[Solved] Arduino Nanos don't work as nodes
  • My issue is rather simple, no matter what I do, Arduino Nano nodes are unable to act as nodes.
    I have a working pair of an Arduino Nano based GW and an Arduino Mega 2560 based node.
    I have:
    • Switched the radios between the nodes, the same radios that work on the GW and the Mega work on each other.
    • Tried PA+LNA and two different regular nRF24 boards (no, not the COB ones)
    • Built three new boards to plug the radio and the Nano into -
    • Tried 1uF, 10uF and 470uF decoupling all separately
    • Tried both with and without MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC
    • Tried with and without MY_TRANSPORT_WAIT_READY_MS
    • I wiped the EEPROM of all the devices
    • Tried an external 3.3V regulator
    • With both the old and new Nano bootloader
    • Multiple Nano boards
    • Downloaded newer Arduino IDE and newest MySensors
    • Switched channel and tried different power levels
    But the node still either outputs:
    16 MCO:BGN:INIT REPEATER,CP=RNNRA---,FQ=16,REL=255,VER=2.3.2
    27 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:INIT:STATID=1
    38 TSF:SID:OK,ID=1
    40 TSM:FPAR
    45 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2052 !TSM:FPAR:NO REPLY
    2054 TSM:FPAR
    2058 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4065 !TSM:FPAR:NO REPLY
    4067 TSM:FPAR
    4071 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6078 !TSM:FPAR:NO REPLY
    6080 TSM:FPAR
    6084 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8091 !TSM:FPAR:FAIL
    8092 TSM:FAIL:CNT=1
    8094 TSM:FAIL:DIS
    8096 TSF:TDI:TSL
    18098 TSM:FAIL:RE-INIT
    18100 TSM:INIT
    18106 TSM:INIT:TSP OK
    18108 TSM:INIT:STATID=1
    18111 TSF:SID:OK,ID=1
    18113 TSM:FPAR
    18117 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20124 !TSM:FPAR:NO REPLY
    20126 TSM:FPAR
    or with MY_TRANSPORT_WAIT_READY_MS:
    16 MCO:BGN:INIT REPEATER,CP=RNNRAS--,FQ=16,REL=255,VER=2.3.2
    54 TSM:INIT
    58 TSF:WUR:MS=1
    64 TSM:INIT:TSP OK
    66 TSM:INIT:STATID=1
    68 TSF:SID:OK,ID=1
    69 TSM:FPAR
    70 TSM:FPAR:STATP=0
    72 MCO:BGN:INIT OK,TSP=0
    74 TSM:ID
    Sensor: 17
    76 !MCO:SND:NODE NOT REG
    79 MCO:SLP:MS=500,SMS=0,I1=255,M1=255,I2=255,M2=255
    84 !MCO:SLP:REP
    86 TSM:ID:OK
    87 TSM:UPL
    123 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    Sensor: 34
    586 !MCO:SND:NODE NOT REG
    589 MCO:SLP:MS=500,SMS=0,I1=255,M1=255,I2=255,M2=255
    594 !MCO:SLP:REP
    Node code:
    #define MY_REPEATER_FEATURE
    #define MY_TRANSPORT_SANITY_CHECK
    #define MY_SIGNAL_REPORT_ENABLED
    #define MY_RF24_CE_PIN     9
    #define MY_RF24_CS_PIN     10
    #define MY_RF24_CHANNEL   29
    #define RF24_DATARATE      RF24_2MBPS
    #define RF24_PA_LEVEL      RF24_PA_MIN
    #define RF24_PA_LEVEL_GW   RF24_PA_MIN
    #define MY_NODE_ID         1
    #define MY_PARENT_NODE_ID  0
    #define MY_TRANSPORT_WAIT_READY_MS 1
    uint32_t SLEEP_TIME = 500; // Sleep time between reads (in milliseconds)
    MyMessage msg(0, V_LIGHT_LEVEL);
      pinMode(A7, INPUT);
      Serial.begin(115200);
      sendSketchInfo("Basicsensor 1", "0.1");
      delay(10);
      present(0, S_LIGHT_LEVEL, F("Light level sensor"), true);
    uint16_t lightLevel = 0;
    uint16_t lastLightLevel = 0;
      lightLevel = analogRead(A7);
        Serial.print("Sensor: ");
        Serial.println(lightLevel);
        send(msg.setSensor(0).setType(V_LIGHT_LEVEL).set(lightLevel));
        lastLightLevel = lightLevel;
      sleep(SLEEP_TIME);
    I now suspect there's a bug somewhere in MySensors introduced by some newer version affecting Arduino Nanos. Because I remember MySensors working on Nanos a while ago.
