[SOLVED]Atmega 328P reset to start
  • Hello
    I just get a Atmega 328P in DIL package. It was configured with external 16Mhz clock.
    I set up it with internal 8mhz and minicore bootloader with Arduino IDE and Arduino as ISP
    Here is the configuration I used
    Burning the bootloader works well. I follow this guide for wiring, and I add a led on D13 with a 1k resistor to GND.
    After burning the bootloader, the led was blinking as usual. I was happy 🙂
    But, after that, I unplug the arduino as ISP, the clock source, and replug only power source. The led was not blinking anymore. 😠
    I replug the arduino as ISP (not the clock), and use AVRDUDESS to read fuse, and miracle the led restart to blink 😁
    Here is the fuses readed
    I unplug everything again, and replug only power source ... no blink 😳 . And I don't know why, I try to send reset (GND to Reset Pin), and blink started.
    I've tested it and retested it, the led don't start to blink until I send reset.
    Any ideas of why I need to reset to start the arduino ? Is there any fuse or lock that configure it ? Something I miss ?
    Thank you for your help
  • Did you check the voltage on the reset pin? Might be a faulty pullup connection on the reset pin, if your circuit is on a breadboard.
  • Hello
    I have 4.8V on the reset pin (directly mesured on the DIL package). I use a 10k pullup resistor.
    The atmega was on a single board with uno bootloader before. It was working great, and the reset pin was not connected at all (only vcc/gnd/D2/D4 and clock where connected before I put it on the breadborard)
    I've tried with 10k resistor, without resistor (reset floating), with caps. Always the same thing
  • @barrydou said in Atmega 328P reset to start:
    Hello
    Whne you burn MiniCore does the led flash TWICE every second? You said the LED was flashing "as usual" - thatis normally ONE blink per second.
    You do have an externa crystal (16MHz as you said) connected for the ATmega?
    The Atmega need external crystal for programming sketch...
  • @skywatch
    Yes after flashing MiniCore, the led flash twice per second.
    If I keep only VCC, GND, pullup on Reset and the led on D13, I unplug / replug the power => Nothing, until I force a reset (GND on Reset pin)
    When I force, the led flash twice per second (even without clock, but the fuses are set to 8Mhz Internal)
    @skywatch
    That is good!
    How are you removing the power and for how long? Try 30 seconds before reconnect.....
    That is contradictory - it is not 'without clock' if the fuses are set to 8MHx internal - it has 8MHz internal clock running.....OR maybe I mis-understand?
  • @skywatch said in Atmega 328P reset to start:
    @skywatch
    That is good!
    I unplug the vcc dupond cable from breadboard (beetween power source and breadboard). And I plug it again.
    Before this message, I unplug during a few seconds. I try 1 minute now, it's the same.
    Sorry, I mean without external clock. I remove external Quartz and Caps just after flashing the minicore
  • @barrydou Intereting - I have flashed MiniCore with 8MHz internal, loaded the sketch, removed the xtal and it works as expected.... So no clue what is different with your experience...
  • I've just found it !
    I added a 100nf caps between VCC and GND, just near pin 7 and 8, like documented on the MiniCore github page.
    https://github.com/MCUdude/MiniCore => DIP-28 package ATmega8/48/88/168/328
    And now, it's work as expected. I just plug VCC and GND, and the led blink twice per second.
    Don't know why, but it's OK 😀
    Thank you for all your ideas
  • @barrydou Well done, good job!
    When in doubt, read the manual! - Easy in hindsight, isn't it? 😉
  • @skywatch Yes ... RTFM ... So simple 😁
