<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sensors are sporadically showing up]]></title><description><![CDATA[<p dir="auto">Unfortunately when I started playing around with Mysensors a week or so ago, life was a little quieter than what it is right now. After playing around with my Gateway I have to readd all my sensors to it, and I was silly today and have tried to combine two sensors that I have had running flawlessly, into one sensor. Big mistake.... I've had a couple issues happen in my family and now I've stuffed up my garage door operation... I have been working on the sketch now for a couple hours and I just can't seem to work out the problem.</p>
<p dir="auto">I have built a sensor which will operate 2 relays, and will also report the state of my two garage doors. My controller is Vera 3. What is happening is something weird; the repeater part always shows up after inclusion, but sometimes it shows the 2 door sensors, then other times it shows the 2 relays. So my guess is that the issue is around Presentation, but it all looks fine to me, and when the relay and the door sensor sketches are uploaded individually, each sensor shows up as they should. I have even tried different power supplies in case it was a power issue, but the issue is still there.</p>
<p dir="auto">Here is my sketch:</p>
<pre><code>// Enable debug prints to serial monitor
#define MY_REPEATER_FEATURE
#include &lt;SPI.h&gt;
#include &lt;MySensors.h&gt;
#include &lt;Bounce2.h&gt;
#define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define SSR_A_ID 1   // Id of the sensor child
#define SSR_B_ID 2   // Id of the sensor child
const int buttonPinA = 6;
const int buttonPinB = 7;
int oldValueA = 0;
int oldValueB = 0;
bool stateA = false;
bool stateB = false;
Bounce debouncerA = Bounce();
Bounce debouncerB = Bounce();
MyMessage msgA(SSR_A_ID, V_TRIPPED);
MyMessage msgB(SSR_B_ID, V_TRIPPED);
void before()
  for (int sensor = 1, pin = RELAY_PIN; sensor &lt;= NUMBER_OF_RELAYS; sensor++, pin++) {
    pinMode(pin, OUTPUT);
    digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
  // Setup the button
  pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
  pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
  // After setting up the buttons, setup debouncer
  debouncerA.attach(buttonPinA);
  debouncerA.interval(5);
  debouncerB.attach(buttonPinB);
  debouncerB.interval(5);
  sendSketchInfo("Garage door Operate/State", "1.0");
  present(SSR_A_ID, S_DOOR);
  present(SSR_B_ID, S_DOOR);
    present(sensor, S_BINARY);
  debouncerA.update();
  // Get the update value
  int valueA = debouncerA.read();
  if (valueA != oldValueA) {
    // Send in the new value
    send(msgA.set(valueA == HIGH ? 0 : 1));
    oldValueA = valueA;
  debouncerB.update();
  int valueB = debouncerB.read();
  if (valueB != oldValueB) {
    send(msgB.set(valueB == HIGH ? 0 : 1));
    oldValueB = valueB;
void receive(const MyMessage &amp;message)
    // Change relay state
    digitalWrite(message.sensor - 1 + RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
    // Store state in eeprom
    // Write some debug info
    Serial.print(message.sensor);
</code></pre>
<p dir="auto">I am sorry to be asking yet again for help. I really have tried for so long today to get this to work on my own, but I can't see the issue. I do have the flu, so maybe that isn't helping!</p>
]]></description><link>https://forum.mysensors.org/topic/10428/sensors-are-sporadically-showing-up</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 12:52:15 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10428.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 May 2019 11:58:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Sensors are sporadically showing up on Wed, 29 May 2019 01:48:12 GMT]]></title><description><![CDATA[<p dir="auto">Thank you so much for your help, that fixed it!!!</p>
<p dir="auto">My wife thanks you too! :-)</p>
]]></description><link>https://forum.mysensors.org/post/99457</link><guid isPermaLink="true">https://forum.mysensors.org/post/99457</guid><dc:creator><![CDATA[Homer]]></dc:creator><pubDate>Wed, 29 May 2019 01:48:12 GMT</pubDate></item><item><title><![CDATA[Reply to Sensors are sporadically showing up on Tue, 28 May 2019 12:23:23 GMT]]></title><description><![CDATA[<p dir="auto">You are using the same ChildID's for relays and tripped/door states. Imo this is messing things up, so e.g. use 11+12 for tripped values.<br />
Remark: If you are looking for a good example on using arrays for that kind of tasks, see korttomas work here: <a href="https://forum.mysensors.org/post/51488">https://forum.mysensors.org/post/51488</a></p>
]]></description><link>https://forum.mysensors.org/post/99445</link><guid isPermaLink="true">https://forum.mysensors.org/post/99445</guid><dc:creator><![CDATA[rejoe2]]></dc:creator><pubDate>Tue, 28 May 2019 12:23:23 GMT</pubDate></item></channel></rss>
