[SOLVED] Error compiling ESP8266 Gateway sketch
  • I am attempting to setup an esp8266 gateway but getting errors in compilation, using the sketch below (arduino ide 1.8.9 and http://arduino.esp8266.com/stable/package_esp8266com_index.json in board manager, with mysensors 2.3.2 library)
    Error:
    d/root/Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: At global scope:
    /root/Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:140:27: error: expected initializer before 'ets_intr_lock'
     extern "C" void IRAM_ATTR ets_intr_lock()
    Using library MySensors at version 2.3.2 in folder: /root/Arduino/libraries/MySensors
    Using library SPI at version 1.0 in folder: /root/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/SPI
    Using library ESP8266WiFi at version 1.0 in folder: /root/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/ESP8266WiFi
    Using library EEPROM at version 1.0 in folder: /root/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/EEPROM
    exit status 1
    Error compiling for board NodeMCU 1.0 (ESP-12E Module).```
     * Version 1.0 - Henrik Ekblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
     * See https://www.mysensors.org/build/connect_radio for wiring instructions.
     * If you are using a "barebone" ESP8266, see
     * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
     * Inclusion mode button:
     * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
    #define MY_BAUD_RATE 9600
    #define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "MySSID"
    #define MY_WIFI_PASSWORD "MyVerySecretPassword"
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_HOSTNAME "ESP8266_GW"
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
  • Mod
    @mrhutchinsonmn you seem to be using an old esp arduino core. Could you update that to the latest version and try again?
  • Yes, that was it. Thought it was handled under preferences with the url.
    Thank you!
  • Mod
    @mrhutchinsonmn no prob! Glad I could help.
  • 4
  • 1
  • 14
  • 933
  • 9
