor</li>
<li>I have tried 5 different mini pros with only my original working..</li>
<li>My original has a blue LED but the others were ordered in a ten pack and have red LED.</li>
<li>Some of the red LED mini pro will only connect @ 57600 while others and blue LED connect @ 115200</li>
<li>Changing the input pin for the DHT22 makes no difference.</li>
</ol>
<p dir="auto">Do I just have a bunch of bad Mini Pros or am I missing something?</p>
<p dir="auto"><img src="/uploads/upload-b45e91d9-e6fb-49b5-acee-b741470a5b81.jpg" alt="FullSizeRender_1.jpg" class=" img-fluid img-markdown" /> <img src="/uploads/upload-06c44f6a-a90b-4fdb-8678-50cdf1bc6548.jpg" alt="FullSizeRender_2.jpg" class=" img-fluid img-markdown" /> <img src="/uploads/upload-47f0f1c8-b980-4c62-bb32-af3fc3302d8a.jpg" alt="FullSizeRender.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/topic/1035/humidity-temp-sensor-issues</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 17:14:14 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1035.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Feb 2015 06:03:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Thu, 26 Feb 2015 19:42:44 GMT]]></title><description><![CDATA[<p dir="auto">I've a sensor running with naked 328p, 3.3V, 8 MHz internal Osz and DHT22. Maybe I'm lucky?!</p>
]]></description><link>https://forum.mysensors.org/post/10744</link><guid isPermaLink="true">https://forum.mysensors.org/post/10744</guid><dc:creator><![CDATA[TimO]]></dc:creator><pubDate>Thu, 26 Feb 2015 19:42:44 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Thu, 26 Feb 2015 19:33:56 GMT]]></title><description><![CDATA[<p dir="auto">Problem with dht22 and ds18b20.<br />
It looks likes a programmation beceause i just switch from arduino pro 3.3 to a 5.5 on my mys1.1 board and it works fine.<br />
Or it s really a problem of manufacturing ...</p>
]]></description><link>https://forum.mysensors.org/post/10740</link><guid isPermaLink="true">https://forum.mysensors.org/post/10740</guid><dc:creator><![CDATA[ludoarchi]]></dc:creator><pubDate>Thu, 26 Feb 2015 19:33:56 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Thu, 26 Feb 2015 18:35:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ludoarchi" aria-label="Profile: ludoarchi">@<bdi>ludoarchi</bdi></a> said:</p>
<blockquote>
<p dir="auto">I have a similar problem with a pack of 10 pro mini 3,3v bought at the ebay link from mysensor ?</p>
</blockquote>
<p dir="auto">Only problem with humidiy sensor or a more general problem?</p>
<p dir="auto">Googling 3.3v dht22 giver a lot of results. E.g.<br />
<a href="http://forum.arduino.cc/index.php?topic=269216.0" rel="nofollow ugc">http://forum.arduino.cc/index.php?topic=269216.0</a></p>
]]></description><link>https://forum.mysensors.org/post/10736</link><guid isPermaLink="true">https://forum.mysensors.org/post/10736</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Thu, 26 Feb 2015 18:35:44 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Thu, 26 Feb 2015 18:00:23 GMT]]></title><description><![CDATA[<p dir="auto">I have a similar problem with a pack of 10 pro mini 3,3v bought at the ebay link from mysensor ?<br />
But every think is ok with pro mini 5.5v ...<br />
I tried many things but it still do not work ?<br />
Other people with same problem ?<br />
Ideas ?<br />
Thinks</p>