    Maybe someone here has some ideas how to narrow the issue down?
  • Plugin Developer
    I created a new gateway on an Arduino Nano today, and that worked. Not sure if that was using the very latest MySensors though. The rest of my network is all based on the RF-Nano, which I'm a big fan of. It shields me from exactly these types of issues 🙂
    How are you powering them?
    The Nano itself runs on 5v, but I suspect you know that.
    Have you tried enabling the advanced radio debug option? (I forget it's name). That can magicaly enable things sometimes. At the very least it will tell you more about what's going on.
    Are you sure there's nothing like encrpytion on the gateway?
    Have you tried replacing all the wires between the nano and the radio module?
    I recommend just buying the Arduino Nano Wireless Expansion Board. They cost a dollar on Aliexpress.
    Maybe you have some of those fake Atmel chips?
  • Plugin Developer
    pinMode(A7, INPUT); should not be in presentation. It should be in setup. Similarly, don't put Serial.begin(115200); in there. All that should be in presentation function is sendSketchInfo and present.
    Also, don't use "delay", use wait() instead.
    And where is your setup function in the first place?
  • Plugin Developer
    Also, your code never loads MySensors? It's commented out?
    Your node code is very strange.
  • @alowhum said in Arduino Nanos don't work as nodes:
    USB, tried a wall-wart and two different PCs.
    Yes, it's the default gateway sketch, except configured to use the right channel, data rate and nRF24.
    Yeah, I have multiple boards, some years old and have worked with other nRF24 projects. Plus, any wiring changes actually break it for things such as RF24.
    I'll look into that.
    Three of them bought at different times, and the only issues are with MySensor? 😛 Seems unlikely.
  • Also, your code never loads MySensors? It's commented out?
    Um, line 22 #include <MySensors.h>
    It was of the examples, barely modified.
  • Plugin Developer
    @Avamander said in Arduino Nanos don't work as nodes:
    Ah, you're right. Have been programming in other languages lately, where that indicates a comment.
  • Plugin Developer
    Is there a reason you're swapping your CE and CS pins?
    Because they're wired that way and it doesn't/shouldn't matter.
  • Plugin Developer
    What happens if you remove everything but the essentials for your network here?
    Maybe only leave #define MY_RF24_CHANNEL 29?
  • Plugin Developer
    Look for something like MY_DEBUG_VERBOSE_NRF24 - something along those lines, for that debug option I mentioned.
  • @alowhum
    #define MY_DEBUG_VERBOSE_RF24
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    29 RF24:INIT:PIN,CE=9,CS=10
    31 RF24:SBY
    32 RF24:WBR:REG=0,VAL=14
    39 RF24:WBR:REG=3,VAL=3
    41 RF24:WBR:REG=4,VAL=95
    44 RF24:WBR:REG=5,VAL=29
    47 RF24:WBR:REG=6,VAL=37
    49 RF24:WBR:REG=29,VAL=4
    51 RF24:RBR:REG=29,VAL=4
    53 RF24:RBR:REG=6,VAL=37
    55 RF24:RBR:REG=5,VAL=29
    58 RF24:WBR:REG=2,VAL=2
    60 RF24:WBR:REG=1,VAL=0
    62 RF24:WBR:REG=28,VAL=3
    64 RF24:FRX
    65 RF24:FTX
    66 RF24:WBR:REG=7,VAL=112
    69 TSM:INIT:TSP OK
    70 TSM:INIT:STATID=1
    72 RF24:WBR:REG=2,VAL=3
    74 RF24:WBR:REG=1,VAL=1
    76 RF24:STL
    78 RF24:WBR:REG=0,VAL=15
    80 RF24:WBR:REG=10,VAL=1
    82 TSF:SID:OK,ID=1
    84 TSM:FPAR
    86 RF24:SPL
    87 RF24:WBR:REG=0,VAL=14
    89 RF24:OWP:RCPT=255
    91 RF24:WBR:REG=10,VAL=255
    93 RF24:WBR:REG=16,VAL=255
    96 RF24:TXM:TO=255,LEN=7
    98 RF24:FTX
    99 RF24:WBR:REG=4,VAL=80
    103 RF24:WBR:REG=7,VAL=112
    106 ?RF24:TXM:MAX_RT
    108 RF24:FTX
    109 RF24:WBR:REG=4,VAL=95
    111 RF24:STL
    113 RF24:WBR:REG=0,VAL=15
