<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tilt-up garage door clearance sensor]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have a tilt-up garage door, and I would like to automate it. However since it is a tilt-up door, in order to close/open I need to make sure nobody/nothing in the way.</p>
<p dir="auto">I have  a thought of using ultrasound sensors, infrared sensors. The main question is how to cover the area in which an object can block the door ?</p>
<p dir="auto">The main concern is the safety. I dont want to hit a child or damage a car which is in the way of the door.</p>
<p dir="auto">Any ideas are more than welcome.</p>
<p dir="auto">Thanks in advance</p>
<p dir="auto">Atesz</p>
]]></description><link>https://forum.mysensors.org/topic/10384/tilt-up-garage-door-clearance-sensor</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 18:58:58 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10384.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 May 2019 12:23:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tilt-up garage door clearance sensor on Fri, 10 May 2019 16:39:21 GMT]]></title><description><![CDATA[<p dir="auto">Basically you have 2 options:</p>
<ol>
<li>You are present to watch when the port goes down</li>
<li>something expensive like this: <a href="https://duckduckgo.com/?q=Safety+Light+Curtains&amp;t=canonical&amp;iar=images&amp;iax=images&amp;ia=images" rel="nofollow ugc">https://duckduckgo.com/?q=Safety+Light+Curtains&amp;t=canonical&amp;iar=images&amp;iax=images&amp;ia=images</a></li>
</ol>
]]></description><link>https://forum.mysensors.org/post/99086</link><guid isPermaLink="true">https://forum.mysensors.org/post/99086</guid><dc:creator><![CDATA[bjacobse]]></dc:creator><pubDate>Fri, 10 May 2019 16:39:21 GMT</pubDate></item></channel></rss>
