<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New ethernet gateway errors out on Home Assistant]]></title><description><![CDATA[<p dir="auto">Hardware: Arduino Nano + HR91105A Ethernet shield</p>
<p dir="auto">I am taking a stab at setting up a new ethernet gateway via the following sketch (build tutorial). I pick up an IP and can ping but HA displays errors (below the sketch) and does not complete setup (as my wireless only gateway does). Ideas where to look?</p>
<pre><code>* The MySensors Arduino library handles the wireless radio link and protocol
* Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
* Version 1.0 - Henrik Ekblad
* Contribution by a-lurker and Anticimex
* Contribution by Norbert Truchsess &lt;norbert.truchsess@t-online.de&gt;
* Contribution by Tomas Hozza &lt;thozza@gmail.com&gt;
* LED purposes:
* - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
* - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
* - ERR (red) - fast blink on error during transmission error or receive crc error
#define MY_RADIO_RF24
//#define MY_RADIO_NRF5_ESB
//#define MY_RADIO_RFM95
#define MY_GATEWAY_W5100
//#define MY_W5100_SPI_EN 4
// radio on the same spi bus.
#if !defined(MY_W5100_SPI_EN) &amp;&amp; !defined(ARDUINO_ARCH_SAMD)
#define MY_SOFTSPI
#ifndef MY_RF24_CE_PIN
#define MY_RF24_CE_PIN 5
#ifndef MY_RF24_CS_PIN
#define MY_RF24_CS_PIN 6
// Enable UDP communication
//#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
//#define MY_IP_ADDRESS 192,168,178,66
#define MY_PORT 5003
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
//#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
// Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
// Enable inclusion mode
// Set blinking period
// Flash leds on rx/tx/err
//#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
//#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
#if defined(MY_USE_UDP)
#include &lt;EthernetUdp.h&gt;
#include &lt;Ethernet.h&gt;
#include &lt;MySensors.h&gt;
</code></pre>
<p dir="auto">Error Logs:</p>
<pre><code>2020-07-28 11:22:02 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: 0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
2020-07-28 11:22:02 WARNING (MainThread) [mysensors] Not a valid message: not enough values to unpack (expected 5, got 0)
2020-07-28 11:22:02 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: 4 TSM:INIT
2020-07-28 11:22:02 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: 5 TSF:WUR:MS=0
2020-07-28 11:22:02 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: 11 TSM:INIT:TSP OK
2020-07-28 11:22:02 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: 13 TSM:INIT:GW MODE
2020-07-28 11:22:02 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: 15 TSM:READY:ID=0,PAR=0,DIS=0
2020-07-28 11:22:02 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: 17 MCO:REG:NOT NEEDED
</code></pre>
<pre><code></code></pre>
]]></description><link>https://forum.mysensors.org/topic/11297/new-ethernet-gateway-errors-out-on-home-assistant</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 13:38:46 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11297.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jul 2020 16:43:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New ethernet gateway errors out on Home Assistant on Mon, 18 Apr 2022 06:19:19 GMT]]></title><description><![CDATA[<p dir="auto">During a multiple value assignment, the ValueError: not enough values to unpack occurs when either you have fewer objects to assign than variables, or you have more variables than objects. This error caused by the mismatch between the number of values returned and the number of variables in the assignment statement. This error happened mostly in the case of using <a href="https://www.w3schools.com/python/ref_string_split.asp" rel="nofollow ugc">python split</a>  function. Verify the assignment variables. If the number of assignment variables is greater than the total number of variables, delete the excess variable from the assignment operator. The number of objects returned, as well as the number of variables available are the same.</p>
