<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t find Mysensors in Home Assist]]></title><description><![CDATA[<p dir="auto">When I go to integrations as per the guide:<br />
<em>"To integrate your Serial, Ethernet (LAN) or MQTT MySensors Gateway, go to Configuration &gt;&gt; Integrations in the UI, click the button with + sign and from the list of integration select MySensors."</em></p>
<p dir="auto">There is no MySensors to select in the integrations.  I have Home Assistant OS 5.9 running on a raspberry pi.</p>
]]></description><link>https://forum.mysensors.org/topic/11709/can-t-find-mysensors-in-home-assist</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 08:36:09 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11709.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Jun 2021 13:16:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t find Mysensors in Home Assist on Fri, 04 Jun 2021 20:55:00 GMT]]></title><description><![CDATA[<p dir="auto">I updated home assist and then the integration appeared.  Everything is working now.</p>
]]></description><link>https://forum.mysensors.org/post/110396</link><guid isPermaLink="true">https://forum.mysensors.org/post/110396</guid><dc:creator><![CDATA[stewie]]></dc:creator><pubDate>Fri, 04 Jun 2021 20:55:00 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t find Mysensors in Home Assist on Thu, 03 Jun 2021 19:45:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stewie" aria-label="Profile: stewie">@<bdi>stewie</bdi></a> I've read about another integration that it is available only when advanced mode is on in user profile. Do you have it on? If not, you can try turning it on to see if it becomes available?</p>
]]></description><link>https://forum.mysensors.org/post/110383</link><guid isPermaLink="true">https://forum.mysensors.org/post/110383</guid><dc:creator><![CDATA[alexelite]]></dc:creator><pubDate>Thu, 03 Jun 2021 19:45:38 GMT</pubDate></item></channel></rss>
