<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Small multifunctional battery powered (AAA and CR2032) pcb (NRF24 + RFM69)]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">in order to facilitate the development of any kind of battery powered sensors (or actuators), I have designed this small pcb that can be easily placed in a 3d printable case</p>
<p dir="auto"><img src="/assets/uploads/files/1581167892601-rear.jpg" alt="rear.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1581167892604-front.jpg" alt="front.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">The main features are:</p>
<ul>
<li>
<p dir="auto">Small dimensions: 55 x 35 mm</p>
</li>
<li>
<p dir="auto">Multiple power options: 2 x AAA batteries or 1xAAA battery (Rechargeable or Alkaline), 1 x CR2032 battery, standard cellphone charger at 5V through the micro USB port or through Vin and GND pin of the MYSX connector</p>
</li>
<li>
<p dir="auto">Reverse polarity protection (Mosfet Q1) to prevent damages in case of wrong batteries insertion.<br />
Boost converter (ME2188C33) to increase the battery voltage to 3.3V when necessary</p>
</li>
<li>
<p dir="auto">LEDs for radio traffic and low batteries signaling. All configurable in the firmware.</p>
</li>
<li>
<p dir="auto">Multiple radio module supported: NRF24L01 (SMD and THT) and RFM69.</p>
</li>
<li>
<p dir="auto">Footprint for a reed switch</p>
</li>
<li>
<p dir="auto">MYSX connector v.2.6</p>
</li>
<li>
<p dir="auto">Support for ATSHA204 chip (security and signing)<br />
Mounting hole for a M2.5 screw</p>
</li>
</ul>
<p dir="auto">Probably in this days the ATMega-328P is a sort of "old" technology but for simple battery powered devices it remains a good option, also for its easy of use.</p>
<p dir="auto">If someone is interested, all the informations and the links to technical files (kicad project, gerber, schematics, firmware, etc) are in the <a href="https://wiki.d-diot.com/hardware/pcb/mysensors/mini-bt-pcb-328p" rel="nofollow ugc">dedicated wiki page</a> of the <a href="https://www.d-diot.com/" rel="nofollow ugc">d-diot project</a>.</p>
]]></description><link>https://forum.mysensors.org/topic/10935/small-multifunctional-battery-powered-aaa-and-cr2032-pcb-nrf24-rfm69</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 11:55:52 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/10935.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Feb 2020 13:26:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Small multifunctional battery powered (AAA and CR2032) pcb (NRF24 + RFM69) on Sun, 23 Feb 2020 17:22:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skywatch" aria-label="Profile: skywatch">@<bdi>skywatch</bdi></a> Thnaks! :+1:</p>
<p dir="auto">The main goal  of this board is to offer a simple way to build any kind (RFM69 and NRF24 support, MYSX connector) of compact battery powered node.</p>
<p dir="auto">Today I have finished the first node based on this board: a door window sensor (reed switch).</p>
<p dir="auto"><img src="/assets/uploads/files/1582478511195-20200223_175502.jpg" alt="20200223_175502.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">If someone is interested, <a href="https://wiki.d-diot.com/sensors_and_actuators/mysensors/door_window_sensor" rel="nofollow ugc">here</a> the detailed build instructions.</p>
<p dir="auto">The next node based on this board will be a soil moisture sensor!</p>
]]></description><link>https://forum.mysensors.org/post/103957</link><guid isPermaLink="true">https://forum.mysensors.org/post/103957</guid><dc:creator><![CDATA[franz-unix]]></dc:creator><pubDate>Sun, 23 Feb 2020 17:22:56 GMT</pubDate></item><item><title><![CDATA[Reply to Small multifunctional battery powered (AAA and CR2032) pcb (NRF24 + RFM69) on Sat, 08 Feb 2020 14:51:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/franz-unix" aria-label="Profile: franz-unix">@<bdi>franz-unix</bdi></a> Very nice job! :)</p>
<p dir="auto">I only had a quick look over the schematics, but it looks very promising from what I have seen.<br />
Well done.</p>
]]></description><link>https://forum.mysensors.org/post/103671</link><guid isPermaLink="true">https://forum.mysensors.org/post/103671</guid><dc:creator><![CDATA[skywatch]]></dc:creator><pubDate>Sat, 08 Feb 2020 14:51:06 GMT</pubDate></item></channel></rss>
