<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Home Assistant and smartSleep]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am creating a battery driven alarm siren with led light flash. The thought specs for it is that it will listen for incoming messages from Home Assistant through the MySensors GW, when a message to drive the siren/alarm is received it will stay awake for a couple of minutes to wait further instructions. In order to achieve that I thought of using the smartSleep functionality, wake up every minute to look for messages from Home Assistant. If there is a message the device will instead of sleeping be awake powering the siren and led through a transistor plus waiting for new instructions.</p>
<p dir="auto">According to my understanding and tests HA should be able to buffer messages to be sent once the device is awake. Functionality according to I_PRE_SLEEP_NOTIFICATION and I_POST_SLEEP_NOTIFICATION in docs.</p>
<p dir="auto">The problem I face is that the first message is delivered, once the siren or led is switched ON. Then when the device is awake, no more I_PRE_SLEEP_NOTIFICATION and I_POST_SLEEP_NOTIFICATION will be sent from the device. After that it seems like HA is not sending messages at trigger, I guess just buffering and waiting for pre and post sleep commands.</p>
<p dir="auto">Is this expected behavior?, am I wrong?, is there a way to reset what I guess is a smartSleep flag on the device in HA? Is there any other workarounds that is feasible?</p>
<p dir="auto">Basically what I want to do, smartSleep and wake up every minute, if a message is received the device will be awake for a minute, when certain conditions are fulfilled the device will smartSleep again and the cycle is restarted.</p>
]]></description><link>https://forum.mysensors.org/topic/11540/home-assistant-and-smartsleep</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 11:50:48 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11540.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Jan 2021 07:37:31 GMT</pubDate><ttl>60</ttl></channel></rss>
