<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Multilayer PCB vs Flexible PCB]]></title><description><![CDATA[<p dir="auto">Does anyone know in what specific application you would use a multi-layer PCB vs. a flexible PCB? Any example would be very helpful.</p>
]]></description><link>https://forum.mysensors.org/topic/11622/multilayer-pcb-vs-flexible-pcb</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 04:54:39 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11622.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Mar 2021 17:33:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Multilayer PCB vs Flexible PCB on Tue, 23 Mar 2021 18:09:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jasonkeel" aria-label="Profile: Jasonkeel">@<bdi>Jasonkeel</bdi></a><br />
The green is the flex PCB,, as you can se how it' turn 90degree a few times<img src="/assets/uploads/files/1616522947005-screenshot-from-2021-03-23-19-08-12.png" alt="Screenshot from 2021-03-23 19-08-12.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/post/109698</link><guid isPermaLink="true">https://forum.mysensors.org/post/109698</guid><dc:creator><![CDATA[bjacobse]]></dc:creator><pubDate>Tue, 23 Mar 2021 18:09:09 GMT</pubDate></item><item><title><![CDATA[Reply to Multilayer PCB vs Flexible PCB on Mon, 22 Mar 2021 17:36:08 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/bjacobse" aria-label="Profile: bjacobse">@<bdi>bjacobse</bdi></a>. I tried even before to understand from pictures but I'm still a learner so can not understand much.</p>
]]></description><link>https://forum.mysensors.org/post/109694</link><guid isPermaLink="true">https://forum.mysensors.org/post/109694</guid><dc:creator><![CDATA[Jasonkeel]]></dc:creator><pubDate>Mon, 22 Mar 2021 17:36:08 GMT</pubDate></item><item><title><![CDATA[Reply to Multilayer PCB vs Flexible PCB on Mon, 22 Mar 2021 17:32:14 GMT]]></title><description><![CDATA[<p dir="auto">Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/peteknight" aria-label="Profile: PeteKnight">@<bdi>PeteKnight</bdi></a> for giving me such a easy to understand explanation.</p>
]]></description><link>https://forum.mysensors.org/post/109693</link><guid isPermaLink="true">https://forum.mysensors.org/post/109693</guid><dc:creator><![CDATA[Jasonkeel]]></dc:creator><pubDate>Mon, 22 Mar 2021 17:32:14 GMT</pubDate></item><item><title><![CDATA[Reply to Multilayer PCB vs Flexible PCB on Sun, 21 Mar 2021 19:47:23 GMT]]></title><description><![CDATA[<p dir="auto">Inside Hearing aids, the PCB are "mainly" only flexible PCB as the PCB must bend and follow the mechanical shape, think this picture gives an idea<br />
<a href="https://www.manualslib.com/manual/1902167/Oticon-Aurora-Minirite-312-T-Rc.html" rel="nofollow ugc">https://www.manualslib.com/manual/1902167/Oticon-Aurora-Minirite-312-T-Rc.html</a></p>
]]></description><link>https://forum.mysensors.org/post/109689</link><guid isPermaLink="true">https://forum.mysensors.org/post/109689</guid><dc:creator><![CDATA[bjacobse]]></dc:creator><pubDate>Sun, 21 Mar 2021 19:47:23 GMT</pubDate></item><item><title><![CDATA[Reply to Multilayer PCB vs Flexible PCB on Sun, 21 Mar 2021 16:30:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jasonkeel" aria-label="Profile: Jasonkeel">@<bdi>Jasonkeel</bdi></a> obviously one is rigid and the other is flexible!<br />
Flexible PCBs are found in things like RGB LED strips, where components need to be mounted to a flexible substrate, whereas rigid single/multi layer PCBs are used for the majority of PCB designs because you want the substrate material to be rigid and easy to mount in enclosures.<br />
Mounting discreet non-flexible components onto a flexible substrate has its issues, as the pads that connect to the components can tear if the pcb is bent through too tight a radius.</p>
<p dir="auto">Pete.</p>
]]></description><link>https://forum.mysensors.org/post/109688</link><guid isPermaLink="true">https://forum.mysensors.org/post/109688</guid><dc:creator><![CDATA[PeteKnight]]></dc:creator><pubDate>Sun, 21 Mar 2021 16:30:05 GMT</pubDate></item></channel></rss>
