<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Domoticz weather sensor presentation]]></title><description><![CDATA[<p dir="auto">I have created a weather sensor which has hum, temp, baro, predicition and lux.<br />
Aslo i have attached there another ds temp sensor (for node internal temp).<br />
Problem is that when i update fw over ota or reboot node, it'll occasionally detect sensors all mixed up:<br />
temp/hum, temp, baro/temp/hum etc... Also when it does that, not all the data will be updated on combined sensros.<br />
Is there a way to present the sensors to domticz so, that it recognises 1 combined weather sensor and then others.<br />
I have tried with all different Sensor ID's 1-4, lux id5 and internal temp id6.<br />
Also tried with giving same sensor ID number to hum, temp, baro and predicition.<br />
Domoticz detects it as a combined sensor, but it doesn't update all values after initial value has been sent.<br />
If i monitor the data on myscontroller, all the variables are updating on the node.</p>
]]></description><link>https://forum.mysensors.org/topic/11273/domoticz-weather-sensor-presentation</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 11:42:35 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11273.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Jul 2020 11:30:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Domoticz weather sensor presentation on Thu, 16 Jul 2020 09:52:23 GMT]]></title><description><![CDATA[<p dir="auto">I use a BME280 sensor for outside and some 18b20's for inside. Domoticz works with these without problems but I do not use OTA - not figured that out yet :disappointed_relieved: :laughing:  I had to cut out all the weather prediction code on for the BME280 to make it run on a pro mini 3.3 but Domoticz has basic prediction built in.</p>
]]></description><link>https://forum.mysensors.org/post/106717</link><guid isPermaLink="true">https://forum.mysensors.org/post/106717</guid><dc:creator><![CDATA[grumpazoid]]></dc:creator><pubDate>Thu, 16 Jul 2020 09:52:23 GMT</pubDate></item><item><title><![CDATA[Reply to Domoticz weather sensor presentation on Wed, 15 Jul 2020 00:49:28 GMT]]></title><description><![CDATA[<p dir="auto">I had a similar problem with weather sensors, but it was a while ago and Domoticz has been updated since then.<br />
I was presenting temp, hum, baro.  Domoticz always assumed it was a weather sensor if I presented the baro -- and the humidity wouldn't update.  It didn't matter if I used separate child IDs or the same one.<br />
I really only wanted temperature and humidity, so I quit presenting the baro and the Domoticz temp/hum has always worked well.<br />
I just assumed I was doing something wrong, but your problem sounds similar.  Maybe it's a Domoticz bug.</p>
]]></description><link>https://forum.mysensors.org/post/106679</link><guid isPermaLink="true">https://forum.mysensors.org/post/106679</guid><dc:creator><![CDATA[nagelc]]></dc:creator><pubDate>Wed, 15 Jul 2020 00:49:28 GMT</pubDate></item></channel></rss>
