<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NRF52 -&gt; gateway Losing messages]]></title><description><![CDATA[<p dir="auto">I have quite an annoying problem keeping me from successfully deploying a bunch of NRF52 PIRs.<br />
For a little while it works and then the messages stop. I have serial logs from the NRF52 seemingly sending the messages but nothing on the gateway side. The two devices are about 6 feet apart. I've tried it at home with a completely different pi and a completely different radio (pa and non-pa version) and the results are the same. On my desk at work its a regular pi b with a non-pa radio. Again, six feet apart. I've tried the default channel. I've tried channel 10 and 125 as well. I've tried max power and low power. I send the message twice thinking maybe one gets lost and the second makes it through.</p>
<p dir="auto">Here's the sketch:</p>
<pre><code>// SUMMARY: This demo sketch runs on the AM612 PIR v607 PCBto transmit battery voltage (heartbeat) and motion detections to a MySensors gateway using MySensors protocols.
// Note: because this is a passive node, node ID must be set manually to a unique sensor node ID:
#define MY_NODE_ID 70  // Passive mode requires static node ID
//#define MY_CORE_ONLY
//#define MY_PASSIVE_NODE
#define MY_RADIO_NRF5_ESB
 * Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
 * Copyright (C) 2013-2017 Sensnology AB
 * Version 1.0 - tekka
 * Passive node example: This is a passive &amp; independent reporting node
// This demo sketch also draws from the MySensor's example MotionSensor sketch.
//#define IS_NRF51  //true iff the target is an nRF51.  If an nRF52, then comment this line out!
#define PIR_DETECTION_PIN 2
#define SHORT_WAIT 100
//#define MY_RF24_CHANNEL 125
#define MY_NRF5_ESB_CHANNEL 125
//#define MY_NRF5_ESB_PA_LEVEL NRF5_PA_MAX
//#define MY_TRANSPORT_WAIT_READY_MS  3000
//#define MY_TRANSPORT_MAX_TSM_FAILURES 2
//#define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 3000
//#define MY_TRANSPORT_UPLINK_CHECK_DISABLED
//#define MY_PARENT_NODE_IS_STATIC
//#define MY_PARENT_NODE_ID 0
#define MY_DEBUG_VERBOSE_NRF5_ESB
//#define MY_NRF5_ESB_REVERSE_ACK_RX
//#define MY_NRF5_ESB_REVERSE_ACK_TX
#define MY_DEBUG_VERBOSE_TRANSPORT
#include &lt;MySensors.h&gt;
// Enable debug prints
volatile bool motion_change=false;
void blinkityBlink(uint8_t pulses, uint8_t repetitions) {
  for (int x=0;x&lt;repetitions;x++) {
    for (int i=0;i&lt;pulses;i++) {
      digitalWrite(LED_BUILTIN,HIGH);
      wait(20);
      digitalWrite(LED_BUILTIN,LOW);
      wait(100);
      wait(500);
void disableNfc() {  //only applied to nRF52
#ifndef IS_NRF51
  //Make pins 9 and 10 usable as GPIO pins.
  NRF_NFCT-&gt;TASKS_DISABLE=1;  //disable NFC
  NRF_NVMC-&gt;CONFIG=1;  // Write enable the UICR
  NRF_UICR-&gt;NFCPINS=0; //Make pins 9 and 10 usable as GPIO pins.
  NRF_NVMC-&gt;CONFIG=0;  // Put the UICR back into read-only mode.
void turnOffRadio() {
  NRF_RADIO-&gt;TASKS_DISABLE=1;
  while (!(NRF_RADIO-&gt;EVENTS_DISABLED)) {}  //until radio is confirmed disabled
void turnOffUarte0() {
#ifndef IS_NRF51
  NRF_UARTE0-&gt;TASKS_STOPRX = 1;
  NRF_UARTE0-&gt;TASKS_STOPTX = 1;
//  NRF_UARTE0-&gt;TASKS_SUSPEND = 1;
  NRF_UARTE0-&gt;ENABLE=0;  //disable UART0
  while (NRF_UARTE0-&gt;ENABLE!=0) {};  //wait until UART0 is confirmed disabled.
