<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved] 2019 - Mega Board &#x2F; 5100 Ethernet Shield -&gt; Confirm Pin&#x2F;etc Setup Please!]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<ol>
<li>I've got an Elegoo Mega2560 r3 board with a Sunfounder 5100 Ethernet shield.</li>
<li>There is NO radio on this board and it won't have one.</li>
<li>I am trying to configure it as a MQTT gateway without transport to be concerned with local sensors only.</li>
<li>This board/shield combo will init and get onto the network just fine using other sample basic (non-MySensors) tutorial sketches I've found, but not when running MySensors.</li>
</ol>
<p dir="auto">-&gt; I am trying to get the board to initialize, at this point I haven't complicated the basic MQTT gateway sample sketch with any I/O sensor configs; I am simply watching the Serial Monitor to see if the board inits and gets on the network.</p>
<p dir="auto">-&gt; I know the Mega has potentially some configuration changes versus an Uno, but all of the threads I've researched and found are 2-3-4 years old and I don't know if things have been updated in the MySensors framework to support a Mega + 5100 Ethernet shield natively. Hopefully so!</p>
<h2>Specific Requests:</h2>
<ol>
<li>
<p dir="auto">If anyone could clarify what I need to change in my code to get this board/Eth shield working I would be MOST appreciative!</p>
</li>
<li>
<p dir="auto">I downgraded my Boards Manager version to 1.6.11 from 1.6.23 after reading some older threads about the Mega/5100 combo, what should I set this to?</p>
</li>
</ol>
<p dir="auto">Here's my code.</p>
<pre><code>/*
 * Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
 * Version 1.0 - Henrik Ekblad
 * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
 * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
 * LED purposes:
 * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
 * - ERR (red) - fast blink on error during transmission error or receive crc error
 * nRF24L01+  ESP8266
 * VCC        VCC
 * CE         GPIO4
 * CSN/CS     GPIO15
 * SCK        GPIO14
 * MISO       GPIO12
 * MOSI       GPIO13
  * Inclusion mode button:
 * Make sure to fill in your ssid and WiFi password below for ssid &amp; pass.
// Enable debug prints to serial monitor, baud rate is 115200 for console
//#define MY_RADIO_RF24
//#define MY_RADIO_RFM95
#define MY_MQTT_PUBLISH_TOPIC_PREFIX "hvac/dampers"
#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "hvac/dampers"
// Set MQTT client id
#define MY_MQTT_CLIENT_ID "mysensors-board1"
#define MY_GATEWAY_W5100
#define MY_W5100_SPI_EN 4
// radio on the same spi bus.
//#if !defined(MY_W5100_SPI_EN) &amp;&amp; !defined(ARDUINO_ARCH_SAMD)
#define MY_SOFTSPI
#define MY_SOFT_SPI_SCK_PIN 52 //14 was default, changed to test Mega board
#define MY_SOFT_SPI_MISO_PIN 50 //16 was default, changed to test Mega board
#define MY_SOFT_SPI_MOSI_PIN 51 //15 was default, changed to test Mega board
//#endif
#ifndef MY_RF24_CE_PIN
#define MY_RF24_CE_PIN 5
#ifndef MY_RF24_CS_PIN
#define MY_RF24_CS_PIN 6
// Enable these if your MQTT broker requires username/password
#define MY_IP_ADDRESS 10,2,20,24
#define MY_IP_GATEWAY_ADDRESS 10,2,20,1
#define MY_CONTROLLER_IP_ADDRESS 10, 2, 10, 34
#define MY_PORT 1883
// Enable inclusion mode
// Set blinking period
// Flash leds on rx/tx/err
#include &lt;Ethernet.h&gt;
#include &lt;MySensors.h&gt;
#include &lt;Bounce2.h&gt;
</code></pre>
<p dir="auto">Here's what pops in the Serial console:</p>
<pre><code>10:41:18.848 -&gt; 378897 GWT:RMQ:MQTT RECONNECT
10:41:19.428 -&gt; 379460 GWT:TPC:IP=0.0.0.0
10:41:20.421 -&gt; 380463 GWT:RMQ:MQTT RECONNECT
10:41:21.003 -&gt; 381026 GWT:TPC:IP=0.0.0.0
10:41:21.994 -&gt; 382028 GWT:RMQ:MQTT RECONNECT
10:41:22.579 -&gt; 382592 GWT:TPC:IP=0.0.0.0
10:41:23.568 -&gt; 383594 GWT:RMQ:MQTT RECONNECT
10:41:24.146 -&gt; 384157 GWT:TPC:IP=0.0.0.0
10:41:25.137 -&gt; 385160 GWT:RMQ:MQTT RECONNECT
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/10430/solved-2019-mega-board-5100-ethernet-shield-confirm-pin-etc-setup-please</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 05:23:16 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10430.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 May 2019 15:46:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved] 2019 - Mega Board &#x2F; 5100 Ethernet Shield -&gt; Confirm Pin&#x2F;etc Setup Please! on Tue, 28 May 2019 16:25:59 GMT]]></title><description><![CDATA[<p dir="auto">UPDATE:<br />
I power cycled the board by physically removing the USB power/data cable and the board came up on the network + MQTT session to the broker was established!!</p>
<p dir="auto">For what it's worth and for future reference if anyone finds this thread:</p>
<p dir="auto">It appears the official MySensors Hello World ethernet gateway basic tutorial works great for the Mega/2560 board paired with a 5100 Ethernet shield.</p>
]]></description><link>https://forum.mysensors.org/post/99449</link><guid isPermaLink="true">https://forum.mysensors.org/post/99449</guid><dc:creator><![CDATA[armoredsaint]]></dc:creator><pubDate>Tue, 28 May 2019 16:25:59 GMT</pubDate></item></channel></rss>
