<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MySensors + Irrigation controller sketch with Jeedom -&gt; passing V_Var1, V_Var2 and V_Var3 at node request]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I'm using MySensors since 2017, and recently I was trying to use the irrigation example (<a href="https://www.mysensors.org/build/irrigation" rel="nofollow ugc">https://www.mysensors.org/build/irrigation</a>) but faced a problem which I'm unable to overcome.<br />
The sketch ask every 5 minutes for the V_VAR1 V_VAR2 and V_VAR3 for configuring times and zone names.<br />
I arrived to send manually these values through jeedom (using the proper type : <a href="https://www.mysensors.org/download/serial_api_20#set,-req" rel="nofollow ugc">https://www.mysensors.org/download/serial_api_20#set,-req</a>)  but they are changed to 0 as the controller don't send any value at its request.<br />
Do you know how to set these values to the MySensors items in order to provide the values at the node request?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mysensors.org/topic/11436/mysensors-irrigation-controller-sketch-with-jeedom-passing-v_var1-v_var2-and-v_var3-at-node-request</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 07:19:53 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11436.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Nov 2020 14:37:03 GMT</pubDate><ttl>60</ttl></channel></rss>