    115 RF24:WBR:REG=10,VAL=1
    2125 !TSM:FPAR:NO REPLY
    2127 TSM:FPAR
    2128 RF24:SPL
    2130 RF24:WBR:REG=0,VAL=14
    2132 RF24:OWP:RCPT=255
    2135 RF24:WBR:REG=10,VAL=255
    2138 RF24:WBR:REG=16,VAL=255
    2140 RF24:TXM:TO=255,LEN=7
    2143 RF24:FTX
    2144 RF24:WBR:REG=4,VAL=80
    2149 RF24:WBR:REG=7,VAL=112
    2151 ?RF24:TXM:MAX_RT
    2153 RF24:FTX
    2155 RF24:WBR:REG=4,VAL=95
    2157 RF24:STL
    2158 RF24:WBR:REG=0,VAL=15
    2161 RF24:WBR:REG=10,VAL=1
    2163 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4171 !TSM:FPAR:NO REPLY
    4173 TSM:FPAR
    4174 RF24:SPL
    4175 RF24:WBR:REG=0,VAL=14
    4178 RF24:OWP:RCPT=255
    4180 RF24:WBR:REG=10,VAL=255
    4184 RF24:WBR:REG=16,VAL=255
    4186 RF24:TXM:TO=255,LEN=7
    4189 RF24:FTX
    4190 RF24:WBR:REG=4,VAL=80
    4195 RF24:WBR:REG=7,VAL=112
    4197 ?RF24:TXM:MAX_RT
    4199 RF24:FTX
    4201 RF24:WBR:REG=4,VAL=95
    4203 RF24:STL
    4204 RF24:WBR:REG=0,VAL=15
    4207 RF24:WBR:REG=10,VAL=1
    4209 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6217 !TSM:FPAR:NO REPLY
    Still no reply.
  • I'm not super experienced using mysensors but I do have 3 nodes working and when first settings things up I had some problems with NODE IDs. It looks like you are setting a Static node Id? Is that ID "free" in the gateway? Have you tried powering of all the nodes you have running, wiping the EEPROM of the gateway, powering up the gateway and shortly after powering up the node?
    Someone else perhaps knows this better but, if the gateway don't want to include the node, does that generate the FPAR:No reply?
    And also, how is the interrupt pin connected?
  • I use Arduinos all the time and have problem with them.
    I suggest to start with one of the examples.
    The RF channel is the same everywhere I guess?
    What does the output on the gateway say?
  • @niclas
    Yes, there are no other nodes (other than the one with a different static node ID that works)
    Yes.
    Yes, I've wiped EEPROMs of all the nodes.
  • @Avamander I meant, have you erased the EEPROM of the gateway?
  • @niclas
    Yes, that too.
    The radio's IRQ pin is not connected. (The IRQ pin is only required to be connected if the MY_RX_MESSAGE_BUFFER_FEATURE is defined in the sketch.)
  • @Avamander Regarding the interrupt pin, at least when using the RFM95 I need to have the pin connected to be able to receive anything. It doesnt poll the module to check for incoming messages. Maybe its different with nRF24.
    I haven't tried messing with the MY_RX_MESSAGE_BUFFER_FEATURE so I wouldnt know about that.
  • @niclas
    Well, the documentation says I don't have to have it connected.
    @electrik
    The gateway and node both are examples with the minimal required changes.
    Yes.
    Nothing, totally silent. When I plug in the Mega node, then it starts outputting all the sensor and other data.
    Anyways, the weird thing here is that I remember this working a few years or so ago on the same boards and stuff, it just doesn't work now and I have 0 clue why. I'm thinking about downgrading MySensors to 1.something
  • @Avamander Found the documentation you were referring to and yes. Seems to be true for the RF24 which I haven't used in a long time.
    #define MY_RX_MESSAGE_BUFFER_FEATURE
    This enables the receiving buffer feature.
    This feature is currently not supported for anything but RF24. Require MY_RF24_IRQ_PIN to be set.
    Note: Not supported on ESP8266, ESP32, STM32, nRF5 and sketches that use SoftSPI. See below issue for details https://github.com/mysensors/MySensors/issues/1128
    Definition at line 2406 of file MyConfig.h.
  • I don't think this is a software issue. More likely your NRF24 is failing.
