<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] Stuck at I_FIND_PARENT_REQUEST presentation]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I currently have a couple of MySensors boards with Arduino Pro Mini + nRF24 radios communicating with a Raspberry Pi Gateway.</p>
<p dir="auto">Today, I wanted to add a new sensor to my network (moisture level sensor). I placed on my protoboard the Arduino Pro Mini, a DCDC boost, a connector for the 2xAA battery and the nRF24L01+, connected as described here:  <a href="https://www.mysensors.org/build/connect_radio" rel="nofollow ugc">https://www.mysensors.org/build/connect_radio</a></p>
<p dir="auto">When I power my sensor, messages seem to be transmitted to the gateway but the sensor seems stuck at the find parents state (from my understanding). As I already have running sensors, I assume the gateway is working fine.</p>
<p dir="auto">Here is the logs on the sensor side :</p>
<pre><code>108560 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
110569 !TSM:FPAR:NO REPLY
110571 TSM:FPAR
110575 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
112584 !TSM:FPAR:NO REPLY
112586 TSM:FPAR
112590 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
114601 !TSM:FPAR:NO REPLY
114604 TSM:FPAR
114608 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
116617 !TSM:FPAR:FAIL
116619 TSM:FAIL:CNT=7
116621 TSM:FAIL:DIS
116623 TSF:TDI:TSL
176627 TSM:FAIL:RE-INIT
176629 TSM:INIT
176635 TSM:INIT:TSP OK
176640 TSM:INIT:STATID=40
176642 TSF:SID:OK,ID=40
176644 TSM:FPAR
176650 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
178659 !TSM:FPAR:NO REPLY
178661 TSM:FPAR
178665 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
180674 !TSM:FPAR:NO REPLY
180676 TSM:FPAR
180680 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
182689 !TSM:FPAR:NO REPLY
182691 TSM:FPAR
182695 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
184705 !TSM:FPAR:FAIL
184707 TSM:FAIL:CNT=7
184709 TSM:FAIL:DIS
184711 TSF:TDI:TSL
244715 TSM:FAIL:RE-INIT
244717 TSM:INIT
244723 TSM:INIT:TSP OK
244727 TSM:INIT:STATID=40
244729 TSF:SID:OK,ID=40
244731 TSM:FPAR
244738 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
246747 !TSM:FPAR:NO REPLY
246749 TSM:FPAR
246753 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
248762 !TSM:FPAR:NO REPLY
248764 TSM:FPAR
248768 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
250777 !TSM:FPAR:NO REPLY
250779 TSM:FPAR
250783 ?TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
252792 !TSM:FPAR:FAIL
252794 TSM:FAIL:CNT=7
252796 TSM:FAIL:DIS
252798 TSF:TDI:TSL
</code></pre>
<p dir="auto">And here are the logs on the gateway side :</p>
<pre><code>!TSF:MSG:SEND,0-0-40-40,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
TSF:MSG:READ,26-26-0,s=1,c=1,t=0,pt=7,l=5,sg=0:25.8
TSF:MSG:READ,40-40-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
TSF:MSG:BC
TSF:MSG:FPAR REQ,ID=40
TSF:PNG:SEND,TO=0
TSF:CKU:OK
TSF:MSG:GWL OK
TSF:MSG:BC
TSF:CKU:OK,FCTRL
TSF:MSG:GWL OK
TSF:MSG:BC
TSF:PNG:SEND,TO=0
TSF:CKU:OK
TSF:MSG:GWL OK
TSF:MSG:BC
TSF:PNG:SEND,TO=0
TSF:CKU:OK
TSF:MSG:GWL OK
TSF:MSG:BC
TSF:CKU:OK,FCTRL
TSF:MSG:GWL OK
TSF:MSG:BC
</code></pre>
<p dir="auto">Using <a href="https://www.mysensors.org/build/parser" rel="nofollow ugc">https://www.mysensors.org/build/parser</a>, it seems that the gateway received the find_parent request and send its response. The sensor however does not seem to get it.</p>
<p dir="auto">I tried adding a 4.7uF capacitor on the VCC / GND pins of the radio but nothing changed.</p>
<p dir="auto">Do you have any idea ?</p>
]]></description><link>https://forum.mysensors.org/topic/11345/solved-stuck-at-i_find_parent_request-presentation</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 01:09:19 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11345.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 23 Aug 2020 09:55:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] Stuck at I_FIND_PARENT_REQUEST presentation on Sun, 23 Aug 2020 18:35:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nono8223" aria-label="Profile: nono8223">@<bdi>nono8223</bdi></a> I've this same problem... stock for days. I tried powering the radio directly with a 3.3volts regulator and capciator between GND and 3.3V pin of the nrf24 but still no luck.</p>
<p dir="auto">I don't want to duplicate posts but the details of my issue can by found here<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/eme" aria-label="Profile: Eme">@<bdi>Eme</bdi></a> said in <a href="/post/107265">MySensors Raspberry Pi Gateway + Domotics Controller</a>:</p>
<blockquote>
<p dir="auto">Please someone help me...</p>
</blockquote>
]]></description><link>https://forum.mysensors.org/post/107292</link><guid isPermaLink="true">https://forum.mysensors.org/post/107292</guid><dc:creator><![CDATA[Eme]]></dc:creator><pubDate>Sun, 23 Aug 2020 18:35:57 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Stuck at I_FIND_PARENT_REQUEST presentation on Sun, 23 Aug 2020 13:16:28 GMT]]></title><description><![CDATA[<p dir="auto">Solved!</p>
<p dir="auto">I fixed it by connecting the radio directly to the battery without using the DCDC boost I use for powering the Arduino Pro Mini.</p>
]]></description><link>https://forum.mysensors.org/post/107285</link><guid isPermaLink="true">https://forum.mysensors.org/post/107285</guid><dc:creator><![CDATA[nono8223]]></dc:creator><pubDate>Sun, 23 Aug 2020 13:16:28 GMT</pubDate></item></channel></rss>
