<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Possible to have an external power source for moisture sensors??]]></title><description><![CDATA[<p dir="auto">I want to run 6 analog moisture sensors on a single arduino nano(if possible). I am guessing that may cause erratic behavior from power issues. Is there a way to use an external power source and still provide a connection to the nano, like is done with a jd-vcc pin on my 8 channel relay, so the sensor will work correctly?</p>
]]></description><link>https://forum.mysensors.org/topic/11411/possible-to-have-an-external-power-source-for-moisture-sensors</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 22:43:14 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11411.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Oct 2020 13:21:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Possible to have an external power source for moisture sensors?? on Mon, 26 Oct 2020 07:41:19 GMT]]></title><description><![CDATA[<p dir="auto">I have MySensors node with 5 moisture sensors - work without problems for one year.<br />
Node platform:</p>
<ul>
<li>Arduino Pro Mini 5 V</li>
<li>RFM69HCW powered by 3,3V voltage regulator + resistors on communication lines</li>
<li>5x FDRobot moisture sensors</li>
<li>3x DS18B20 temperature sensors</li>
</ul>
<p dir="auto">powered by 5V, 1A power supply</p>
]]></description><link>https://forum.mysensors.org/post/107897</link><guid isPermaLink="true">https://forum.mysensors.org/post/107897</guid><dc:creator><![CDATA[gieemek]]></dc:creator><pubDate>Mon, 26 Oct 2020 07:41:19 GMT</pubDate></item><item><title><![CDATA[Reply to Possible to have an external power source for moisture sensors?? on Wed, 21 Oct 2020 09:50:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrhutchinsonmn" aria-label="Profile: mrhutchinsonmn">@<bdi>mrhutchinsonmn</bdi></a> So long as the ground wires are all connected together you should be fine.</p>
<p dir="auto">But before you do a lot of work, search on here about moisture sensors, it might save you a lot of time.</p>
]]></description><link>https://forum.mysensors.org/post/107868</link><guid isPermaLink="true">https://forum.mysensors.org/post/107868</guid><dc:creator><![CDATA[skywatch]]></dc:creator><pubDate>Wed, 21 Oct 2020 09:50:52 GMT</pubDate></item><item><title><![CDATA[Reply to Possible to have an external power source for moisture sensors?? on Tue, 20 Oct 2020 19:41:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrhutchinsonmn" aria-label="Profile: mrhutchinsonmn">@<bdi>mrhutchinsonmn</bdi></a> yes. Relays draw a lot of power when switching. Moisture sensors draw almost no power.</p>
]]></description><link>https://forum.mysensors.org/post/107867</link><guid isPermaLink="true">https://forum.mysensors.org/post/107867</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Tue, 20 Oct 2020 19:41:20 GMT</pubDate></item><item><title><![CDATA[Reply to Possible to have an external power source for moisture sensors?? on Tue, 20 Oct 2020 19:17:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> I was looking at it through the perspective of my 8 channel relay which needs an external power source to work reliably. Seems 6 moisture sensors will work fine.</p>
]]></description><link>https://forum.mysensors.org/post/107864</link><guid isPermaLink="true">https://forum.mysensors.org/post/107864</guid><dc:creator><![CDATA[mrhutchinsonmn]]></dc:creator><pubDate>Tue, 20 Oct 2020 19:17:23 GMT</pubDate></item><item><title><![CDATA[Reply to Possible to have an external power source for moisture sensors?? on Tue, 20 Oct 2020 19:12:52 GMT]]></title><description><![CDATA[<p dir="auto">I don’t see why it wouldn’t work, but on the other hand I don’t see the original problem either.</p>
]]></description><link>https://forum.mysensors.org/post/107863</link><guid isPermaLink="true">https://forum.mysensors.org/post/107863</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Tue, 20 Oct 2020 19:12:52 GMT</pubDate></item><item><title><![CDATA[Reply to Possible to have an external power source for moisture sensors?? on Tue, 20 Oct 2020 17:08:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrhutchinsonmn" aria-label="Profile: mrhutchinsonmn">@<bdi>mrhutchinsonmn</bdi></a> Did some more research. It seems it is possible to run all 6 sensors on a single board without a 2nd power source since readings are not taken simultaneously. Is that a correct assertation?</p>
]]></description><link>https://forum.mysensors.org/post/107858</link><guid isPermaLink="true">https://forum.mysensors.org/post/107858</guid><dc:creator><![CDATA[mrhutchinsonmn]]></dc:creator><pubDate>Tue, 20 Oct 2020 17:08:59 GMT</pubDate></item></channel></rss>