]]></description><link>https://forum.mysensors.org/post/10733</link><guid isPermaLink="true">https://forum.mysensors.org/post/10733</guid><dc:creator><![CDATA[ludoarchi]]></dc:creator><pubDate>Thu, 26 Feb 2015 18:00:23 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Thu, 26 Feb 2015 03:40:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bulldoglowell" aria-label="Profile: BulldogLowell">@<bdi>BulldogLowell</bdi></a> Yes.  I put one 4.7uf for the radio and one for the DHT22 with no change.  Over two days I did get it to read the DHT22 once out of 1000 or so reads and that was with out any capacitors.. Reading every 5 seconds</p>
]]></description><link>https://forum.mysensors.org/post/10675</link><guid isPermaLink="true">https://forum.mysensors.org/post/10675</guid><dc:creator><![CDATA[FUZNUTS]]></dc:creator><pubDate>Thu, 26 Feb 2015 03:40:51 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Wed, 25 Feb 2015 23:37:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fuznuts" aria-label="Profile: FUZNUTS">@<bdi>FUZNUTS</bdi></a></p>
<p dir="auto">have you tried to put a cap on the DHT's Vcc and ground??</p>
]]></description><link>https://forum.mysensors.org/post/10674</link><guid isPermaLink="true">https://forum.mysensors.org/post/10674</guid><dc:creator><![CDATA[BulldogLowell]]></dc:creator><pubDate>Wed, 25 Feb 2015 23:37:56 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Wed, 25 Feb 2015 22:57:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/salmoides" aria-label="Profile: Salmoides">@<bdi>Salmoides</bdi></a> 5v regulated into raw comes out 4.52v on vcc</p>
]]></description><link>https://forum.mysensors.org/post/10672</link><guid isPermaLink="true">https://forum.mysensors.org/post/10672</guid><dc:creator><![CDATA[FUZNUTS]]></dc:creator><pubDate>Wed, 25 Feb 2015 22:57:00 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Wed, 25 Feb 2015 12:46:30 GMT]]></title><description><![CDATA[<p dir="auto">When you apply voltage to the RAW pin, do you get 5v out of Vcc?</p>
]]></description><link>https://forum.mysensors.org/post/10655</link><guid isPermaLink="true">https://forum.mysensors.org/post/10655</guid><dc:creator><![CDATA[Salmoides]]></dc:creator><pubDate>Wed, 25 Feb 2015 12:46:30 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Wed, 25 Feb 2015 08:17:28 GMT]]></title><description><![CDATA[<p dir="auto">these are all 5.5v 16mhz  or at least that's what they say..lol<br />
ill try leaving it set up on the gateway and see what happens with fingers crossed</p>
]]></description><link>https://forum.mysensors.org/post/10648</link><guid isPermaLink="true">https://forum.mysensors.org/post/10648</guid><dc:creator><![CDATA[FUZNUTS]]></dc:creator><pubDate>Wed, 25 Feb 2015 08:17:28 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Wed, 25 Feb 2015 07:31:52 GMT]]></title><description><![CDATA[<p dir="auto">Perhaps your minis are 3.3v 8 Mhz and you selected 5v 16 Mhz in the IDE?</p>
]]></description><link>https://forum.mysensors.org/post/10645</link><guid isPermaLink="true">https://forum.mysensors.org/post/10645</guid><dc:creator><![CDATA[Jan Gatzke]]></dc:creator><pubDate>Wed, 25 Feb 2015 07:31:52 GMT</pubDate></item><item><title><![CDATA[Reply to Humidity&#x2F;Temp Sensor Issues on Wed, 25 Feb 2015 07:21:57 GMT]]></title><description><![CDATA[<p dir="auto">Mine was doing the same thing when I had it plugged into my laptop while viewing the serial monitor. Once I connected it to my Gateway and into Vera, all is working. I got really frustrated at this, but it just seemed like it wanted to be connected to something first.<br />
Sorry, probably not much help, but thought I would share my experience.</p>
]]></description><link>https://forum.mysensors.org/post/10643</link><guid isPermaLink="true">https://forum.mysensors.org/post/10643</guid><dc:creator><![CDATA[Dean]]></dc:creator><pubDate>Wed, 25 Feb 2015 07:21:57 GMT</pubDate></item></channel></rss>
