<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[node NRF52832 with DHT22]]></title><description><![CDATA[<p dir="auto">hello,<br />
i'm trying to experiment nodes with NRF52832.<br />
I use this sketch :</p>
<pre><code>// Enable debug prints
//#define MY_RADIO_RF24
//#define MY_RS485
#define MY_RADIO_NRF5_ESB
#include &lt;SPI.h&gt;
#include &lt;MySensors.h&gt;
#include &lt;DHT.h&gt;
#define DHT_DATA_PIN 08
// Set this offset if the sensor has a permanent small offset to the real temperatures.
// In Celsius degrees (as measured by the device)
#define SENSOR_TEMP_OFFSET 0
// Must be &gt;1000ms for DHT22 and &gt;2000ms for DHT11
static const uint64_t UPDATE_INTERVAL = 6000;
#define CHILD_ID_HUM 0
#define CHILD_ID_TEMP 1
float lastTemp;
float lastHum;
uint8_t nNoUpdatesTemp;
uint8_t nNoUpdatesHum;
bool metric = true;
DHT dht;
  sendSketchInfo("TemperatureHumiditeNRF", "1.0");
  present(CHILD_ID_HUM, S_HUM);
  if (UPDATE_INTERVAL &lt;= dht.getMinimumSamplingPeriod()) {
  dht.readSensor(true);
  if (isnan(temperature)) {
    lastTemp = temperature;
    // apply the offset before converting to something different than Celsius degrees
    if (!metric) {
    // Reset no updates counter
    nNoUpdatesTemp = 0;
    #ifdef MY_DEBUG
    Serial.print("T: ");
    Serial.println(temperature);
  } else {
    nNoUpdatesTemp++;
  if (isnan(humidity)) {
    lastHum = humidity;
    nNoUpdatesHum = 0;
    #ifdef MY_DEBUG
    Serial.print("H: ");
    Serial.println(humidity);
  } else {
    nNoUpdatesHum++;
  sleep(UPDATE_INTERVAL);
</code></pre>
<p dir="auto">But problem...<br />
My controlleur found my node, but no read of temperature or humidity.<br />
I try to change pin of data from dht22, same problem.</p>
<p dir="auto">Can you help me make this node running ?</p>
]]></description><link>https://forum.mysensors.org/topic/10493/node-nrf52832-with-dht22</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 03:06:47 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10493.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 Jun 2019 22:51:20 GMT</pubDate><ttl>60</ttl></channel></rss>
