<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nano minimum voltage]]></title><description><![CDATA[<p dir="auto">Know officially the nano needs 5v<br />
Has anyone played with the minimum voltage you can get away with</p>
<p dir="auto">Wondering if I can run them off one 18650 ?</p>
<p dir="auto">If not will use 2 plus a 7805</p>
]]></description><link>https://forum.mysensors.org/topic/10406/nano-minimum-voltage</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Mar 2026 03:22:05 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10406.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 May 2019 09:33:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nano minimum voltage on Thu, 23 May 2019 15:13:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bjacobse" aria-label="Profile: bjacobse">@<bdi>bjacobse</bdi></a> Granted that is what he has, but it's a lot more effort reducing a Nano to pro-mini compared to the cost of a getting a pro-mini to begin surgery to start with... We all have devices bought with good intention gathering dust as we learn.... ;)<br />
One of these days will get a Nano to play with, but had dismissed it for battery applications from the start of this adventure and have seen no reason to reconsider that conclusion since.. For testbed or PSU applications, fine, but for battery applications?...<br />
As the Limerick man advised the driver seeking directions to Dublin, " I wouldn't start from here" :)</p>
]]></description><link>https://forum.mysensors.org/post/99354</link><guid isPermaLink="true">https://forum.mysensors.org/post/99354</guid><dc:creator><![CDATA[zboblamont]]></dc:creator><pubDate>Thu, 23 May 2019 15:13:16 GMT</pubDate></item><item><title><![CDATA[Reply to Nano minimum voltage on Thu, 23 May 2019 14:06:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zboblamont" aria-label="Profile: zboblamont">@<bdi>zboblamont</bdi></a> said in <a href="/post/99331">Nano minimum voltage</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arden" aria-label="Profile: arden">@<bdi>arden</bdi></a> With so many more efficient boosters available than stock voltage regulators I have to question the wisdom of detuning any device to accommodate the power supply for all but the most extreme requirements.<br />
With the Nano's USB converter constantly sucking power it is the least frugal device of the newer Arduinos, the pro-mini has a wealth of information on reducing sleep load power with LED and VR removed, perhaps a change in approach may be worthwhile ?</p>
</blockquote>
<p dir="auto">Yes I fully agree, but if Arden only have those Nano available, he can use those with extra effort to remove all those not needed current consumption IC's</p>
]]></description><link>https://forum.mysensors.org/post/99351</link><guid isPermaLink="true">https://forum.mysensors.org/post/99351</guid><dc:creator><![CDATA[bjacobse]]></dc:creator><pubDate>Thu, 23 May 2019 14:06:10 GMT</pubDate></item><item><title><![CDATA[Reply to Nano minimum voltage on Wed, 22 May 2019 18:02:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arden" aria-label="Profile: arden">@<bdi>arden</bdi></a> With so many more efficient boosters available than stock voltage regulators I have to question the wisdom of detuning any device to accommodate the power supply for all but the most extreme requirements.<br />
]]></description><link>https://forum.mysensors.org/post/99331</link><guid isPermaLink="true">https://forum.mysensors.org/post/99331</guid><dc:creator><![CDATA[zboblamont]]></dc:creator><pubDate>Wed, 22 May 2019 18:02:27 GMT</pubDate></item><item><title><![CDATA[Reply to Nano minimum voltage on Wed, 22 May 2019 15:01:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kimot" aria-label="Profile: kimot">@<bdi>kimot</bdi></a> said in <a href="/post/99315">Nano minimum voltage</a>:</p>
<blockquote>
<p dir="auto">But it do NOT means with 16Mhz crystal on Arduino Nano ...</p>
</blockquote>
