<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Node doesn’t seem to reconnect]]></title><description><![CDATA[<p dir="auto">I have a 2 relay node in my master bedroom running 2.3.2.  Gateway is pi gateway running the same version.  Node is built with the easy/newbie board.  It’s a decent distance away from the gateway, periodically something happen and I guess it stops being able to communicate.  But oddly enough, it never seems to try to reconnect.  I thought the built in watchdog should get it to go back to find parent or something.</p>
<p dir="auto">If I unplug the module and plug back in, reconnect, all is well.</p>
<p dir="auto">Just wondering if anyone has any advice for getting nodes to retry to connect to gateway better.  I feel I’m missing something simple in the stability aspect here.</p>
]]></description><link>https://forum.mysensors.org/topic/11682/node-doesn-t-seem-to-reconnect</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 10:16:04 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11682.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 May 2021 06:11:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Node doesn’t seem to reconnect on Mon, 10 May 2021 15:09:11 GMT]]></title><description><![CDATA[<p dir="auto">I suppose you are using a arduino pro mini when you speak of a newbie board. So effectively it is not easy to connect a laptop to the serial output. I don't think the arduino will reset when connecting, but it's not convenient.</p>
<p dir="auto">So to detect if it is the relayboard, can you deconnect it from the newbie board and let run the node like this.<br />
If it works now for some time, we are sure it is the relayboard somehow influencing the arduino.<br />
If it still freeze, it is not the relayboard and we must continue to debug...</p>
]]></description><link>https://forum.mysensors.org/post/110207</link><guid isPermaLink="true">https://forum.mysensors.org/post/110207</guid><dc:creator><![CDATA[evb]]></dc:creator><pubDate>Mon, 10 May 2021 15:09:11 GMT</pubDate></item><item><title><![CDATA[Reply to Node doesn’t seem to reconnect on Mon, 10 May 2021 03:31:49 GMT]]></title><description><![CDATA[<p dir="auto">I have done some digging around and and I am not 100% sure or not but I do not recall if the relay module in the node is optoisolated, so that could be part of the interference if you think that could be the issue.  I am pretty sure the 5v power for the relay module and the arduino are coming from the same 5v psu BUT I am 99.99% sure I do not have a cap across the 5v/gnd on the relay module, so I guess I could pull that module out and see about replacing it with an optoisolated one (if it's not isolated) and put a decoupling capacitor on the relay module itself.</p>
<p dir="auto">Just some thoughts.</p>
]]></description><link>https://forum.mysensors.org/post/110194</link><guid isPermaLink="true">https://forum.mysensors.org/post/110194</guid><dc:creator><![CDATA[CrankyCoder]]></dc:creator><pubDate>Mon, 10 May 2021 03:31:49 GMT</pubDate></item><item><title><![CDATA[Reply to Node doesn’t seem to reconnect on Sun, 09 May 2021 19:36:42 GMT]]></title><description><![CDATA[<p dir="auto">I would need to leave something connected all the time wouldn't I?  Hooking laptop to the arduino would cause the reset?</p>
<p dir="auto">The relay module is a purchased 2 relay board for the arduino, 5v logic.</p>
]]></description><link>https://forum.mysensors.org/post/110192</link><guid isPermaLink="true">https://forum.mysensors.org/post/110192</guid><dc:creator><![CDATA[CrankyCoder]]></dc:creator><pubDate>Sun, 09 May 2021 19:36:42 GMT</pubDate></item><item><title><![CDATA[Reply to Node doesn’t seem to reconnect on Sun, 09 May 2021 19:16:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crankycoder" aria-label="Profile: CrankyCoder">@<bdi>CrankyCoder</bdi></a> This could have several reasons...<br />
To debug this, you should activate the mysensors debug statement. Let the node run and at the moment you see no connection anymore, connect a laptop/computer to the node via the serial connection and see what the node is doing.<br />
It could be that the node is frozen.<br />
You are talking about a 2 relay node. How this relay board is connected to the newbie board? A selfmade relay board or a bought one? What are you switching with these relays? External systems can have an 'electronic' influence on the arduino causing a malfunction...</p>
]]></description><link>https://forum.mysensors.org/post/110191</link><guid isPermaLink="true">https://forum.mysensors.org/post/110191</guid><dc:creator><![CDATA[evb]]></dc:creator><pubDate>Sun, 09 May 2021 19:16:17 GMT</pubDate></item></channel></rss>
