<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Newbie Gateway]]></title><description><![CDATA[<p dir="auto">Hi Folks,</p>
<p dir="auto">I'm new at this, but am getting ready to give it a go.</p>
<p dir="auto">I'm a bit confused by the Ethernet/MQTT gateway - in the pictures there seems to be a breadboard but I can't see what's connected to it and for what reason, also as they both need 3.3, how do I give that voltage to both of them?</p>
<p dir="auto">Also any particular Arduino best for a gateway? I saw someone was having trouble with a nano fitting the code in memory, am I best to get a Uno for this one?</p>
<p dir="auto">Thanks,<br />
Brett</p>
]]></description><link>https://forum.mysensors.org/topic/1158/newbie-gateway</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 11:34:36 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1158.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Mar 2015 22:04:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Newbie Gateway on Thu, 26 Mar 2015 10:13:16 GMT]]></title><description><![CDATA[<p dir="auto">Yes, Nano is a bit bigger, but have own usb-serial chip so you can program it directly and have onboard 5-3.3 output. Keep forgetting that:) So if size is not an issue, got with the Nano...</p>
]]></description><link>https://forum.mysensors.org/post/11898</link><guid isPermaLink="true">https://forum.mysensors.org/post/11898</guid><dc:creator><![CDATA[Magiske]]></dc:creator><pubDate>Thu, 26 Mar 2015 10:13:16 GMT</pubDate></item><item><title><![CDATA[Reply to Newbie Gateway on Thu, 26 Mar 2015 09:14:54 GMT]]></title><description><![CDATA[<p dir="auto">Is a Nano better than a Pro Mini? I read it was more USB ready and easier to use, with the 3.3v and 5v being provided on the board pre-regulated and here in the UK it's actually cheaper than a Pro Mini.</p>
]]></description><link>https://forum.mysensors.org/post/11896</link><guid isPermaLink="true">https://forum.mysensors.org/post/11896</guid><dc:creator><![CDATA[Brett Jenkins]]></dc:creator><pubDate>Thu, 26 Mar 2015 09:14:54 GMT</pubDate></item><item><title><![CDATA[Reply to Newbie Gateway on Thu, 26 Mar 2015 07:11:07 GMT]]></title><description><![CDATA[<p dir="auto">Check the <a href="http://www.mysensors.org/build/connect_radio" rel="nofollow ugc">connecting radio</a> and <a href="http://www.mysensors.org/build/ethernet_gateway" rel="nofollow ugc">Connecting Ethernet Gateway</a>. And get some 5.0-&gt;3.3v voltage regulators. Dirt cheap on ebay.</p>
<p dir="auto">For ease of use I would go with the Uno + W5100 shield. Not that much more expensive vs using a Pro Mini, you will have less wiring. And then use Pro Mini's for sensors..</p>
]]></description><link>https://forum.mysensors.org/post/11892</link><guid isPermaLink="true">https://forum.mysensors.org/post/11892</guid><dc:creator><![CDATA[Magiske]]></dc:creator><pubDate>Thu, 26 Mar 2015 07:11:07 GMT</pubDate></item></channel></rss>