#ifdef IS_NRF51
  NRF_UART0-&gt;TASKS_STOPRX = 1;
  NRF_UART0-&gt;TASKS_STOPTX = 1;
  NRF_UART0-&gt;TASKS_SUSPEND = 1;
  NRF_UART0-&gt;ENABLE=0;  //disable UART0
  while (NRF_UART0-&gt;ENABLE!=0) {};  //wait until UART0 is confirmed disabled.
void turnOffAdc() {
#ifndef IS_NRF51
  if (NRF_SAADC-&gt;ENABLE) { //if enabled, then disable the SAADC
    NRF_SAADC-&gt;TASKS_STOP=1;
    while (NRF_SAADC-&gt;EVENTS_STOPPED) {} //wait until stopping of SAADC is confirmed
    NRF_SAADC-&gt;ENABLE=0;  //disable the SAADC
    while (NRF_SAADC-&gt;ENABLE) {} //wait until the disable is confirmed
void turnOffHighFrequencyClock() {
    NRF_CLOCK-&gt;TASKS_HFCLKSTOP = 1;
    while ((NRF_CLOCK-&gt;HFCLKSTAT) &amp; 0x0100) {}  //wait as long as HF clock is still running.
void mySleepPrepare() {  //turn-off energy drains prior to sleep
  turnOffHighFrequencyClock();
  turnOffRadio();
  //turnOffUarte0();
void activateLpComp() {
  NRF_LPCOMP-&gt;PSEL=0; // monitor AIN0 (i.e. pin P0.02 on nRF52832 PIR Motion Sensor v607).
  while (!(NRF_LPCOMP-&gt;PSEL==0)) {} //wait until confirmed
  NRF_LPCOMP-&gt;REFSEL=3;  // choose 1/2 VDD as the reference voltage
  while (!(NRF_LPCOMP-&gt;REFSEL==3)) {} //wait until confirmed
  NRF_LPCOMP-&gt;ANADETECT=0;  //detect CROSS events on PIR detection pin
  while (NRF_LPCOMP-&gt;ANADETECT!=0) {} //wait until confirmed
  NRF_LPCOMP-&gt;INTENSET=B1000;  //Enable interrupt for CROSS event
  while (!(((NRF_LPCOMP-&gt;INTENSET)&amp;B1000)==B1000)) {} //wait until confirmed
  NRF_LPCOMP-&gt;ENABLE=1;  //Enable LPCOMP
  while (!(NRF_LPCOMP-&gt;ENABLE==1)) {} //wait until confirmed
  NRF_LPCOMP-&gt;TASKS_START=1;  //start the LPCOMP
  while (!(NRF_LPCOMP-&gt;EVENTS_READY)) {}  //wait until ready
  NVIC_SetPriority(LPCOMP_IRQn, 15);
  NVIC_ClearPendingIRQ(LPCOMP_IRQn);
  NVIC_EnableIRQ(LPCOMP_IRQn);
void suspendLpComp() { //suspend getting more interrupts from LPCOMP before the first interrupt can be handled
  if ((NRF_LPCOMP-&gt;ENABLE) &amp;&amp; (NRF_LPCOMP-&gt;EVENTS_READY)) {  //if LPCOMP is enabled
    NRF_LPCOMP-&gt;INTENCLR=B0100;  //disable interrupt from LPCOMP
    while (((NRF_LPCOMP-&gt;INTENCLR)&amp;B0100)==B0100) {} //wait until confirmed
void resumeLpComp() { //suspend getting interrupts from LPCOMP
  NRF_LPCOMP-&gt;INTENSET=B0100;  //Enable interrupt for UP event
  while (((NRF_LPCOMP-&gt;INTENSET)&amp;B1000)!=B0100) {} //wait until confirmed
#define CHILD_ID 1   // Id of the motion sensor child
#define ID_S_MULTIMETER        28
// Initialize motion message
MyMessage msg_S_MULTIMETER_V_VOLTAGE(ID_S_MULTIMETER,V_VOLTAGE);
float batteryVoltage=0;
void blinkityBlink(uint8_t repetitions) {
    wait(20);
    wait(100);
    wait(20);
    if (x&lt;(repetitions-1)) {  //skip waiting at the end of the final repetition
      wait(500);
  sendSketchInfo("Motion Sensor", "1.0");
  present(CHILD_ID, S_MOTION);
  wait(SHORT_WAIT);
  present(ID_S_MULTIMETER,S_MULTIMETER,"Electric Station");
  wait(SHORT_WAIT);
  hwInit();
  hwPinMode(LED_BUILTIN,OUTPUT_D0H1);
  hwPinMode(PIR_DETECTION_PIN,INPUT);
  blinkityBlink(2,1);  //Signify end of setup with two quick pulses.
