<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[room&#x2F;air quality sensor]]></title><description><![CDATA[<p dir="auto">MySensors friends,</p>
<p dir="auto">I made a new post in response to this post <a href="https://forum.mysensors.org/topic/9290/air-quality-node">air quality node</a> , responding to a post from 2018 did not seem advisable to me.</p>
<p dir="auto">Due to other things, the MySensors project has stopped here for a while, but I have started again, and among other things I want to make a room sensor (humidity temperature air quality), which will integrate into the wall.<br />
Of course, that installation is not the problem, the big question is of course which sensor should I use?<br />
Or possibly which combination of sensors?</p>
<p dir="auto">I have now done a test with the BME680, but I also ran into calculating the IAQ, so the sensor seems to be a good choice if you look at the specs, but not if you want to integrate it yourself.<br />
or are templates already available for this?</p>
<p dir="auto">Another option is the CCS811, possibly together with a Temp / Hum sensor (Si7021 / BME280?).</p>
<p dir="auto">but maybe there are other and better options possible?</p>
<p dir="auto">I don't have to have a laboratory precision, it's just about being able to see what the air quality is (good / average / bad / dangerous)</p>
<p dir="auto">Preferably everything together with a pro mini and RS485.</p>
<p dir="auto">Thanks for contributing ideas.</p>
<p dir="auto">dzjr</p>
]]></description><link>https://forum.mysensors.org/topic/11078/room-air-quality-sensor</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Mar 2026 00:51:20 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11078.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Apr 2020 09:00:26 GMT</pubDate><ttl>60</ttl></channel></rss>
