<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SCT013 50A - Low current]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I'm using the basic config to read at serial monitor the current from my loads(resistive).<br />
The setup is an arduino UNO(Emonlib running) + SCT013-50A  with classic voltage divider+capacitor 10uF.<br />
I can see currents with good acuracy only above 1A, so its my question...<br />
How can I read currents like 30....100mA?<br />
Thanks in advance<br />
Cheers</p>
]]></description><link>https://forum.mysensors.org/topic/11130/sct013-50a-low-current</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 03:01:50 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11130.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Apr 2020 21:10:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SCT013 50A - Low current on Fri, 01 May 2020 01:39:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a>  thanks,<br />
I have ACS712 for 5 and 30A but it has 66mV/A, would be complicated to use it with arduino uno :/<br />
I will try to use a ct 5A + opamp like ina122 and try to read at least 100mA - 2.5A, after that I will read using the SCT model.</p>
]]></description><link>https://forum.mysensors.org/post/105353</link><guid isPermaLink="true">https://forum.mysensors.org/post/105353</guid><dc:creator><![CDATA[carlos sampaio]]></dc:creator><pubDate>Fri, 01 May 2020 01:39:20 GMT</pubDate></item><item><title><![CDATA[Reply to SCT013 50A - Low current on Thu, 30 Apr 2020 14:23:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/carlos-sampaio" aria-label="Profile: carlos-sampaio">@<bdi>carlos-sampaio</bdi></a> there are a number of alternative current sensors that could fit your application and are available on breakout modules, e.g. from AliExpress or EBay: ACS758, ACS712, INA219<br />
Maybe some of them can be sourced in Brazil.</p>
]]></description><link>https://forum.mysensors.org/post/105340</link><guid isPermaLink="true">https://forum.mysensors.org/post/105340</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Thu, 30 Apr 2020 14:23:32 GMT</pubDate></item><item><title><![CDATA[Reply to SCT013 50A - Low current on Thu, 30 Apr 2020 14:00:31 GMT]]></title><description><![CDATA[<p dir="auto">Hey,<br />
Thanks for that info, very interesting. But I think too complicated to get it here in Brazil.<br />
I had a new idea, will put here today or tomorrow because it depends from a answer of emonlib config.</p>
]]></description><link>https://forum.mysensors.org/post/105337</link><guid isPermaLink="true">https://forum.mysensors.org/post/105337</guid><dc:creator><![CDATA[carlos sampaio]]></dc:creator><pubDate>Thu, 30 Apr 2020 14:00:31 GMT</pubDate></item><item><title><![CDATA[Reply to SCT013 50A - Low current on Wed, 29 Apr 2020 17:05:00 GMT]]></title><description><![CDATA[<p dir="auto">I think you can try <a href="https://www.sparkfun.com/products/14544" rel="nofollow ugc">this</a></p>
]]></description><link>https://forum.mysensors.org/post/105323</link><guid isPermaLink="true">https://forum.mysensors.org/post/105323</guid><dc:creator><![CDATA[Puneit Thukral]]></dc:creator><pubDate>Wed, 29 Apr 2020 17:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to SCT013 50A - Low current on Wed, 29 Apr 2020 14:29:43 GMT]]></title><description><![CDATA[<p dir="auto">I just got some info about this sensor...it can't read low currents due it features of construction, the best accuracy would be +- 5-50A range.<br />
But I really need to read low currents like 100mA for example in my project :/<br />
If I use 2 arduino pins to read 2 non invasive CT's with different ranges probably the CT used to low current will be broke when the current gets high...like 20-30A.</p>
]]></description><link>https://forum.mysensors.org/post/105320</link><guid isPermaLink="true">https://forum.mysensors.org/post/105320</guid><dc:creator><![CDATA[carlos sampaio]]></dc:creator><pubDate>Wed, 29 Apr 2020 14:29:43 GMT</pubDate></item><item><title><![CDATA[Reply to SCT013 50A - Low current on Wed, 29 Apr 2020 06:42:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/carlos-sampaio" aria-label="Profile: carlos-sampaio">@<bdi>carlos-sampaio</bdi></a> said in <a href="/post/105300">SCT013 50A - Low current</a>:</p>
<blockquote>
<p dir="auto">SCT013</p>
</blockquote>
<p dir="auto">I would be interested to know this as well, but to my understanding - maybe it has something to do with resolution.  I had earlier used this <a href="https://tyler.anairo.com/projects/open-energy-monitor-calculator" rel="nofollow ugc">calculator</a> to calculate the value of resistors and capcitors for my 30A CT Clamp. But the calculator is no longer opening.</p>
<p dir="auto">There are lower capacity CT clamps available and perhaps those can measure smaller currents. It is possible that the mA current is smaller than the threshold to excite the coil inside it.</p>
]]></description><link>https://forum.mysensors.org/post/105302</link><guid isPermaLink="true">https://forum.mysensors.org/post/105302</guid><dc:creator><![CDATA[Puneit Thukral]]></dc:creator><pubDate>Wed, 29 Apr 2020 06:42:17 GMT</pubDate></item></channel></rss>
