<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Extrenal contact from water valve on same child-id]]></title><description><![CDATA[<p dir="auto">Hello MySensors friends,</p>
<p dir="auto">I made a node to control a water valve, the valve has its own status contact which I use as status signaling in the controller (Domoticz) of the valve,<br />
The contact uses the same child ID as the control of the valve, in MYScontroller I see that this works well, I send the valve open, if the valve is open the status will also be set to 1, so exactly as I want it .</p>
<p dir="auto">Only within Domoticz does the status of the control change immediately when the button is pressed, and when the valve is open I see the status getting a trigger again, so the berict will certainly come through.</p>
<p dir="auto">In the Domoticz hardware settings I have already disabled ACT from this child ID.</p>
<p dir="auto">Does anyone know how I can adjust this so that the status does not change until the valve has actually changed position?</p>
<p dir="auto">Thank you in advance</p>
<p dir="auto">dzjr</p>
]]></description><link>https://forum.mysensors.org/topic/10681/extrenal-contact-from-water-valve-on-same-child-id</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 16:25:06 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10681.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Oct 2019 19:27:28 GMT</pubDate><ttl>60</ttl></channel></rss>