<p dir="auto">To see what line is causing the issue, you could add some debug statements like this:</p>
<pre><code>if len(line.split()) != "xx":
    print line
</code></pre>
<p dir="auto">This will resolve the value error.</p>
]]></description><link>https://forum.mysensors.org/post/111844</link><guid isPermaLink="true">https://forum.mysensors.org/post/111844</guid><dc:creator><![CDATA[evanbung]]></dc:creator><pubDate>Mon, 18 Apr 2022 06:19:19 GMT</pubDate></item><item><title><![CDATA[Reply to New ethernet gateway errors out on Home Assistant on Fri, 31 Jul 2020 15:57:43 GMT]]></title><description><![CDATA[<p dir="auto">Much appreciated!</p>
<p dir="auto">This is what I ended up with for a working config:</p>
<pre><code>automation: !include 'automations.yaml'
default_config: ~
group: !include 'groups.yaml'
scene:  !include 'scenes.yaml'
script: !include 'scripts.yaml'
mysensors:
  gateways:
    - device: '/dev/ttyUSB0'
      persistence_file: 'mysensors1.pickle'
    - device: '10.10.1.69'
      persistence_file: 'mysensors2.pickle'
      tcp_port: 5003
  optimistic: false
  persistence: true
  retain: true
  version: '2.3'
</code></pre>
]]></description><link>https://forum.mysensors.org/post/106942</link><guid isPermaLink="true">https://forum.mysensors.org/post/106942</guid><dc:creator><![CDATA[mrhutchinsonmn]]></dc:creator><pubDate>Fri, 31 Jul 2020 15:57:43 GMT</pubDate></item><item><title><![CDATA[Reply to New ethernet gateway errors out on Home Assistant on Fri, 31 Jul 2020 05:45:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrhutchinsonmn" aria-label="Profile: mrhutchinsonmn">@<bdi>mrhutchinsonmn</bdi></a> - i dont know if this can help you but this is my homeassistant configuration with ethernet gateway:</p>
<pre><code>mysensors:
  gateways:
    - device: '192.168.X.X'
      persistence_file: 'mysensors/mysensors.json'
      tcp_port: 5003
  optimistic: false
  persistence: true
  version: '2.3'
</code></pre>
<p dir="auto">and here is my ethernet gateway:</p>
<pre><code>// Enable debug prints to serial monitor
#define MY_SOFTSPI
#define MY_IP_ADDRESS 192,168,1,8   // If this is disabled, DHCP is used to retrieve address
#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0x01, 0x08 //AF-A0-F2-15-3B-1C
#include &lt;SPI.h&gt;
void presentation(){
void setup(){
</code></pre>
]]></description><link>https://forum.mysensors.org/post/106929</link><guid isPermaLink="true">https://forum.mysensors.org/post/106929</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Fri, 31 Jul 2020 05:45:05 GMT</pubDate></item><item><title><![CDATA[Reply to New ethernet gateway errors out on Home Assistant on Thu, 30 Jul 2020 20:25:36 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for pointing me in the right direction. I working on figuring that out via the home assistant mysensors gateway doc but getting errors. Will follow-up if I can't figure it out.</p>
]]></description><link>https://forum.mysensors.org/post/106926</link><guid isPermaLink="true">https://forum.mysensors.org/post/106926</guid><dc:creator><![CDATA[mrhutchinsonmn]]></dc:creator><pubDate>Thu, 30 Jul 2020 20:25:36 GMT</pubDate></item><item><title><![CDATA[Reply to New ethernet gateway errors out on Home Assistant on Wed, 29 Jul 2020 05:41:10 GMT]]></title><description><![CDATA[<p dir="auto">To me the errors look like you have connected the gateway to your home assistant controller, and that home assistant is configured for a serial gateway.<br />
Home assistant is processing the debug output as the data it is expecting.<br />
I think you should check your configuration</p>
]]></description><link>https://forum.mysensors.org/post/106885</link><guid isPermaLink="true">https://forum.mysensors.org/post/106885</guid><dc:creator><![CDATA[electrik]]></dc:creator><pubDate>Wed, 29 Jul 2020 05:41:10 GMT</pubDate></item></channel></rss>
