<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New To CNC PCB Routing (Warning, Long Post)]]></title><description><![CDATA[<p dir="auto">I am a complete, or was 2 months ago, newbie. I bought a 3018 to isolation route guitar effect pcb's, and I'm having a devil of a time.  I am using EAGLE to design the board, and Flatcam to generate g-code, and lastly, Candle to send it to my mill.<br />
Let me say, after watching so many YT vids, I know it <strong>can</strong> be done, I just can't seem to hit on the right combo.<br />
There seems be a LOT of different setting in each program that don't want to play well with each other if not correct. I know I don't know all of these settings.<br />
I was able, at one point, to mill a fairly decent board, but the results confirmed that a heightmap was needed to attain any usable results.<br />
That's when it all went south for me. The version of Candle I'm using <em>seems</em> to only probe in mm, and I started in inches.<br />
So I went back and set Eagle to mm (I think), and when I import it to the older version of FC, FC converts it to inches. I upgraded FC, and <em>seem</em> to be able to keep the mm's. Do the heightmap in Candle, in mm's, use the heightmap, and the mill sees the HM values as inches, and of course maxes the Z (broke my first of many bits). I am not opposed to converting the mm that the HM creates to inches, and manually changing all the results, <em>if</em> that would be my answer.<br />
The other blaring problem I have, is when I get the g-code into candle, or an online viewer, even if I change the settings, the start Z and end Z are both WAY to high.<br />
I have tried other software, but cant even get this far.<br />
I am running Win7<br />
I know that most, if not all, of my problems stem from my lack of knowledge.<br />
TIA</p>
]]></description><link>https://forum.mysensors.org/topic/11725/new-to-cnc-pcb-routing-warning-long-post</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 01:17:00 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11725.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 Jun 2021 15:17:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New To CNC PCB Routing (Warning, Long Post) on Mon, 21 Jun 2021 17:20:32 GMT]]></title><description><![CDATA[<p dir="auto">Lots of info here:  <a href="https://forum.mysensors.org/topic/8735/cnc-pcb-milling?_=1624294898545">https://forum.mysensors.org/topic/8735/cnc-pcb-milling?_=1624294898545</a>  It's as close as you'll find to a complete walkthru.</p>
<p dir="auto">Turnaround is faster than JLPCB (an hour vs days).  Otherwise, I would agree.  TL;DR: for rapid iteration, or you simply want something fast, DIY PCB's are hard to beat.</p>
<p dir="auto">As to topicality, it's a subject not covered well on most other forums.  CNC Zone has some posts, but that's about it.</p>
<p dir="auto">All in all, the tools keep getting better, and it's easier now than before to find speciallized bits that make the work easier.</p>
]]></description><link>https://forum.mysensors.org/post/110499</link><guid isPermaLink="true">https://forum.mysensors.org/post/110499</guid><dc:creator><![CDATA[NeverDie]]></dc:creator><pubDate>Mon, 21 Jun 2021 17:20:32 GMT</pubDate></item><item><title><![CDATA[Reply to New To CNC PCB Routing (Warning, Long Post) on Mon, 21 Jun 2021 11:15:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skypn" aria-label="Profile: skypn">@<bdi>skypn</bdi></a> I have no idea how this fits-in with the MySensors forum - if at all.</p>
<p dir="auto">I find it difficult to justify the time, cost and poor quality results of home milling PCBs compared to the results you get from the likes of JLCPCB</p>
]]></description><link>https://forum.mysensors.org/post/110498</link><guid isPermaLink="true">https://forum.mysensors.org/post/110498</guid><dc:creator><![CDATA[PeteKnight]]></dc:creator><pubDate>Mon, 21 Jun 2021 11:15:01 GMT</pubDate></item></channel></rss>
