<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ESP8266 Gateway with local sensors stuck in loop]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">I previously had this sketch working fine with a local sensor on Arduino Uno. I want to move to NodeMCU for the sake of simplicity.</p>
<p dir="auto">I have loaded the sketch that worked previosuly on the Ardunio onto the NodeMCU and it is stuck in the infinite loop. I suspect this has something to do with sleep not working?</p>
<p dir="auto">Here is the code:</p>
<pre><code>//Set NODE ID
#define MY_NODE_ID 0
#define MY_BAUD_RATE 9600
//#define MY_RADIO_RF24
//#define MY_RADIO_RFM95
#define MY_GATEWAY_ESP8266
#define MY_MQTT_PUBLISH_TOPIC_PREFIX "homeassistant-out"
#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "homeassistant-in"
// Set MQTT client id
// Enable these if your MQTT broker requires username/password
#define MY_MQTT_USER "####"
#define MY_MQTT_PASSWORD "#####"
// Set WIFI SSID and password
#define MY_WIFI_SSID "######"
#define MY_WIFI_PASSWORD "######!"
// passed to the DHCP server if not static.
#define MY_HOSTNAME "KITCHEN_MQTT_GW"
// MQTT broker ip address.
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 87, 179
//MQTT broker if using URL instead of ip address.
// #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
#define MY_PORT 1883
// Enable inclusion mode
//#define MY_INCLUSION_MODE_BUTTON_PIN D1
// Set blinking period
//#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
#include &lt;MySensors.h&gt;
#define CHILD_ID_PH_LOCAL 1   // Id of the sensor child
// Initialize motion message
MyMessage msg(CHILD_ID_PH_LOCAL, V_TRIPPED);
  sendSketchInfo("Kitchen Motion Sensor", "2.0");
  present(CHILD_ID_PH_LOCAL, S_MOTION);
  // Read digital motion value
  Serial.println(tripped);
  send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
  sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
</code></pre>
<p dir="auto">Any help you anyone can provide would be greatly appreciated.</p>
<p dir="auto">Thank You!</p>
]]></description><link>https://forum.mysensors.org/topic/10874/esp8266-gateway-with-local-sensors-stuck-in-loop</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 01:34:39 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10874.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Jan 2020 23:28:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ESP8266 Gateway with local sensors stuck in loop on Sun, 12 Jan 2020 18:56:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shadex12" aria-label="Profile: ShadeX12">@<bdi>ShadeX12</bdi></a><br />
Hello,</p>
<p dir="auto">maybe these links will provide the necessary background information to solve your problem:</p>
<p dir="auto">Basics about ESP8266 sleep modes:</p>
<p dir="auto"><a href="https://www.losant.com/blog/making-the-esp8266-low-powered-with-deep-sleep" rel="nofollow ugc">https://www.losant.com/blog/making-the-esp8266-low-powered-with-deep-sleep</a></p>
<p dir="auto">Extensive discussion of this topic:</p>
<p dir="auto"><a href="https://github.com/esp8266/Arduino/issues/1488" rel="nofollow ugc">https://github.com/esp8266/Arduino/issues/1488</a></p>
<p dir="auto">Especially this citation might be interesting:</p>
<p dir="auto">"GPIO16 is connected to CH_DP for deepSleep.<br />
and pulled low during deepSleep.<br />
if CH_DP goes high the chip wakes up.<br />
for what reason the high signal comes from does not mater.<br />
can be the RTC timer or any other electrical stuff connected to CH_DP.<br />
so adding a pullup to CH_DP and a switch that is normally close to GPIO16 will work fine."</p>
<p dir="auto">Excellent summary, how to work with interrupts in general on the ESP8266:</p>
<p dir="auto"><a href="https://techtutorialsx.com/2016/12/11/esp8266-external-interrupts/" rel="nofollow ugc">https://techtutorialsx.com/2016/12/11/esp8266-external-interrupts/</a></p>
<p dir="auto">Good luck with your project.</p>
<p dir="auto">Karl-Heinz</p>
]]></description><link>https://forum.mysensors.org/post/103201</link><guid isPermaLink="true">https://forum.mysensors.org/post/103201</guid><dc:creator><![CDATA[Karl-Heinz K]]></dc:creator><pubDate>Sun, 12 Jan 2020 18:56:07 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 Gateway with local sensors stuck in loop on Sat, 11 Jan 2020 19:49:29 GMT]]></title><description><![CDATA[<p dir="auto">Now you are sending the message every second, even if the state didn't change.<br />
If you check to the previous state, and then send when the state changed it would be more efficient</p>
]]></description><link>https://forum.mysensors.org/post/103179</link><guid isPermaLink="true">https://forum.mysensors.org/post/103179</guid><dc:creator><![CDATA[electrik]]></dc:creator><pubDate>Sat, 11 Jan 2020 19:49:29 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 Gateway with local sensors stuck in loop on Thu, 09 Jan 2020 21:18:11 GMT]]></title><description><![CDATA[<p dir="auto">After surfing around the web a bit I eventually came up with this:</p>
<pre><code>
  long state = digitalRead(DIGITAL_INPUT_SENSOR);
    if(state == HIGH) {
      Serial.println("Motion detected!");
      send(msg.set("1"));
      delay(1000);
    else {
      Serial.println("Motion absent!");
      send(msg.set("0"));
      delay(1000);
</code></pre>
<p dir="auto">This seems to be working fine.</p>
]]></description><link>https://forum.mysensors.org/post/103159</link><guid isPermaLink="true">https://forum.mysensors.org/post/103159</guid><dc:creator><![CDATA[ShadeX12]]></dc:creator><pubDate>Thu, 09 Jan 2020 21:18:11 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 Gateway with local sensors stuck in loop on Thu, 09 Jan 2020 20:50:25 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply.</p>
<p dir="auto">I removed sleep and added wait instead. Now it just seems to output a sensor as tripped regardless of what is going on. It seems like it is not reading the state from the pin.</p>
<pre><code>void loop()
  wait(5000);
</code></pre>
<p dir="auto">Here is the serial output:</p>
<pre><code>143021 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
148086 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
153151 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
158216 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
163281 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
168346 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
173411 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
178476 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
183541 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
188606 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
193671 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
198736 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
</code></pre>
<p dir="auto">Any ideas?</p>
]]></description><link>https://forum.mysensors.org/post/103158</link><guid isPermaLink="true">https://forum.mysensors.org/post/103158</guid><dc:creator><![CDATA[ShadeX12]]></dc:creator><pubDate>Thu, 09 Jan 2020 20:50:25 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 Gateway with local sensors stuck in loop on Thu, 09 Jan 2020 07:45:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shadex12" aria-label="Profile: ShadeX12">@<bdi>ShadeX12</bdi></a> yyes you are correct. Esp8266 only supports sleeping by resetting the mcu, which means it would start fresh after every sleep (instead of continuing on he next line after sleep).</p>
]]></description><link>https://forum.mysensors.org/post/103148</link><guid isPermaLink="true">https://forum.mysensors.org/post/103148</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Thu, 09 Jan 2020 07:45:01 GMT</pubDate></item></channel></rss>
