<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Modifying a Raspberry Pi dislay]]></title><description><![CDATA[<p dir="auto">Hi All,<br />
I got this 5" raspberry pi display, XPT2046 Touch Controller. Currently it has a hardware backlight on/off switch and i'm looking to change that to be able to turn on and off the backlight using a script from raspberry pi.<br />
I am looking for an always on gate that i can control through a pin. My initial thought was to place a tranzistor, but not sure if that will work. Any other ideas ? how can i achieve this really simple and easy ?</p>
<p dir="auto"><img src="/assets/uploads/files/1595193539657-image1.jpeg" alt="image1.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1595193548389-image0.jpeg" alt="image0.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Regards<br />
Adrian.</p>
]]></description><link>https://forum.mysensors.org/topic/11284/modifying-a-raspberry-pi-dislay</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 11:03:55 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11284.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Jul 2020 21:19:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Modifying a Raspberry Pi dislay on Sun, 09 Aug 2020 07:06:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ady_e_n" aria-label="Profile: ady_e_n">@<bdi>ady_e_n</bdi></a> Presumably a low current DPDT switch.<br />
Since I have them anyway I'd  be using a latching DPDT signal relay fired by two logic level mosfets controlled by two pins, hence emulating the switch itself with no running current. The relays I have are NEC EE2-3TNU around 7mm thick and 9mm tall, 5v version should be available if that is your logic voltage level.<br />
If space permits you could hot glue the relay to the board on it's side with the mosfets/resistors/3 pin control mounted onto it's base, hard wired to the original switch pads.<br />
;)</p>
]]></description><link>https://forum.mysensors.org/post/107075</link><guid isPermaLink="true">https://forum.mysensors.org/post/107075</guid><dc:creator><![CDATA[zboblamont]]></dc:creator><pubDate>Sun, 09 Aug 2020 07:06:12 GMT</pubDate></item><item><title><![CDATA[Reply to Modifying a Raspberry Pi dislay on Sat, 08 Aug 2020 20:26:51 GMT]]></title><description><![CDATA[<p dir="auto">so, nobody can help me with this issue ?</p>
]]></description><link>https://forum.mysensors.org/post/107068</link><guid isPermaLink="true">https://forum.mysensors.org/post/107068</guid><dc:creator><![CDATA[ady_e_n]]></dc:creator><pubDate>Sat, 08 Aug 2020 20:26:51 GMT</pubDate></item></channel></rss>
