<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Momentary output command to node]]></title><description><![CDATA[<p dir="auto">So I've been diving into my setup a bit more now, as my work schedule has lightened due to the state of the world. My question is, because I'm a dummy :) is I have the mysensors platform running on a UNO with  a relay shield. Now, in MyController, you can latch, and unlatch relay outputs, but there isnt anything to allow a momentary pushbutton action. Now, is this unattainable from MyController, and if it is, would MySensors sketch running at the node allow a lockout after x seconds of being asserted from the controller as on, so it reverts off, even if someone forgot to turn off the relay. Even better, I did see there is ack commands in MyController, so if the sketch only allowed the relay on for x seconds, the ack command could revert the controller to off state?</p>
]]></description><link>https://forum.mysensors.org/topic/11051/momentary-output-command-to-node</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 16:50:46 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11051.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Apr 2020 15:14:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Momentary output command to node on Wed, 01 Apr 2020 15:16:56 GMT]]></title><description><![CDATA[<p dir="auto">Also, ideally, moreso very necessary, the momentary needs to be sorta snappy, as I am planning on connecting to a starter circuit on the generator, so which is why i was thinking more at the node built into the sketch as opposed to the controller, due to lag times in data to/from node</p>
]]></description><link>https://forum.mysensors.org/post/104674</link><guid isPermaLink="true">https://forum.mysensors.org/post/104674</guid><dc:creator><![CDATA[fdlou147]]></dc:creator><pubDate>Wed, 01 Apr 2020 15:16:56 GMT</pubDate></item></channel></rss>
