<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[3D printed housing for an MQTT-GW]]></title><description><![CDATA[<p dir="auto">I recently designed a housing for my MQTT-Gateway, based on an ESP8266 module (Node-MCU) and an nRF24L01+PA+LNA. The housing printed great using PLA on my FF Creator Pro. Connections are made using Dupont cables cut in half and soldered directly to the nRF24 where the pins have been removed. I enclose a picture from FreeCad and <a href="https://github.com/BGunnarB/MQTT-GW-housing" rel="nofollow ugc">a link to the stl-files on Github</a> for the base and the cover.</p>
<p dir="auto"><img src="/assets/uploads/files/1608547847450-screenshot-2020-12-21-at-11.41.02.png" alt="Screenshot 2020-12-21 at 11.41.02.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1608547929334-img_0670.jpeg" alt="IMG_0670.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/topic/11491/3d-printed-housing-for-an-mqtt-gw</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 18:18:15 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11491.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Dec 2020 11:21:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 3D printed housing for an MQTT-GW on Sun, 03 Jan 2021 18:53:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evb" aria-label="Profile: evb">@<bdi>evb</bdi></a> Done that. <a href="https://www.thingiverse.com/thing:4697420" rel="nofollow ugc">Here is the link</a></p>
]]></description><link>https://forum.mysensors.org/post/108662</link><guid isPermaLink="true">https://forum.mysensors.org/post/108662</guid><dc:creator><![CDATA[bgunnarb]]></dc:creator><pubDate>Sun, 03 Jan 2021 18:53:53 GMT</pubDate></item><item><title><![CDATA[Reply to 3D printed housing for an MQTT-GW on Mon, 28 Dec 2020 10:45:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evb" aria-label="Profile: evb">@<bdi>evb</bdi></a> Thanks, yes my wife liked it too so all good :-D</p>
<p dir="auto">Unfortunately Thingiverse looses track on many designs so i only see half of my own designs even if the direct links work, so nice to see that someone found it anyway. The last batch of Minis i use is these ones <a href="https://www.ebay.com/itm/323377378845" rel="nofollow ugc">https://www.ebay.com/itm/323377378845</a> but it's the same 8MHz 3.3V that i've used for several years. I've probably consumed 40-50 in various projects and i haven't had a single failure. The voltage regulators are crap of course but following the normal mysensor battery powered recommendations you will remove that. <a href="https://www.youtube.com/watch?v=91aFByn90RY" rel="nofollow ugc">https://www.youtube.com/watch?v=91aFByn90RY</a> here is another video where i'm looking more in detail on the DC powered temp sensor that gets a nice ldo low quiescent voltage regulator. Then it's at 120uA but that is the plain MySensors temp sketch with no modifications.</p>
<p dir="auto">120uA will probably take you quite far if your sensor is not reporting too frequently any if you need to go even lower then you need even better step up or LDO and also patch some MySensor behaviours. I've built sensors before with a sleep current of 4uA following the exellent tips of Nick Gammon <a href="http://www.gammon.com.au/forum/?id=11497" rel="nofollow ugc">http://www.gammon.com.au/forum/?id=11497</a> but again that was not using MySensors or RFM69 chips but rather plain ook chips like this one (<a href="https://github.com/boanjo/rain_sensor" rel="nofollow ugc">https://github.com/boanjo/rain_sensor</a>). But i try to stay at master MySensor and take a small hit in sleep current as it's good enough in most cases</p>
<p dir="auto">Cool! I need to read up on that long thread :)!</p>
]]></description><link>https://forum.mysensors.org/post/108570</link><guid isPermaLink="true">https://forum.mysensors.org/post/108570</guid><dc:creator><![CDATA[boanjo]]></dc:creator><pubDate>Mon, 28 Dec 2020 10:45:51 GMT</pubDate></item><item><title><![CDATA[Reply to 3D printed housing for an MQTT-GW on Sun, 27 Dec 2020 20:10:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boanjo" aria-label="Profile: boanjo">@<bdi>boanjo</bdi></a> a very nice design, not only functional, but also pleasing to the eye.<br />
I've seen your same based design for the temperature node on your thingiverse account, I like that.<br />
I think that I can sell this to my wife to put that in the house :-)</p>
<p dir="auto">Where did you buy your pro mini's? How did you get a deep sleep consumption of only 35 µA?<br />
See my adventures : <a href="https://forum.mysensors.org/topic/4796/battery-powered-sensors/242">https://forum.mysensors.org/topic/4796/battery-powered-sensors/242</a></p>
]]></description><link>https://forum.mysensors.org/post/108561</link><guid isPermaLink="true">https://forum.mysensors.org/post/108561</guid><dc:creator><![CDATA[evb]]></dc:creator><pubDate>Sun, 27 Dec 2020 20:10:08 GMT</pubDate></item><item><title><![CDATA[Reply to 3D printed housing for an MQTT-GW on Sun, 27 Dec 2020 19:29:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">If there is interest here is a model that i've made for MQTT-GW  targeting the Wemos D1 Mini and RFM69 radios. <a href="https://www.thingiverse.com/thing:4657916" rel="nofollow ugc">https://www.thingiverse.com/thing:4657916</a></p>
<p dir="auto">It's a pack with two models for table or wall mounting.</p>
<p dir="auto">BR<br />
//Anders</p>
]]></description><link>https://forum.mysensors.org/post/108554</link><guid isPermaLink="true">https://forum.mysensors.org/post/108554</guid><dc:creator><![CDATA[boanjo]]></dc:creator><pubDate>Sun, 27 Dec 2020 19:29:12 GMT</pubDate></item><item><title><![CDATA[Reply to 3D printed housing for an MQTT-GW on Mon, 21 Dec 2020 14:24:49 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the contribution.<br />
You could maybe upload it also to <a href="http://www.thingiverse.com" rel="nofollow ugc">www.thingiverse.com</a>, so that more people can find it :-)</p>
]]></description><link>https://forum.mysensors.org/post/108479</link><guid isPermaLink="true">https://forum.mysensors.org/post/108479</guid><dc:creator><![CDATA[evb]]></dc:creator><pubDate>Mon, 21 Dec 2020 14:24:49 GMT</pubDate></item></channel></rss>