<p dir="auto">Well the AtMega328 has an option to use internal RC oscillation and hence don't need to use the 16MHZ crystal.<br />
yes we agree that with low voltage you must use 1MHz, -&gt; 8MHZ div8</p>
<p dir="auto">From the link I have provided above, read chap 9.6:<br />
Calibrated Internal RC Oscillator<br />
By default, the Internal RC Oscillator provides an approximate 8.0MHz clock. Though voltage and temperature<br />
dependent, this clock can be very accurately calibrated by the user. See Table 29-9 on page 313 for more<br />
details. The device is shipped with the CKDIV8 Fuse programmed. See ”System Clock Prescaler” on page 45<br />
for more details.<br />
This clock may be selected as the system clock by programming the CKSEL Fuses as shown in Table 9-11. If<br />
selected, it will operate with no external components.</p>
<p dir="auto">And yes it's possible and maybe needed to calibrate the internal RC, that you need to test</p>
<p dir="auto">And yes you need also to change fuse for BOD (Brown out detection) as this by default close down the ATMega328 below 2.7V<br />
read chap 10.2: BOD Disable</p>
]]></description><link>https://forum.mysensors.org/post/99326</link><guid isPermaLink="true">https://forum.mysensors.org/post/99326</guid><dc:creator><![CDATA[bjacobse]]></dc:creator><pubDate>Wed, 22 May 2019 15:01:47 GMT</pubDate></item><item><title><![CDATA[Reply to Nano minimum voltage on Tue, 21 May 2019 19:29:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bjacobse" aria-label="Profile: bjacobse">@<bdi>bjacobse</bdi></a> said in <a href="/post/99311">Nano minimum voltage</a>:</p>
<blockquote>
<p dir="auto">Datasheet: The device operates between 1.8-5.5 volts.<br />
and this means to bypass/remove the voltage regulator on the Nano board</p>
</blockquote>
]]></description><link>https://forum.mysensors.org/post/99315</link><guid isPermaLink="true">https://forum.mysensors.org/post/99315</guid><dc:creator><![CDATA[kimot]]></dc:creator><pubDate>Tue, 21 May 2019 19:29:33 GMT</pubDate></item><item><title><![CDATA[Reply to Nano minimum voltage on Tue, 21 May 2019 14:34:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arden" aria-label="Profile: arden">@<bdi>arden</bdi></a> said in <a href="/post/99287">Nano minimum voltage</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">You don't need to play around, as the first thing to do is to read the datasheet for the CPU, a nano like the other original/classic Arduino's are using AtMega328p, then you get knowledge what is possible.<br />
<p dir="auto"><a href="http://ww1.microchip.com/downloads/en/DeviceDoc/ATmega48A-PA-88A-PA-168A-PA-328-P-DS-DS40002061A.pdf" rel="nofollow ugc">http://ww1.microchip.com/downloads/en/DeviceDoc/ATmega48A-PA-88A-PA-168A-PA-328-P-DS-DS40002061A.pdf</a></p>
]]></description><link>https://forum.mysensors.org/post/99311</link><guid isPermaLink="true">https://forum.mysensors.org/post/99311</guid><dc:creator><![CDATA[bjacobse]]></dc:creator><pubDate>Tue, 21 May 2019 14:34:04 GMT</pubDate></item><item><title><![CDATA[Reply to Nano minimum voltage on Mon, 20 May 2019 18:39:10 GMT]]></title><description><![CDATA[<p dir="auto">If you use an ISP programmer, you can reprogram the fuses and use it on lower voltages also. Upto 1.8v but also 3.3v</p>
]]></description><link>https://forum.mysensors.org/post/99295</link><guid isPermaLink="true">https://forum.mysensors.org/post/99295</guid><dc:creator><![CDATA[electrik]]></dc:creator><pubDate>Mon, 20 May 2019 18:39:10 GMT</pubDate></item><item><title><![CDATA[Reply to Nano minimum voltage on Mon, 20 May 2019 13:29:24 GMT]]></title><description><![CDATA[<p dir="auto">Why "plus" 7805.<br />
Nano has got voltage regulator on  board.<br />
Original Arduinos 7805 I think, clones LM1117 usually.</p>
]]></description><link>https://forum.mysensors.org/post/99290</link><guid isPermaLink="true">https://forum.mysensors.org/post/99290</guid><dc:creator><![CDATA[kimot]]></dc:creator><pubDate>Mon, 20 May 2019 13:29:24 GMT</pubDate></item></channel></rss>
