<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Right sensor&#x2F;message type for using analog message in Domoticz]]></title><description><![CDATA[<p dir="auto">Hello MySensors friends,</p>
<p dir="auto">For my rain sensor, I also send the analogue value to the controller in addition to the text of the rain status (with V_TEXT / S_INFO), I tried some types, but in domoticz that is immediately converted to another value, so ultimately also via V_TEXT / S_INFO sent the raw value (0 - 1023) to the controller, partly because at that time I only used that value to determine the correct value for the rain status.</p>
<p dir="auto">In the meantime that works pretty well, and I want to keep seeing the analogue value to be able to make a graph of it.<br />
Only Domoticz makes a table of it since it is a text message.</p>
<p dir="auto">is there another type I can use that Domoticz understands, and displays the analog value between 0 and 1023?</p>
<p dir="auto">the rain status (dry, raindrops, rain, heavy rain) is of course also in the table, but is it also possible to put it directly in a graph within domoticz?</p>
<p dir="auto">Another question;<br />
I have placed a water pressure sensor which measures the drinking water pressure, after looking around I came out to use (V_PRESSURE / S_BARO), after all water pressure is also pressure ...<br />
But now domoticz sees the sensor only as a barometer which measures the air pressure, so including the weather forecast .....</p>
<p dir="auto">Has anyone tried this before in combination with domoticz?</p>
<p dir="auto">thank you in advance !</p>
]]></description><link>https://forum.mysensors.org/topic/10463/right-sensor-message-type-for-using-analog-message-in-domoticz</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 19:34:45 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10463.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Jun 2019 12:55:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Right sensor&#x2F;message type for using analog message in Domoticz on Sun, 09 Jun 2019 16:54:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flyingdomotic" aria-label="Profile: flyingdomotic">@<bdi>flyingdomotic</bdi></a></p>
<p dir="auto">I tried that, only then the text status will not appear in domoticz.</p>
<p dir="auto">I didn't use/tried it for the analog value, maybe i'll try that,</p>
<p dir="auto">thank you!</p>
]]></description><link>https://forum.mysensors.org/post/99744</link><guid isPermaLink="true">https://forum.mysensors.org/post/99744</guid><dc:creator><![CDATA[dzjr]]></dc:creator><pubDate>Sun, 09 Jun 2019 16:54:10 GMT</pubDate></item><item><title><![CDATA[Reply to Right sensor&#x2F;message type for using analog message in Domoticz on Sun, 09 Jun 2019 15:46:00 GMT]]></title><description><![CDATA[<p dir="auto">Any specific reason not using V_RAIN and send any float value ?</p>
]]></description><link>https://forum.mysensors.org/post/99741</link><guid isPermaLink="true">https://forum.mysensors.org/post/99741</guid><dc:creator><![CDATA[FlyingDomotic]]></dc:creator><pubDate>Sun, 09 Jun 2019 15:46:00 GMT</pubDate></item></channel></rss>
