<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RFM69 on one print board or on separate Rx and Tx prints?]]></title><description><![CDATA[<p dir="auto">Hi.<br />
I have a serial gateway working.</p>
<p dir="auto">My next step is creating nodes using RFM69/433MHz.<br />
On the mysensors site there is an (obsolete) AliExpress link to an RFM69 chip that has sender and receiver on the same print board.<br />
What I currently have in my drawer are 433 MHz chips where the sender and receiver are on separate print boards (e.g. <a href="https://www.aliexpress.com/item/4001148855756.html?spm=a2g0o.productlist.0.0.12023abf3WwfqH&amp;algo_pvid=8b48b8c5-f4a7-4148-9c76-522f77bb5bbb&amp;algo_expid=8b48b8c5-f4a7-4148-9c76-522f77bb5bbb-10&amp;btsid=0ab50f4415948924536708139e7ccc&amp;ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_" rel="nofollow ugc">https://www.aliexpress.com/item/4001148855756.html?spm=a2g0o.productlist.0.0.12023abf3WwfqH&amp;algo_pvid=8b48b8c5-f4a7-4148-9c76-522f77bb5bbb&amp;algo_expid=8b48b8c5-f4a7-4148-9c76-522f77bb5bbb-10&amp;btsid=0ab50f4415948924536708139e7ccc&amp;ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_</a>)</p>
<p dir="auto">Will these also work out of the box with the mysensors libraries (without me having rewrite most)?<br />
Or must I have the RFM69 where the sender and receiver are on the same print board?<br />
I would hate having to wait several months for new components to arrive from China, but as I am not able to rewrite the mysensors libraries myself, I realize I might end up having to do that.</p>
]]></description><link>https://forum.mysensors.org/topic/11280/rfm69-on-one-print-board-or-on-separate-rx-and-tx-prints</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 10:21:08 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11280.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Jul 2020 09:51:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RFM69 on one print board or on separate Rx and Tx prints? on Thu, 16 Jul 2020 10:32:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scalz" aria-label="Profile: scalz">@<bdi>scalz</bdi></a> Thanks.</p>
]]></description><link>https://forum.mysensors.org/post/106722</link><guid isPermaLink="true">https://forum.mysensors.org/post/106722</guid><dc:creator><![CDATA[Thomas433]]></dc:creator><pubDate>Thu, 16 Jul 2020 10:32:07 GMT</pubDate></item><item><title><![CDATA[Reply to RFM69 on one print board or on separate Rx and Tx prints? on Thu, 16 Jul 2020 10:34:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas433" aria-label="Profile: Thomas433">@<bdi>Thomas433</bdi></a><br />
indeed it is not synonymous. you can also find rfm69 868mhz or 915mhz depending on which region you live. (868 for EU, and 915 for USA for example). I personnaly use 868mhz because range is good enough for me, requires a smaller antenna and ground plane than 433 (lower freq bigger gnd plane, antenna performance and radiation dependant of gnd plane size which is a part of the antenna, if monopole/coil is used).<br />
But 433 has better penetration than 868 which in turn is better than 2.4ghz.</p>
]]></description><link>https://forum.mysensors.org/post/106721</link><guid isPermaLink="true">https://forum.mysensors.org/post/106721</guid><dc:creator><![CDATA[scalz]]></dc:creator><pubDate>Thu, 16 Jul 2020 10:34:42 GMT</pubDate></item><item><title><![CDATA[Reply to RFM69 on one print board or on separate Rx and Tx prints? on Thu, 16 Jul 2020 10:22:51 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/scalz" aria-label="Profile: scalz">@<bdi>scalz</bdi></a> for confirming what I suspected. It saves me (and maybe others) time by not going in the wrong direction with 433 MHz chips that are not RFM69.<br />
As a newbie, I thought RFM69 was synonymous with 433MHz communication in general. but I guess it is not.</p>
]]></description><link>https://forum.mysensors.org/post/106720</link><guid isPermaLink="true">https://forum.mysensors.org/post/106720</guid><dc:creator><![CDATA[Thomas433]]></dc:creator><pubDate>Thu, 16 Jul 2020 10:22:51 GMT</pubDate></item><item><title><![CDATA[Reply to RFM69 on one print board or on separate Rx and Tx prints? on Thu, 16 Jul 2020 10:03:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi.</p>
<p dir="auto">the radio modules you linked are not rfm69, nor compatible.<br />
Yes, you need to buy rfm69 modules. You can easily find them on aliexpress.</p>
<p dir="auto">Thx for reporting obsolete link.</p>
]]></description><link>https://forum.mysensors.org/post/106718</link><guid isPermaLink="true">https://forum.mysensors.org/post/106718</guid><dc:creator><![CDATA[scalz]]></dc:creator><pubDate>Thu, 16 Jul 2020 10:03:58 GMT</pubDate></item></channel></rss>
