<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[W5100 Ethernet Gateway in Release 2.5.0-1]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I hope I don't open a new thread for an already fixed Problem, but after searching for hours in the GW threads I don't found a similar problem.</p>
<p dir="auto">The problem: I would like to use the <a href="http://Eth.GW" rel="nofollow ugc">Eth.GW</a> just as Node with no radio attached so I used the GatewayW5100 sketch, commented all radios and defined a controller address with DHCP enabled.<br />
In presentation I send  a sketch info and a motion sensor.<br />
When the sketch starts I see in the debug console the assigned IP address and after that the sketch hangs.<br />
In the Wireshark log I can see the DHCP assignment and after that IP-connect messages between the gateway and the controller but no sketch info message from GW to the controller.</p>
<p dir="auto">Changed the sketch to GatewayW5100MQTTClient with the same settings every thing works as  expected i.e. DHCP is assigned, IP-Link is established and after that GW and controller exchange Data (info and sensor) asked by the controller.</p>
<p dir="auto">I also tried UPEthernet.h, and ethernet2.h without any change.<br />
So I hope anybody could give me hint what's wrong.</p>
<p dir="auto">Thanks in advance for a reply.</p>
]]></description><link>https://forum.mysensors.org/topic/10915/w5100-ethernet-gateway-in-release-2-5-0-1</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 06:19:39 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10915.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Jan 2020 14:33:31 GMT</pubDate><ttl>60</ttl></channel></rss>
