<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RPi 3 with Domoticz and RF-link (RFXcom) &#x27;TSP-fail&#x27;]]></title><description><![CDATA[<p dir="auto">After playing some time with sensors and Arduinos I read about MySensors I wanted to expand my home automation system with it.</p>
<p dir="auto">Situation:<br />
Raspberry pi 3 with Domoticz with RF antenna and Z-wave running for about 3 years.</p>
<p dir="auto">Wish:<br />
Connect sensors in the bee hives in my garden to a new topic in the MQTT database of Domoticz. I have a long range RFXcom antenna working on 433 mhz. <a href="http://www.rflink.nl/blog2/devlist" rel="nofollow ugc">MySensors is supported</a></p>
<p dir="auto">Attempt:</p>
<pre><code>./configure --my-gateway=mqtt --my-controller-ip-address=192.168.0.176 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-port=/dev/ttyUSB0 --my-rfm69-frequency=433
</code></pre>
<p dir="auto">Error:</p>
<pre><code>Dec 28 23:55:49 INFO  Starting gateway...
Dec 28 23:55:49 INFO  Protocol version - 2.3.2
Dec 28 23:55:50 DEBUG Serial port /dev/ttyUSB20 (115200 baud) creat
ed
Dec 28 23:55:50 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=255,VER
=2.3.2
Dec 28 23:55:50 DEBUG TSF:LRT:OK
Dec 28 23:55:50 DEBUG TSM:INIT
Dec 28 23:55:50 DEBUG TSF:WUR:MS=0
Dec 28 23:55:50 DEBUG !TSM:INIT:TSP FAIL
Dec 28 23:55:50 DEBUG TSM:FAIL:CNT=1
Dec 28 23:55:50 DEBUG TSM:FAIL:DIS
Dec 28 23:55:50 DEBUG TSF:TDI:TSL
Dec 28 23:56:00 DEBUG TSM:FAIL:RE-INIT
Dec 28 23:56:00 DEBUG TSM:INIT
Dec 28 23:56:00 DEBUG !TSM:INIT:TSP FAIL
Dec 28 23:56:00 DEBUG TSM:FAIL:CNT=2
Dec 28 23:56:00 DEBUG TSM:FAIL:DIS
Dec 28 23:56:00 DEBUG TSF:TDI:TSL
</code></pre>
<p dir="auto">Who can help me here please?</p>
]]></description><link>https://forum.mysensors.org/topic/10854/rpi-3-with-domoticz-and-rf-link-rfxcom-tsp-fail</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 15:22:16 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10854.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Dec 2019 22:58:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RPi 3 with Domoticz and RF-link (RFXcom) &#x27;TSP-fail&#x27; on Mon, 30 Dec 2019 04:45:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/esfnl" aria-label="Profile: esfnl">@<bdi>esfnl</bdi></a> said in <a href="/post/102974">RPi 3 with Domoticz and RF-link (RFXcom) 'TSP-fail'</a>:</p>
<blockquote>
<p dir="auto">MySensors is supported</p>
</blockquote>
<p dir="auto">MySensors is supported if you connect an NRF24 to the RFXCom as instructed in the link, did you ?<br />
As explained, it can only <em>receive</em> information, so as you seem to have no gateway to assign node ID you will need to define your nodes as passive nodes and hard code node id :</p>
<pre><code>#define MY_PASSIVE_NODE
#define MY_NODE_ID 2
#define MY_PARENT_NODE_ID 0
</code></pre>
]]></description><link>https://forum.mysensors.org/post/103002</link><guid isPermaLink="true">https://forum.mysensors.org/post/103002</guid><dc:creator><![CDATA[Nca78]]></dc:creator><pubDate>Mon, 30 Dec 2019 04:45:24 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3 with Domoticz and RF-link (RFXcom) &#x27;TSP-fail&#x27; on Sun, 29 Dec 2019 22:10:37 GMT]]></title><description><![CDATA[<p dir="auto">Thank you all for your advice.</p>
<p dir="auto">Sorry for mixing up RF terms. On my hardware and in Domoticz it is called RFXCOM - RFXtrx433 USB 433.92MHz Transceiver.</p>
<p dir="auto">For me as a beginner it's hard to understand you recommend an extra micro controller and an extra long range antenna instead of fixing it by software. But if that is the case, I have to deal with that 😕.</p>
<p dir="auto">Thanks again!</p>
]]></description><link>https://forum.mysensors.org/post/102995</link><guid isPermaLink="true">https://forum.mysensors.org/post/102995</guid><dc:creator><![CDATA[ESFnl]]></dc:creator><pubDate>Sun, 29 Dec 2019 22:10:37 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3 with Domoticz and RF-link (RFXcom) &#x27;TSP-fail&#x27; on Sun, 29 Dec 2019 21:15:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/esfnl" aria-label="Profile: esfnl">@<bdi>esfnl</bdi></a><br />
You are completely wrong and mix different things together.<br />
Firstly - you wrote RFXcom (with long range antena ) and then mention link to RFLink.<br />
Both devices have got separete device in Domoticz:<br />
<img src="/assets/uploads/files/1577652924611-2019-12-29-215407_1920x1080_scrot-resized.png" alt="0_1577652923032_2019-12-29-215407_1920x1080_scrot.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Secondly - RFLink and RFXCom are for intergration most commercial sensors and transducers to 433MHz.<br />
You do not need install MySensors gateway on RPI for use them.<br />
Simply connect them and select in Domoticz devices with appropriate interface.<br />