  disableNfc();  //remove unnecessary energy drains
  turnOffAdc();  //remove unnecessary energy drains
  activateLpComp();
void mySleep(uint32_t ms) {
   mySleepPrepare();  //Take steps to reduce drains on battery current prior to sleeping
   sleep(ms);
bool motionDetected=false;
  mySleep(300000);  //sleep for 5 minutes
  if (motion_change) {
    motionDetected=!motionDetected;
    if (motionDetected) {
      digitalWrite(LED_BUILTIN,HIGH);  //turn-on LED to signify motion detected
      send(msg.set("1"));  // motion detected
      wait(SHORT_WAIT);
      send(msg.set("1"));
      delay(500);
    else {
      digitalWrite(LED_BUILTIN,LOW);  //turn-off LED to signify motion no longer detected
      send(msg.set("0"));  // send all-clear to prepare for future detections
      wait(SHORT_WAIT);
      send(msg.set("0"));
    NRF_LPCOMP-&gt;EVENTS_CROSS=0;
  else { //must be a scheduled wake-up.  Time to report voltage as a heartbeat.
    batteryVoltage=((float)hwCPUVoltage())/1000.0;  //take voltage measurement after transmission to hopefully measure lowest voltage that occurs.
    send(msg_S_MULTIMETER_V_VOLTAGE.set(batteryVoltage,3));  //send battery voltage with 3 decimal places
// * Reset events and read back on nRF52
//* http://infocenter.nordicsemi.com/pdf/nRF52_Series_Migration_v1.0.pdf
#if __CORTEX_M == 0x04
#define NRF5_RESET_EVENT(event)                                                 \
        event = 0;        \
        (void)event
#else
#define NRF5_RESET_EVENT(event) event = 0
// This must be in one line
extern "C" { void LPCOMP_IRQHandler(void) {motion_change=true; NRF5_RESET_EVENT(NRF_LPCOMP-&gt;EVENTS_CROSS); NRF_LPCOMP-&gt;EVENTS_CROSS=0; MY_HW_RTC-&gt;CC[0]=(MY_HW_RTC-&gt;COUNTER+2);}}
</code></pre>
<p dir="auto">The serial log from a wake up event:</p>
<pre><code>849294 MCO:SLP:WUP=-1
849296 TSF:TRI:TPU
849298 NRF5:INIT:ESB
849300 NRF5:STL
849301 NRF5:SND:TO=255,LEN=8,PID=1,NOACK=1
849311 NRF5:SND:END=1,ACK=0,RTRY=4,RSSI=-61,WAKE=10
849316 ?TSF:MSG:SEND,70-70-255-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
849373 NRF5:SND:TO=255,LEN=8,PID=2,NOACK=1
849383 NRF5:SND:END=1,ACK=0,RTRY=4,RSSI=-61,WAKE=9
849388 ?TSF:MSG:SEND,70-70-255-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
849394 NRF5:RX:LEN=8,NOACK=0,PID=1,RSSI=-63,RX=0
849399 TSF:MSG:READ,0-0-70,s=1,c=1,t=16,pt=0,l=1,sg=0:0
849404 TSF:MSG:ACK
849406 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
849411 TSF:TDI:TPD
849413 NRF5:PD
</code></pre>
<p dir="auto">From the gateway at NRF5 power-on:</p>
<pre><code>May 07 14:07:49 DEBUG TSF:MSG:READ,70-70-0,s=255,c=3,t=6,pt=1,l=1,sg=0:255
May 07 14:07:49 DEBUG GWT:TPS:TOPIC=mysensors-out/70/255/3/0/6,MSG SENT
</code></pre>
<p dir="auto">Sometimes it all makes it through, not this time.</p>