  • @electrik It's highly unlikely. I have more than one type of module and more than one module of each type, none of them work. I also swapped the modules between working GW and Mega node and it still works, I swap the module between working GW and the node, it doesn't work.
  • Could you try version 2.2 of mysensors? I remember summer changes in 2.4 regarding nrf modules
  • @electrik :
    I went to the oldest available version and it doesn't work.
    I don't really get it, if I swap the radios between the Mega node and the Nano node, it stops working, swapping CE/CSN also makes it stop working - any alterations make it fail loud and clear.
    It does initialize the radio and claim everything is okay. I can be quite certain it's not the radios, it's not the boards themselves, it's not the wiring.
    There's something very specific to the Nanos themselves that 2.x.x is unable to use the nRF24L01+.
    I will assemble an Arduino Uno board and see if the issue is specific to the AtMega328P.
  • I also ran the full "test" suite of RF24 and all examples work great, so I am very certain communication is likely to be very good.
    It's just that something makes MySensors not like it.
  • Just in case I also took clean RepeaterNode example and just defined the CE/CSN pins and channel, it's still unable to work.
    I also tried the same example without any repeater functionality enabled, it's still unable to register. It's basically a blank sketch.
    Changing Node ID didn't also work.
  • In your first sketch the baud rate was 2mbps. How is your existing network configured?
    If you take an example sketch and an example gateway sketch, does it work then. So don't change channels and so on
    That's exactly the same across all my sketches.
    Yeah, I did that and wrote about it above, took RepeaterNode and just defined CE/CSN on GW and the node.
  • I've determined that it doesn't matter which:
    • Radio
    • Radio's power supply/source
    • Nano
    • Bootloader
    • Arduino IDE (tried 1.8.2 and latest nightly)
    • 2.x.x MySensors
    • Example, or custom sketch
    • Channel, data rate, power level or node ID
    • Repeater or not
    • WAIT_READY_MS or not
    • Predefined master or not
    • SPI bus speed, 0.5*default SPI speed didn't help
    I just can't make a Nano act as a regular node.
    Maybe a MySensors dev has an idea what I could try.
  • I'm going to finish my Arduino Uno node and if that too doesn't work getting MyController to work must take some goat sacrifice because I can't do it.
  • I just discovered that on the Arduino Uno RF24_250KBPS works, but RF24_2MBPS doesn't. On the Nanos, neither work.
    I used RF24 and tested the boards for a while, I've determined that 2MBPS on that specific channel works great, I've sent at least 100 000 packets and lost only two. Auto-ack and dynamic payloads also work.
    I am 99.99% certain this is a bug in MySensors. @mfalkvidd maybe you have some ideas where to look next?
  • Mod
    @Avamander nano's are basically just regular atmega328 boards, running off 5v at 16MHz. The MySensors stack doesn't know if it is running on a nano, uno or pro mini, so why are you so certain this is a bug in the stack?
    What I do know is that a lot of low quality nanos are available from Chinese sources, with bad ground planes or crappy power regulators.
    What nano boards do you use? Could you try a different atmega328 based arduino?
  • @Yveaux said in Arduino Nanos don't work as nodes:
    Because I'm really rather certain it isn't the hardware. You can read what I've replaced, swapped and tried. The radios have been decoupled, the power has been decoupled. The setup works in all possible ways when using RF24.
    Yeah, I said I tried an Uno and it exhibited pretty much the same symptoms when acting as a regular node.
  • Admin
    @Avamander Can you upload both, the GW and node sketches from the working pair nanoGW/megaNode? Also, it would be helpful to see the full GW log from the non-working combination (nanoNode/megaGW) with MY_DEBUG_VERBOSE_RF24 enabled. If time allows, I'd like to reproduce and test your setup.
  • @tekka
    Just to be clear, the Arduino Mega node (megaNode) can talk to the Arduino Nano gateway (nanoGW), but no Arduino Nano node (nanoNode) can talk to the Arduino Nano gateway.
    I'll post the sketches and logs.
  • Ah, I think cussing is warranted here, I copied the radio configuration from my old sketch to the new ones, the node had:
    The GW has:
    #define MY_RF24_DATARATE RF24_2MBPS
    Lesson learned: Never copy configuration from an existing older sketch, you never know what has been deprecated without a warning. MY_RADIO_NRF24 threw a warning and I fixed that, had no idea about RF24_DATARATE and I didn't notice it. 😅
  • Plugin Developer
    This thread reads like an Agathie Christie novel. Well done on finding it!
  • 87
  • 9
  • 8
  • 10