Then you will see all sensors in your surroundings.<br />
Mostly your neighbors meteostantions, heatpumps etc.<br />
Here is my RFLink sensors list after couple of hours - none from me, all neighbors.<br />
And I live on village ....<br />
No block of flats.<br />
( It is twice as long as you see )<br />
<img src="/assets/uploads/files/1577653534750-2019-01-29-214601_1920x1080_scrot-resized.png" alt="0_1577653534106_2019-01-29-214601_1920x1080_scrot.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I do not know RFXCom, but RFLink can receive data from MySensors nodes.<br />
According your link, I do not test it.<br />
ONLY receive - so no AUTO ID for nodes, no answer for presentation etc.<br />
If you want use MySensors, I suggest build separate USB gateway and connect it to Domoticz and select<br />
"MySensors Gateway USB" in device list.<br />
That all.<br />
No "./configure" and all this.</p>
]]></description><link>https://forum.mysensors.org/post/102992</link><guid isPermaLink="true">https://forum.mysensors.org/post/102992</guid><dc:creator><![CDATA[kimot]]></dc:creator><pubDate>Sun, 29 Dec 2019 21:15:09 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3 with Domoticz and RF-link (RFXcom) &#x27;TSP-fail&#x27; on Sun, 29 Dec 2019 18:24:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: yveaux">@<bdi>yveaux</bdi></a> Yes, actually that was the plan having <a href="https://www.mysensors.org/controller/domoticz" rel="nofollow ugc">Domoticz and MySensors integrated</a>. But what is my beginner mistake?</p>
<p dir="auto">I have installed the <a href="https://www.mysensors.org/build/raspberry" rel="nofollow ugc">Raspberry version</a> of MySensors on the same Pi as Domoticz is running. In this Pi the RF-link antenna is plugged in the USB port, <a href="https://ibb.co/kBcf6rF" rel="nofollow ugc">see this picture of my fuse box</a>.</p>
<p dir="auto">Actually I'm not primary interested of controlling MySensors, my main goal is using Domoticz for collecting sensor data and sending messages. So just 'sniffing' the RF signals.</p>
<p dir="auto">Edit: <a href="http://www.rflink.nl/blog2/faq#Mysensors" rel="nofollow ugc">RFlink</a></p>
]]></description><link>https://forum.mysensors.org/post/102987</link><guid isPermaLink="true">https://forum.mysensors.org/post/102987</guid><dc:creator><![CDATA[ESFnl]]></dc:creator><pubDate>Sun, 29 Dec 2019 18:24:39 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3 with Domoticz and RF-link (RFXcom) &#x27;TSP-fail&#x27; on Sun, 29 Dec 2019 18:04:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/esfnl" aria-label="Profile: esfnl">@<bdi>esfnl</bdi></a> I think you're mixing things up. Are you trying to use the RFXcom connected to a serial port as a mysensors gateway?</p>
]]></description><link>https://forum.mysensors.org/post/102986</link><guid isPermaLink="true">https://forum.mysensors.org/post/102986</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sun, 29 Dec 2019 18:04:05 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3 with Domoticz and RF-link (RFXcom) &#x27;TSP-fail&#x27; on Sun, 29 Dec 2019 13:27:41 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your suggestions.</p>
<p dir="auto">I don't have any wires nor pin connections as the RF-link is an USB module (<a href="https://www.google.com/search?q=rfxcom&amp;client=firefox-b-d&amp;source=lnms&amp;tbm=isch&amp;sa=X&amp;ved=2ahUKEwiLma-M-trmAhXHYVAKHQiyCyEQ_AUoAnoECA8QBA&amp;biw=1536&amp;bih=790&amp;dpr=1.25" rel="nofollow ugc">RFXcom</a>.</p>
<p dir="auto">I understand having a controller and gateway separately is recommended. But I'd like to use the long-range antenna currently operational. Am I correct I can configure the MySensors in the same frequency of 433 MHz?</p>
<p dir="auto">Could my error lie within the ./configure command?</p>
]]></description><link>https://forum.mysensors.org/post/102980</link><guid isPermaLink="true">https://forum.mysensors.org/post/102980</guid><dc:creator><![CDATA[ESFnl]]></dc:creator><pubDate>Sun, 29 Dec 2019 13:27:41 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3 with Domoticz and RF-link (RFXcom) &#x27;TSP-fail&#x27; on Sun, 29 Dec 2019 12:23:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/esfnl" aria-label="Profile: esfnl">@<bdi>esfnl</bdi></a> mySensors support for rfxcom is unofficial and receive only, so I wouldn't try to use it to setup a MySensors network.</p>
<p dir="auto">The !TSM:INIT:TSP FAIL message indicates a communication error to the radio module. Triple check wiring and pin configuration.</p>
]]></description><link>https://forum.mysensors.org/post/102978</link><guid isPermaLink="true">https://forum.mysensors.org/post/102978</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sun, 29 Dec 2019 12:23:48 GMT</pubDate></item></channel></rss>
