<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Serial Monitor: Reversed question marks when on battery]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am creating my first sensor using a easypcb. It has two reed switches, one on D3 and the other on D8 (via an IRS).</p>
<p dir="auto">When I power the sensor from an USB port the output in the serial monitor looks fine, but when I power it via battery (2 AA rechargables, 2.6v in total) the output contains reversed question marks:</p>
<pre><code>12:45:04.443 -&gt;  __  __       ____
12:45:04.443 -&gt; |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
12:45:04.443 -&gt; | |\/| | | | \__⸮ \ / _ \ `_ \/ __|/ _ \| `__/ __|
12:45:04.443 -&gt; | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
12:45:04.443 -&gt; |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
12:45:04.476 -&gt;         |___/                      2.3.2
12:45:04.476 -&gt;
12:45:04.476 -&gt; 16 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,RE⸮=255,VER=2.3.2
12:45:04.476 -&gt; 28 T⸮M:INIT
12:45:04.476 -&gt; 28 TSF:WUR:MS=0
12:45:04.476 -&gt; 32 TSM:INIT:TSP OK
12:45:04.476 -&gt; 34 TS⸮:INI⸮:ST⸮TID=1
12:45:04.476 -&gt; 36 TSF:SID:OK,ID=1
12:45:04.476 -&gt; 38 TSM:FPAR
12:45:04.476 -&gt; 43 ?TSF:MSG:SEND,1-1-255-255,s=255,⸮=3,t=7,pt=0,l=0,⸮g=0,⸮t=0,st=OK:
12:45:06.499 -&gt; 2052 !TSM:FPAR:NO REPLY
</code></pre>
<p dir="auto">This has been soldered to the PCB:</p>
<ul>
<li>Arduino Pro Mini 3v<br />
RFM69HW<br />
Antenna<br />
//Battery Measurement<br />
1M Ohm<br />
470k Ohm<br />
1uF Capacitor<br />
//Booster<br />
Step up Booster(to 3v)<br />
1uF Capacitor</li>
</ul>
<p dir="auto">Does that mean the booster is broken? Or did I use the wrong capacitor size? The easypcb says 0.1uF but I only had 1uF capacitors and I hoped it would work.</p>
]]></description><link>https://forum.mysensors.org/topic/10881/serial-monitor-reversed-question-marks-when-on-battery</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 02:20:49 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10881.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Jan 2020 11:51:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Serial Monitor: Reversed question marks when on battery on Mon, 13 Jan 2020 17:00:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kiesel" aria-label="Profile: kiesel">@<bdi>kiesel</bdi></a> said in <a href="/post/103203">Serial Monitor: Reversed question marks when on battery</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a> thanks, what could be the reason for them?</p>
</blockquote>
<p dir="auto">Baud rate could be slightly off, or crappy connections,or ....</p>
<blockquote>
<p dir="auto">And by xomms you mean Serial, not the rfm69, right?</p>
</blockquote>
<p dir="auto">Correct</p>
]]></description><link>https://forum.mysensors.org/post/103215</link><guid isPermaLink="true">https://forum.mysensors.org/post/103215</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Mon, 13 Jan 2020 17:00:20 GMT</pubDate></item><item><title><![CDATA[Reply to Serial Monitor: Reversed question marks when on battery on Sun, 12 Jan 2020 20:40:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a> thanks, what could be the reason for them? And by xomms you mean Serial, not the rfm69, right?</p>
]]></description><link>https://forum.mysensors.org/post/103203</link><guid isPermaLink="true">https://forum.mysensors.org/post/103203</guid><dc:creator><![CDATA[kiesel]]></dc:creator><pubDate>Sun, 12 Jan 2020 20:40:51 GMT</pubDate></item><item><title><![CDATA[Reply to Serial Monitor: Reversed question marks when on battery on Sun, 12 Jan 2020 16:27:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kiesel" aria-label="Profile: kiesel">@<bdi>kiesel</bdi></a> said in <a href="/post/103187">Serial Monitor: Reversed question marks when on battery</a>:</p>
<blockquote>
<p dir="auto">/edit: There are less reversed question marks now, but there are still some.</p>
</blockquote>
<p dir="auto">There should be no illegal characters at all. Looks like there's still a comm issue.</p>
]]></description><link>https://forum.mysensors.org/post/103199</link><guid isPermaLink="true">https://forum.mysensors.org/post/103199</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sun, 12 Jan 2020 16:27:34 GMT</pubDate></item><item><title><![CDATA[Reply to Serial Monitor: Reversed question marks when on battery on Sun, 12 Jan 2020 12:38:04 GMT]]></title><description><![CDATA[<p dir="auto">Well, it seems the problem might have been that the booster capacitor was touching the booster.</p>
<p dir="auto">Only problem left is a lot of NACKs, but I will create a different topic for that.</p>
]]></description><link>https://forum.mysensors.org/post/103187</link><guid isPermaLink="true">https://forum.mysensors.org/post/103187</guid><dc:creator><![CDATA[kiesel]]></dc:creator><pubDate>Sun, 12 Jan 2020 12:38:04 GMT</pubDate></item></channel></rss>
