<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TinyBME - ATTiny85 + NRF24l01 + BME280&#x2F;I2C]]></title><description><![CDATA[<p dir="auto">Hi.</p>
<p dir="auto">Just published current status of my work on ATTiny85 node with NRF24L01 and BME280 (4 pin I2C version) and want to share it here.</p>
<p dir="auto"><a href="https://github.com/rmrfus/tinybme" rel="nofollow ugc">https://github.com/rmrfus/tinybme</a></p>
<p dir="auto">TLDR -  It works! :)</p>
<p dir="auto">It is based on <a href="https://forum.mysensors.org/topic/10866/a-tiny-bme-node-bme280-on-attiny85">fabyte's work</a> and couple of other resources.</p>
<ul>
<li>NRF24L01 works from 3 pins - MOSI/MISO/SCK, keeping CE constantly high and multiplexing CE over SCK.</li>
<li>BME280 is connected via pins 3 and 4 on ATTiny85 and communicates over SoftWire</li>
<li>It works just fine from 18650 battery. Prolly should work from CR2032 too. Didn't test current consumption (yet).</li>
<li>Right now code is just 92 bytes under 8K limit - no space for conversions of units - I'm doing it at HASS.</li>
<li>There is neither free pins nor flash to report the battery status. Prolly some kind alarm on lost heartbeats is much as could be done in this situation.</li>
</ul>
<p dir="auto">In general I'm open for suggestions and improvement ideas.</p>
<p dir="auto"><img src="https://raw.githubusercontent.com/rmrfus/tinybme/master/images/TinyBME_overview.jpeg" alt="Breadboard" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/topic/11163/tinybme-attiny85-nrf24l01-bme280-i2c</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Apr 2026 00:16:11 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11163.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 May 2020 08:30:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TinyBME - ATTiny85 + NRF24l01 + BME280&#x2F;I2C on Sun, 09 Oct 2022 10:56:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/henkoegema" aria-label="Profile: henkoegema">@<bdi>henkoegema</bdi></a> said in <a href="/post/112568">TinyBME - ATTiny85 + NRF24l01 + BME280/I2C</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wim-oosterhof" aria-label="Profile: Wim-Oosterhof">@<bdi>Wim-Oosterhof</bdi></a> said in <a href="/post/110292">TinyBME - ATTiny85 + NRF24l01 + BME280/I2C</a>:</p>
<blockquote>
<p dir="auto">I was attracted to the idea of having a wireless hum/temp sensor and so I built this. I prototyped it on a breadboard, and I also soldered it on a PCB. I extended the antenna with a 8.3 cm wire.</p>
<p dir="auto">But I can't get it to work stable. Sometimes it works for many hours and sometimes only for one hour. And then it just hangs. A reset of the at85 sometimes helps, but most of the times I need to power it off and on again.</p>
<p dir="auto">I need it to work reliably for several weeks. Any suggestions ?</p>
</blockquote>
<p dir="auto">Have you got any suggestions?<br />
Did you get it to work stable?</p>
</blockquote>
<p dir="auto">Or have you abandoned the project?</p>
]]></description><link>https://forum.mysensors.org/post/113113</link><guid isPermaLink="true">https://forum.mysensors.org/post/113113</guid><dc:creator><![CDATA[henkoegema]]></dc:creator><pubDate>Sun, 09 Oct 2022 10:56:21 GMT</pubDate></item><item><title><![CDATA[Reply to TinyBME - ATTiny85 + NRF24l01 + BME280&#x2F;I2C on Tue, 12 Jul 2022 11:58:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wim-oosterhof" aria-label="Profile: Wim-Oosterhof">@<bdi>Wim-Oosterhof</bdi></a> said in <a href="/post/110292">TinyBME - ATTiny85 + NRF24l01 + BME280/I2C</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.mysensors.org/post/112568</link><guid isPermaLink="true">https://forum.mysensors.org/post/112568</guid><dc:creator><![CDATA[henkoegema]]></dc:creator><pubDate>Tue, 12 Jul 2022 11:58:32 GMT</pubDate></item><item><title><![CDATA[Reply to TinyBME - ATTiny85 + NRF24l01 + BME280&#x2F;I2C on Thu, 20 May 2021 09:56:50 GMT]]></title><description><![CDATA[<p dir="auto">I was attracted to the idea of having a wireless hum/temp sensor and so I built this. I prototyped it on a breadboard, and I also soldered it on a PCB. I extended the antenna with a 8.3 cm wire.</p>
]]></description><link>https://forum.mysensors.org/post/110292</link><guid isPermaLink="true">https://forum.mysensors.org/post/110292</guid><dc:creator><![CDATA[Wim Oosterhof]]></dc:creator><pubDate>Thu, 20 May 2021 09:56:50 GMT</pubDate></item><item><title><![CDATA[Reply to TinyBME - ATTiny85 + NRF24l01 + BME280&#x2F;I2C on Thu, 21 May 2020 08:59:35 GMT]]></title><description><![CDATA[<p dir="auto">Great achievement, congratulations :+1: :)</p>
<p dir="auto">I like that you also tried Nerd Ralph's 3-Pin configuration and got it to work. I tried it once but somehow it didn't connect to the radio, so discarded this idea. Also I thought it might be cheaper (from a memory point of view), just to use one bus. Nice work on stuffing all this in 8K :)</p>
<p dir="auto">It would be great if you reported in a couple of weeks how stable it's running. Did you have a chance to measure the power consumption of the hole system?</p>
]]></description><link>https://forum.mysensors.org/post/105715</link><guid isPermaLink="true">https://forum.mysensors.org/post/105715</guid><dc:creator><![CDATA[fabyte]]></dc:creator><pubDate>Thu, 21 May 2020 08:59:35 GMT</pubDate></item></channel></rss>