<p dir="auto">Here's the startup log from the NRF5 at the same time:</p>
<pre><code> __  __       ____
        |___/                      2.3.1
23 MCO:BGN:INIT NODE,CP=RNNPN---,REL=255,VER=2.3.1
28 TSM:INIT
29 TSF:WUR:MS=0
30 NRF5:INIT:ESB
32 TSM:INIT:TSP OK
34 TSM:INIT:TSP PSM
35 TSM:INIT:STATID=70
37 NRF5:STL
39 TSF:SID:OK,ID=70
40 TSM:FPAR
41 TSM:FPAR:STATP=255
43 TSM:ID
44 TSM:ID:OK
46 TSM:UPL:DISABLED
47 TSM:READY:ID=70,PAR=255,DIS=1
50 NRF5:SND:TO=255,LEN=9,PID=0,NOACK=0
60 NRF5:SND:END=1,ACK=0,RTRY=4,RSSI=-61,WAKE=11
65 ?TSF:MSG:SEND,70-70-255-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
72 NRF5:RX:LEN=9,NOACK=0,PID=1,RSSI=-71,RX=0
76 TSF:MSG:READ,0-0-70,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
81 NRF5:SND:TO=255,LEN=12,PID=1,NOACK=1
92 NRF5:SND:END=1,ACK=0,RTRY=4,RSSI=-61,WAKE=10
96 ?TSF:MSG:SEND,70-70-255-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
103 NRF5:SND:TO=255,LEN=8,PID=2,NOACK=1
113 NRF5:SND:END=1,ACK=0,RTRY=4,RSSI=-61,WAKE=9
118 ?TSF:MSG:SEND,70-70-255-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:255
2124 NRF5:SND:TO=255,LEN=20,PID=3,NOACK=1
2135 NRF5:SND:END=1,ACK=0,RTRY=4,RSSI=-61,WAKE=9
2139 ?TSF:MSG:SEND,70-70-255-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
2147 NRF5:SND:TO=255,LEN=10,PID=0,NOACK=1
2158 NRF5:SND:END=1,ACK=0,RTRY=4,RSSI=-61,WAKE=9
2162 ?TSF:MSG:SEND,70-70-255-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
2169 NRF5:SND:TO=255,LEN=7,PID=1,NOACK=1
2179 NRF5:SND:END=1,ACK=0,RTRY=4,RSSI=-61,WAKE=9
2184 ?TSF:MSG:SEND,70-70-255-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
2240 NRF5:SND:TO=255,LEN=23,PID=2,NOACK=1
2251 NRF5:SND:END=1,ACK=0,RTRY=4,RSSI=-61,WAKE=9
2256 ?TSF:MSG:SEND,70-70-255-0,s=28,c=0,t=30,pt=0,l=16,sg=0,ft=0,st=OK:Electric Station
2314 MCO:REG:NOT NEEDED
2316 MCO:BGN:STP
3057 MCO:BGN:INIT OK,TSP=1
3059 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
3064 TSF:TDI:TPD
3066 NRF5:PD
PORT CLOSED
</code></pre>
<p dir="auto">any hints would be more than welcome, please</p>
]]></description><link>https://forum.mysensors.org/topic/10375/nrf52-gateway-losing-messages</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 16:23:50 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10375.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 May 2019 13:09:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NRF52 -&gt; gateway Losing messages on Thu, 09 May 2019 12:26:23 GMT]]></title><description><![CDATA[<p dir="auto">Make sure you don't have two controllers running. That will split the messages between them randomly.</p>
]]></description><link>https://forum.mysensors.org/post/99057</link><guid isPermaLink="true">https://forum.mysensors.org/post/99057</guid><dc:creator><![CDATA[alowhum]]></dc:creator><pubDate>Thu, 09 May 2019 12:26:23 GMT</pubDate></item></channel></rss>
