(homeassistant) mysensors.notify does nothing, (alternatives?)
  • I cant get mysensors.notify to work...
    in my configuration.yaml i put this:
    input_boolean:
      baum_fx_twinkle:
        initial: off
    and in my automations.yaml i have this.
    - alias: 'send scene to map'
      trigger:
        platform: state
        entity_id: input_boolean.baum_fx_twinkle
        to: 'on'
      action:
        service: notify.mysensors
        data:
          message: twinkle
          target: 'lalelu 111 2'
    it works when i use MYSController with type c_set, subtype V_TEXT settings. but whenever i try to press the switch it does nothing... also there is nothing logged in MYSController.
    Same when i try to use the call-service-page in my homeassistant backend... just nothing - not even an error...
    does anyone have an idea? I checked for correct IDs and everything and in MYSController it definetly works... but homeassistant is very reluctant to do anything...
  • or does anybody have an alternative?
    i just want to send a V_TEXT to a node via the dashboard.
  • Plugin Developer
    Maybe add 'home assistant' to the topic title?
  • @alowhum
    good idea. thx.
  • let me ask differently again:
    did anybody get this:
    https://www.home-assistant.io/components/notify.mysensors/
    to work? i find no useful example and have the suspicion that it just doesnt work anymore since all the forumentries seem old and outdated?
  • sorry for spamming my own thread... i just want to keep updates coming in while debugging... i got it to the point where the homeassistant log tells me: "Unable to find service notify/mysensors".
    but apparently there is no known solution to do this. i even unplugged and restarted everything. i am hitting a dead end here...
  • I have the same issue after settinf an automation under HA ( "Unable to find service notify/mysensor")
    Do you find a workaround?
  • I faced same issue and was able to solve it by doing a proper presentation of S_INFO widget, as described in sample sketch: https://www.home-assistant.io/integrations/notify.mysensors/
    The error message is quite misleading.
  • 24
  • 1
