<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Generic Variable V_VAR1 not displaying correctly on Vera3 UI5.]]></title><description><![CDATA[<p dir="auto">I have created a multi-sensor + relay node that is passing two V_VAR1 and a V_LIGHT to the gateway. From the device overview I can see the two "Arduino Generic" sensors, but they are not displaying any value for the level. I know the values are being passes to the gateway since they are being reported correctly when I open the advanced tab of the sensor itself(see images). Any idea's why the Vera is not displaying the values next to the word "Level"?</p>
<p dir="auto">This repeater node is a custom board that I posted about last month. Once everything is worked out I will be posting more details to that thread.<br />
<a href="http://forum.mysensors.org/topic/845/surface-mount-atmega328p-au-sensor-board" rel="nofollow ugc">http://forum.mysensors.org/topic/845/surface-mount-atmega328p-au-sensor-board</a></p>
<p dir="auto">![Alt text][1]<br />
![Alt text][2]<br />
[1]: <a href="https://lh3.googleusercontent.com/3fjCULegAD1thKUJbG_-9ykoH2IvlfkfCOIspA3M2ly0SahY4bkxe8QdMx5w6W3B-k6Xjb7giac=w1896-h835" rel="nofollow ugc">https://lh3.googleusercontent.com/3fjCULegAD1thKUJbG_-9ykoH2IvlfkfCOIspA3M2ly0SahY4bkxe8QdMx5w6W3B-k6Xjb7giac=w1896-h835</a><br />
[2]: <a href="https://lh4.googleusercontent.com/zB5oGw6WYMfF3dXIkZEqR8EZiNyd4TWLGM5JROVmAdkI1d4FxCQ_A_HZHa9gsTCQfJt2J4c-uow=w1896-h835" rel="nofollow ugc">https://lh4.googleusercontent.com/zB5oGw6WYMfF3dXIkZEqR8EZiNyd4TWLGM5JROVmAdkI1d4FxCQ_A_HZHa9gsTCQfJt2J4c-uow=w1896-h835</a></p>
]]></description><link>https://forum.mysensors.org/topic/1079/generic-variable-v_var1-not-displaying-correctly-on-vera3-ui5</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 17:29:02 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1079.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Mar 2015 04:19:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Generic Variable V_VAR1 not displaying correctly on Vera3 UI5. on Fri, 13 Mar 2015 08:44:28 GMT]]></title><description><![CDATA[<p dir="auto">You cannot change the default Temp-device without affecting all of the same type (vera has no "override" functionality in their device definition files).</p>
<p dir="auto">So.. what you can do is to create a new device type used by the Arduino plugin.</p>
<p dir="auto">Here is some documentation of the files needed.<br />
<a href="http://wiki.micasaverde.com/index.php/Luup_plugins:_Static_JSON_file" rel="nofollow ugc">http://wiki.micasaverde.com/index.php/Luup_plugins:_Static_JSON_file</a><br />
(<a href="http://wiki.micasaverde.com/index.php/Category:Development" rel="nofollow ugc">http://wiki.micasaverde.com/index.php/Category:Development</a>)</p>
<p dir="auto">And this is where you set your own:<br />
<a href="https://github.com/mysensors/Vera/blob/master/L_Arduino.lua#L55" rel="nofollow ugc">https://github.com/mysensors/Vera/blob/master/L_Arduino.lua#L55</a></p>
]]></description><link>https://forum.mysensors.org/post/11267</link><guid isPermaLink="true">https://forum.mysensors.org/post/11267</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Fri, 13 Mar 2015 08:44:28 GMT</pubDate></item><item><title><![CDATA[Reply to Generic Variable V_VAR1 not displaying correctly on Vera3 UI5. on Fri, 13 Mar 2015 07:42:08 GMT]]></title><description><![CDATA[<p dir="auto">How do you define what to show for a device. I mean similar to the distance och temperature sensor? If I have a custom variable that tells number of times something has happened, how do I show it on the device itself and not only as a variable in the settings?</p>
]]></description><link>https://forum.mysensors.org/post/11265</link><guid isPermaLink="true">https://forum.mysensors.org/post/11265</guid><dc:creator><![CDATA[Atman]]></dc:creator><pubDate>Fri, 13 Mar 2015 07:42:08 GMT</pubDate></item><item><title><![CDATA[Reply to Generic Variable V_VAR1 not displaying correctly on Vera3 UI5. on Fri, 06 Mar 2015 06:46:37 GMT]]></title><description><![CDATA[<p dir="auto">You would have to create your own custom device files (which shows the VAR_x).</p>
]]></description><link>https://forum.mysensors.org/post/11031</link><guid isPermaLink="true">https://forum.mysensors.org/post/11031</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Fri, 06 Mar 2015 06:46:37 GMT</pubDate></item></channel></rss>
