<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I use MySensors library to have one Sensor Transmitter and one Receiver without any Gateway]]></title><description><![CDATA[<p dir="auto">I am 74 years old retired Telecom Engineer and new to MySensors forum. I like the MySensors Battery node for Soil Monitoring and using it with ESP8266 WiFi gateway. I also want to have a Simple setup just One Transmitter and One Receiver without any Gateway to monitor Soil Moisture (and Node's Battery) of my Green House. Any pointer will be greatly appreciated.</p>
]]></description><link>https://forum.mysensors.org/topic/11753/can-i-use-mysensors-library-to-have-one-sensor-transmitter-and-one-receiver-without-any-gateway</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 06:00:51 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11753.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Jul 2021 02:39:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I use MySensors library to have one Sensor Transmitter and one Receiver without any Gateway on Sun, 01 Aug 2021 16:26:18 GMT]]></title><description><![CDATA[<p dir="auto">One little project and you're hooked!  You know you're going to want another sensor in the yard, so consider a gateway running MQTT (called a broker).  Once you have that, it's really easy to add more sensors.</p>
<p dir="auto">But if you're really strong willed an will only be using two devices ever, you might look at <a href="https://nrf24.github.io/RF24/index.html" rel="nofollow ugc">https://nrf24.github.io/RF24/index.html</a>.  You can get an Arduino Nano and an nRF24 radio for about $3.50 from Aliexpress (downside: delivery takes ~2 months, so get 10 each.)</p>
<p dir="auto">MySensors Library can do this, too, but I find it a little bloated.</p>
<p dir="auto">Personal note: I'm 70, retired engineer, and have only four projects going right now.</p>
]]></description><link>https://forum.mysensors.org/post/110686</link><guid isPermaLink="true">https://forum.mysensors.org/post/110686</guid><dc:creator><![CDATA[OldSurferDude]]></dc:creator><pubDate>Sun, 01 Aug 2021 16:26:18 GMT</pubDate></item><item><title><![CDATA[Reply to Can I use MySensors library to have one Sensor Transmitter and one Receiver without any Gateway on Wed, 28 Jul 2021 11:16:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> Thank you for your immediate solution. I will try it now.</p>
]]></description><link>https://forum.mysensors.org/post/110660</link><guid isPermaLink="true">https://forum.mysensors.org/post/110660</guid><dc:creator><![CDATA[RagoTube]]></dc:creator><pubDate>Wed, 28 Jul 2021 11:16:03 GMT</pubDate></item><item><title><![CDATA[Reply to Can I use MySensors library to have one Sensor Transmitter and one Receiver without any Gateway on Wed, 28 Jul 2021 07:40:15 GMT]]></title><description><![CDATA[<p dir="auto">Welcome to the forum <a class="plugin-mentions-user plugin-mentions-a" href="/user/ragotube" aria-label="Profile: RagoTube">@<bdi>RagoTube</bdi></a></p>
<p dir="auto">Yes, it can be done by using node to node communication and setting MY_PARENT_NODE_IS_STATIC and MY_PARENT_NODE_ID.</p>
<p dir="auto">But it might be easier to use the plain radiohead library, since you would not need most features in MySensors.</p>
]]></description><link>https://forum.mysensors.org/post/110652</link><guid isPermaLink="true">https://forum.mysensors.org/post/110652</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Wed, 28 Jul 2021 07:40:15 GMT</pubDate></item></channel></rss>
