<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Ethernet Gateway - how reliable is it? which problems and how to avoid?]]></title><description><![CDATA[<p dir="auto">HI All!</p>
<p dir="auto">i'm struggling to build the ethernet gateway, using the arduino nano v3.0, nrf24l01 and enc28j60.</p>
<p dir="auto">what i'm facing:</p>
<ul>
<li>fixed ip works, dhcp (commenting out the fixed ip) causes compilation error (arduino IDE)</li>
<li>having usb cable plugged to nano v3.0 to computer and power supply connected ping works.</li>
<li>disconnecting the usb cable, ping stops (power supply and ethernet connected)</li>
</ul>
<p dir="auto">Anyone have it working?<br />
What can you tell me about?<br />
Which problems are knowns?<br />
Is it reliable to be in production (work as expected, without extensive maintenence due errors, etc)?</p>
<p dir="auto">Those questions refers to my intention to have it working with minimal intervention once installed and configured, and i don't want to start a learning curve to spend lot of time supporting it.</p>
<p dir="auto">Thx for all help you may provide.</p>
]]></description><link>https://forum.mysensors.org/topic/11221/ethernet-gateway-how-reliable-is-it-which-problems-and-how-to-avoid</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 08:44:25 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11221.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Jun 2020 15:28:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Ethernet Gateway - how reliable is it? which problems and how to avoid? on Fri, 19 Jun 2020 16:54:36 GMT]]></title><description><![CDATA[<p dir="auto">I think you should stop spamming the same topic in a bunch of different threads.</p>
<p dir="auto">In fact, I think mods should merge and/or delete all these secondary threads, and possibly even warn.</p>
]]></description><link>https://forum.mysensors.org/post/106187</link><guid isPermaLink="true">https://forum.mysensors.org/post/106187</guid><dc:creator><![CDATA[TRS-80]]></dc:creator><pubDate>Fri, 19 Jun 2020 16:54:36 GMT</pubDate></item></channel></rss>
