<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Corrupted serial debug output]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm building my first MySensors serial gateway on pro mini (ATmega328 3.3V) controller. As a serial adapter I've got PL2303HX adapter connected to arduino.</p>
<p dir="auto">My test scetches are successfully apploaded to arduino and I also tested serial output via serial monitor of arduino IDE.</p>
<p dir="auto">But when I get NRF24L01+ connected and serial scetch uploaded to the board I've got some corrupted/binary output to my serial monitor. It looks like screenshot I've attached.</p>
<p dir="auto">![0_1622790526190_2021-06-03_21-59-59.png](Uploading 0%)</p>
<p dir="auto">Could somebody direct me to the ways I can debug the issus?</p>
]]></description><link>https://forum.mysensors.org/topic/11711/corrupted-serial-debug-output</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 05:17:05 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11711.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Jun 2021 07:09:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Corrupted serial debug output on Fri, 04 Jun 2021 19:11:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skywatch" aria-label="Profile: skywatch">@<bdi>skywatch</bdi></a> that helped! resolved, thank you!</p>
]]></description><link>https://forum.mysensors.org/post/110392</link><guid isPermaLink="true">https://forum.mysensors.org/post/110392</guid><dc:creator><![CDATA[Max Kurilov]]></dc:creator><pubDate>Fri, 04 Jun 2021 19:11:07 GMT</pubDate></item><item><title><![CDATA[Reply to Corrupted serial debug output on Fri, 04 Jun 2021 12:02:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skywatch" aria-label="Profile: skywatch">@<bdi>skywatch</bdi></a>, 3.3V at 16MHz is somewhat out of specs, but it works at 115200bps using the hardware uart.</p>
]]></description><link>https://forum.mysensors.org/post/110389</link><guid isPermaLink="true">https://forum.mysensors.org/post/110389</guid><dc:creator><![CDATA[alexelite]]></dc:creator><pubDate>Fri, 04 Jun 2021 12:02:36 GMT</pubDate></item><item><title><![CDATA[Reply to Corrupted serial debug output on Fri, 04 Jun 2021 09:31:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/max-kurilov" aria-label="Profile: Max-Kurilov">@<bdi>Max-Kurilov</bdi></a> If using 3.3V hen max serial speed is 38400 - Try setting that in your serial  monitor, it should do the trick (unless you set serial speed differently in your sketch, but we don't know as you didn't post your sketch).</p>
]]></description><link>https://forum.mysensors.org/post/110386</link><guid isPermaLink="true">https://forum.mysensors.org/post/110386</guid><dc:creator><![CDATA[skywatch]]></dc:creator><pubDate>Fri, 04 Jun 2021 09:31:03 GMT</pubDate></item><item><title><![CDATA[Reply to Corrupted serial debug output on Fri, 04 Jun 2021 07:30:48 GMT]]></title><description><![CDATA[<p dir="auto">Welcome to the forum <a class="plugin-mentions-user plugin-mentions-a" href="/user/max-kurilov" aria-label="Profile: Max-Kurilov">@<bdi>Max-Kurilov</bdi></a></p>
<p dir="auto">Could you try to re-upload the screen shot? Seems like the forum messed it up.</p>
]]></description><link>https://forum.mysensors.org/post/110385</link><guid isPermaLink="true">https://forum.mysensors.org/post/110385</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Fri, 04 Jun 2021 07:30:48 GMT</pubDate></item></channel></rss>
